adversexreality Posted October 19, 2011 Share Posted October 19, 2011 how do you get the headliner out of the car after it's loose? I make T-Shirts! and I Detail Cars(I'll go to you!) Send me a PM!! Link to comment Share on other sites More sharing options...
01rs25 Posted October 19, 2011 Author Share Posted October 19, 2011 It's like tetris! I ended up removing the seats and center console to gain some room. But it's not easy. That was the hardest part of the whole thing. Remember to be careful with the foam headliner, if you crack it or bend it will normally show once covered. Slammed more than your girlfriend. Link to comment Share on other sites More sharing options...
adversexreality Posted October 19, 2011 Share Posted October 19, 2011 figured that. I make T-Shirts! and I Detail Cars(I'll go to you!) Send me a PM!! Link to comment Share on other sites More sharing options...
01rs25 Posted October 19, 2011 Author Share Posted October 19, 2011 If your thinking about doing this mod, that should be the least of your concerns. It's very labor intensive, and requires pretty much removal of the entire interior. Slammed more than your girlfriend. Link to comment Share on other sites More sharing options...
copenhagen6123 Posted October 19, 2011 Share Posted October 19, 2011 Love the look, I'm sold time to order some fabric. Link to comment Share on other sites More sharing options...
SBT Posted October 19, 2011 Share Posted October 19, 2011 Could I entice you down to SoCar to help me with mine? Would also need to repair the sunroof at the same time - which would be the ideal time to do the headliner. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
01rs25 Posted October 19, 2011 Author Share Posted October 19, 2011 I'm alittle far from you. Aka all the way on the other side of the country. Your sunroof issues should be realitively easy if your looking to fix that w/o doing the headliner. Pull the 2 screws out of the visors (remove visors) Pull the visor clips out, they should just pull out although you may need a very small screwdriver Remove the 2 screws out of the map light assembly and disconnect and remove map light Remove the Oh shit handles. Theres 2 covers on each with a screw behind. Remove the covers and pull the handles down. On the B-pillars you should be able to just remove the airbag tab, remove the 10mm bolt and pull the panels off. This should give you enough room to work. If you need more drop the dome light. 2 more screws inside the cover. Drop the headliner down, and sit in the sunroof opening so that it doesn't bend or crease. You should have full access to the sunroof/ sunroof motor for you to either replace or fix. Hope this helps. Slammed more than your girlfriend. Link to comment Share on other sites More sharing options...
SBT Posted October 19, 2011 Share Posted October 19, 2011 On a wagon??? Those sunroofs are tanks! - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
SBT Posted October 19, 2011 Share Posted October 19, 2011 And yeah - believe we've met before years ago at some of the local SoCal Subaru meets. Was driving a Forester, a OBS, or one of the 98 LGTs at the time. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
jhawk222 Posted January 17, 2012 Share Posted January 17, 2012 Headliner looks really good! GREAT write-up!! I did it years ago in my 92 Galant VR4. It came out spectacular. After seeing your interior I will definitely be tackling this when the weather warms again!!! Link to comment Share on other sites More sharing options...
stevenva Posted January 24, 2012 Share Posted January 24, 2012 Here is a simple and professional solution to labeling your sunroof controls. Remember those "Model airplane decals" which are activated by water? They are known as waterslide decals. Vendors sell the blank decal paper, which can be custom printed using your own inkjet or laser printer. Give it a try. http://www.decalpaper.com/Default.asp RIP 96 Legacy 2.2 4EAT lost reverse @ 374,000 miles Link to comment Share on other sites More sharing options...
01rs25 Posted January 24, 2012 Author Share Posted January 24, 2012 Interesting! Guess you could try by the font is so incredibly small that I just figured it would be hard to reproduce. Slammed more than your girlfriend. Link to comment Share on other sites More sharing options...
copenhagen6123 Posted January 24, 2012 Share Posted January 24, 2012 On the to do list! Great write up Link to comment Share on other sites More sharing options...
BOOSSTT Posted January 25, 2012 Share Posted January 25, 2012 Subscribed! Thanks for such a great writeup man! Link to comment Share on other sites More sharing options...
01rs25 Posted January 25, 2012 Author Share Posted January 25, 2012 It got a little weak at the end. I was just trying to get it finished, and wasn't in the picture taking mood. As always, shoot me a messege or post on here if you have any questions. Slammed more than your girlfriend. Link to comment Share on other sites More sharing options...
copenhagen6123 Posted January 25, 2012 Share Posted January 25, 2012 So did you get it all back in? Link to comment Share on other sites More sharing options...
01rs25 Posted January 25, 2012 Author Share Posted January 25, 2012 Yeah there are installed pictures above I thought. Slammed more than your girlfriend. Link to comment Share on other sites More sharing options...
SuperhawkLGT Posted February 7, 2012 Share Posted February 7, 2012 Can you give more specifics on the red led's? Which ones and where you wired them in? Thanks. Link to comment Share on other sites More sharing options...
qwick911 Posted August 5, 2012 Share Posted August 5, 2012 hey 01rs25 i had the idea to do my headliner in suede as well then seen this post. great DIY btw, i am currently doing this to mine as well (sedan with sunroof) and i'm having a difficult time with the headliner. when you did yours did you start from the back and moved towards the front, or the other way around or start in the middle and move outwards. i tried starting at the back but i get so much excess material when i get to the front. any helps would be appreciated thanks. i am also doing the visors and could add to your post if you would like (since you sent yours out. Link to comment Share on other sites More sharing options...
Dragon-Wagon Posted June 20, 2013 Share Posted June 20, 2013 http://i19.photobucket.com/albums/b192/00vr6gti/DIY%20Suede%20Interior/IMG_3203.jpg[/img] We want to seperate these pieces. Pull back the sound deadning and and find the plastic welds. We want to remove these. http://i19.photobucket.com/albums/b192/00vr6gti/DIY%20Suede%20Interior/IMG_3204.jpg Be careful and drill these out. http://i19.photobucket.com/albums/b192/00vr6gti/DIY%20Suede%20Interior/IMG_3205.jpg How did you get the plastic welds back together? I'm working on my 3rd gen right now and the door cards are full of these things. What can I do to seal it back up when I'm done? Thanks for the inspiration and the help! Link to comment Share on other sites More sharing options...
Andy_Mac Posted March 30, 2015 Share Posted March 30, 2015 Bumping this ancient thread. If the OP is still around, how did the handles and other often used pieces hold up being just painted? Didn't flake/ rub off after a while 2000 Legacy B4 RSK - SOLD 2006 Legacy BP5 GT Spec B wagon - Garage Thread 2011 VW T5 van 2.0L of turbo diesel awesomeness Link to comment Share on other sites More sharing options...
