snow05gtRI Posted April 4, 2011 Share Posted April 4, 2011 Why ahve all forums seemed to come to this. These are places to share information and help each other. Every post that does not pertain to the threads topic gets in the way of someones research. Post in off topic for socializing or cheesey jokes Anthony i was trying to make it obvious that you're all just feeding rao. unless you get a PhD to come in here and explain it all and cite specific sources and have an award winning presentation, you're not gonna "prove" anything. for the record, I don't think the grounding mod or big 3 are a bad idea to do to your car at all. i haven't done them (yet), but that doesn't mean you guys shouldn't. i've always thought it's a good touch for the electrical system. i would like to see a video of before/after if that does ever happen though. would be nice to put some hard evidence behind the theory. Link to comment Share on other sites More sharing options...
RedDawg Posted April 4, 2011 Share Posted April 4, 2011 it's worth the $35 as an excuse to be outside working on my car for a few hours instead of inside watching tv, or doing dishes, or laundry, or etc, etc, etc. Link to comment Share on other sites More sharing options...
Mark34 Posted April 4, 2011 Share Posted April 4, 2011 I agree with RedDawg on this one. I installed one and perceived that my sub hit a little bit harder, but that was about it. I came across this graph from Zero/Sports. http://www.zerosports.co.jp/shop/index.php?main_page=product_info&products_id=339 Link to comment Share on other sites More sharing options...
PhilT Posted April 4, 2011 Share Posted April 4, 2011 I rewired my car with welding cable, even the indicators, and the difference is amazing ! Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
rao Posted April 4, 2011 Share Posted April 4, 2011 really any voltage drop is noticable, it just matters whether or not its enough for you to do anything about it. so you know that when your car is off a battery sits at around 12.6. when you turn the car on, the alternator boosts the voltage to 13.8-14.4 generally. that increase by itself is noticeable in the car audio industry. basically the ideal situation is to have as high of voltage as possible without damaging electrical components which is around 16-18 volts depending on the car. personally my legacy ran at 15.5 volts until i installed a h.o. alternator. now i dropped it down to 14.7 considering i dont need the extra current and voltage that puts out. standard 8 gauge wire can handle around 500 watts safely or roughly 40 amps of current....wait a minute...so if a factory alt such as our legacy has a stock alt of 110 on a 05 then were not getting the full amount of current to the battery. you can push the 8 gauge up to about 60a before any melting or burning of the wire would incur. 4 gauge can handle about 80-100 amps. 1/0 gauge can do upwards of 300 amps. that will give the alternator the least resistance so there will be very little if any fluctuation in current/voltage flow. make sense? these references are calculated via 12.6v base. these numbers do go up when the voltage goes up but the wire is still limited by current ratings so there is only so much you can do with the stock wiring, alt, or battery. i hope this kinda helped. Unfortunately this doesn't help at all. According to your post every Legacy made should have melted ground wires due to the output of the stock alternator. So far that hasn't happened. i was trying to make it obvious that you're all just feeding rao. unless you get a PhD to come in here and explain it all and cite specific sources and have an award winning presentation, you're not gonna "prove" anything. for the record, I don't think the grounding mod or big 3 are a bad idea to do to your car at all. i haven't done them (yet), but that doesn't mean you guys shouldn't. i've always thought it's a good touch for the electrical system. i would like to see a video of before/after if that does ever happen though. would be nice to put some hard evidence behind the theory. Some simple answers to some simple questions would get the job done. That doesn't seem likely to happen though. I rewired my car with welding cable, even the indicators, and the difference is amazing ! What brand and color did you use? Was it directional? Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
BigTDogg MA Posted April 4, 2011 Share Posted April 4, 2011 i was trying to make it obvious that you're all just feeding rao. He's definitely the most active troll I've seen on any internet forum ever. Link to comment Share on other sites More sharing options...
rao Posted April 4, 2011 Share Posted April 4, 2011 That hurts Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
mwiener2 Posted April 4, 2011 Share Posted April 4, 2011 I once put wire in backwards in a car. Damn thing wouldn't run right. I put the wire in correctly and all my gauges worked properly. That's science. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Mark34 Posted April 4, 2011 Share Posted April 4, 2011 But I also heard that extra grounding cables directly affects oil life and consumption. Link to comment Share on other sites More sharing options...
PhilT Posted April 4, 2011 Share Posted April 4, 2011 What brand and color did you use? Was it directional? Lincoln, black, it was tri-directional. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
rao Posted April 4, 2011 Share Posted April 4, 2011 I've read that Miller works better. That tri-directional stuff is marketing BS. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
mwiener2 Posted April 4, 2011 Share Posted April 4, 2011 I only use gold termination rings My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
PhilT Posted April 4, 2011 Share Posted April 4, 2011 I've read that Miller works better. That tri-directional stuff is marketing BS. That depends on what you mean by better. I heard it allows the electricity to flow smoother, but that's not always a good thing. I was going to change my wires to AC wiring, that will allow the electricity to flow both ways. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
mwiener2 Posted April 5, 2011 Share Posted April 5, 2011 Don't use AC wiring. DC wires allow the electrons to flow from one end to another. Since AC wires only allow the electrons to bounce back and forth, you won't get enough electron flow where you need it. A DC wire is like a garden hose. Electrons just fall out the end of it. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
ama0787 Posted April 5, 2011 Share Posted April 5, 2011 Mweiner , I guess the difference in ac/dc wiring you mentioned explains why my home wording is like a single copper strand vs. The stuff I use on the cars which is a multi-strand. I can't believe o never put 2 & 2 together Thanks for the info Link to comment Share on other sites More sharing options...
BigTDogg MA Posted April 5, 2011 Share Posted April 5, 2011 Here you go Rao: http://forums.rennlist.com/rennforums/924-931-944-951-968-forum/215060-bad-grounds-destroy-your-wheel-bearings-where-is-sid-when-you-need-him.html Save your wheel bearings, make a grounding kit Link to comment Share on other sites More sharing options...
PhilT Posted April 5, 2011 Share Posted April 5, 2011 Here you go Rao: http://forums.rennlist.com/rennforums/924-931-944-951-968-forum/215060-bad-grounds-destroy-your-wheel-bearings-where-is-sid-when-you-need-him.html Save your wheel bearings, make a grounding kit So electricity will always find its way to ground ? How do they ground electricity on ships Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
mwiener2 Posted April 5, 2011 Share Posted April 5, 2011 Well Duh! Everyone knows water is a great conductor of electricity. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
doctorbrody Posted April 5, 2011 Share Posted April 5, 2011 I hate to interrupt the epic sarcasm, but I'll chime in with my limited experience with a grounding kit. When I bought my OBXT, it had a rough idle. A few months later I installed a 20mm sway bar, SPT intake and a Buddy Club Grounding Kit - idle smoothed right out. I no longer have the SPT intake, but my idle is still smooth. Anyway, I tried using DC wire on a stereo install, but electrons kept leaking out and getting all over my nice WeatherTech floor liners. Link to comment Share on other sites More sharing options...
rao Posted April 5, 2011 Share Posted April 5, 2011 Is it possible that the sway bar smoothed out the idle? I apologize in advance if this post is seen as "trolling" Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted April 5, 2011 Share Posted April 5, 2011 http://www.zerosports.co.jp/shop/images/1033001_2.jpg Ah, now it all makes sense! [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
snow05gtRI Posted April 5, 2011 Share Posted April 5, 2011 hahaha. what is the product in that link? has some sort of blue box that i dont know what it's doing. Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted April 5, 2011 I Donated Share Posted April 5, 2011 Mweiner , I guess the difference in ac/dc wiring you mentioned explains why my home wording is like a single copper strand vs. The stuff I use on the cars which is a multi-strand. I can't believe o never put 2 & 2 together Thanks for the info Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted April 6, 2011 Share Posted April 6, 2011 hahaha. what is the product in that link? has some sort of blue box that i dont know what it's doing. It appears to be a sort of JDM engineered grounding module. [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
forayzor Posted April 11, 2011 Share Posted April 11, 2011 first of all, your not being productive to this thread whatsoever. secondly, everything electrical has a operating voltage, most car electronics fall under the 10-16 volt range, so anything less will shut it off and anything more will put it it protect mode if the product has it. as for what voltage is acceptable is completely up to the person, i personally don't settle for any dimming period, which is why i have a h.o. alternator with the proper gauge wire, and the batteries to go along with it. if someone wants to tolerate dimming(voltage drop) that's ultimately up to them. and yes obviously 24volt systems are superior and is why cars are starting to be 24volt or 36. it cuts the current needed drastically so you dont have to use thicker gauge wire or go to can wires like all new cars are so they can cut down on how many wires the car needs to send voltage and/or communication to bcm/pcm, etc. voltage fluctuations are only normal if you have a completely unmodified car electrically speaking which is also iffy because factory alternators run at generally 85% of its full output so adding anything aftermarket or turning on all accy's in the car on such as ac, headlights, hazards, stereo, etc on will also cause fluctuations. and before you say anything as well, upgrading you grounds and power cable from the alternator will only do so much because the alternator only produces so much. BUT it WILL cause less voltage drop significantly than not doing it at all. there are too many scenarios and every car and electrical load is different so you cant just be ignorant to everything. everything i just stated is proven and backed up by any credible company or testing facility, like UL or MECP or ASE or ICAR, etc. you pick. you can go all day because i can keep explaining facts all day too. just out of curiosity, what cars have you encountered that are running a 24volt or 36volt system? Link to comment Share on other sites More sharing options...
