dudeondacouch Posted February 9, 2011 Share Posted February 9, 2011 IBtheop'swifeblewhisenginebydrivingthecarwithoutchanginggears? Link to comment Share on other sites More sharing options...
joeleodee Posted February 9, 2011 Share Posted February 9, 2011 IBtheop'swifeblewhisenginebydrivingthecarwithoutchanginggears? That's racist. Link to comment Share on other sites More sharing options...
SneakyFast Posted February 9, 2011 Share Posted February 9, 2011 I thought you were a man and wanted to be turned into a woman, but nobody would help you with that. Says a guy that drinks orange juice through a straw... Link to comment Share on other sites More sharing options...
joeleodee Posted February 9, 2011 Share Posted February 9, 2011 Actually, it's more economical to buy the gallon carton and pour it into a glass. No straw necessary. But I applaud the cross-thread burn effort. loud Link to comment Share on other sites More sharing options...
mikeislord Posted February 9, 2011 Share Posted February 9, 2011 Don't listen to any of these guys OP. It's actually quite easy to do. 1) Buy the VF40 turbo. Used is a better bet. If you're buying new, I recommend a VF52. They are plug and play but spool better. You can get one from plenty of vendors on here. 2) Between the intake box and throttle body, cut a 12" gap. Insert the turbo here. Zip ties are more than sufficient to hold that sucker in place. 3) After that, turn the key to POWER ON, three times, until you hear the beep. The car's ECU is now ready for a command. At that point, lean down towards the passenger side of the dash and whisper "woosh." Your car is now ready for turbo powah. Link to comment Share on other sites More sharing options...
RuskiTrombone Posted February 9, 2011 Share Posted February 9, 2011 Link to comment Share on other sites More sharing options...
SneakyFast Posted February 9, 2011 Share Posted February 9, 2011 http://www.tweak3d.net/forums/imagehosting/34514b5b4b8f83919.gif Link to comment Share on other sites More sharing options...
rock2534 Posted February 9, 2011 Share Posted February 9, 2011 scratch all the mods you listed, all you need is this !!! http://photoshopcontest.com/images/large/8r3doaxza2vy7oqmuim1ke2mh7c3pvvnenuk.jpg Are those network cables?? OP-I am sure you can see the overall sentiment of this thread would be to save yourself the money/headaches and just keep what you have for now. Link to comment Share on other sites More sharing options...
Madjik_Man Posted February 9, 2011 Share Posted February 9, 2011 Don't listen to any of these guys OP. It's actually quite easy to do. 1) Buy the VF40 turbo. Used is a better bet. If you're buying new, I recommend a VF52. They are plug and play but spool better. You can get one from plenty of vendors on here. 2) Between the intake box and throttle body, cut a 12" gap. Insert the turbo here. Zip ties are more than sufficient to hold that sucker in place. 3) After that, turn the key to POWER ON, three times, until you hear the beep. The car's ECU is now ready for a command. At that point, lean down towards the passenger side of the dash and whisper "woosh." Your car is now ready for turbo powah. http://i65.photobucket.com/albums/h218/madjik_man/Funny%20Animated%20Gifs/kevthumb.gif Link to comment Share on other sites More sharing options...
MatsuDano Posted February 9, 2011 Share Posted February 9, 2011 Successful troll is successful. It's a good way to break up my 13 hour day at work though. Link to comment Share on other sites More sharing options...
aziankingz Posted February 9, 2011 Share Posted February 9, 2011 wow you guys got trolled badly haha.. Link to comment Share on other sites More sharing options...
dudeondacouch Posted February 9, 2011 Share Posted February 9, 2011 wow you guys got trolled badly haha.. 1. STFUup n00b. 2. I'm pretty sure everyone in here after the first few replies was well aware it was a troll effort, which your post also may be. If so, you could have at least added an amusing/offensive image. If not, you just fail. Link to comment Share on other sites More sharing options...
katalyst Posted February 9, 2011 Share Posted February 9, 2011 hahahaha such an amusing thread. ruskibear's post in particular cracked me up good. OP, have you taken the time reading the FAQ that i wrote up in regards to the mods available for the 2.5i in the normally aspirated section? it would be a good place to start and gather some more information. Link to comment Share on other sites More sharing options...
Madjik_Man Posted February 9, 2011 Share Posted February 9, 2011 you could have at least added an amusing/offensive image. http://i65.photobucket.com/albums/h218/madjik_man/Funny%20Animated%20Gifs/gifbinrobertfagot.gif Link to comment Share on other sites More sharing options...
dudeondacouch Posted February 10, 2011 Share Posted February 10, 2011 ^ Link to comment Share on other sites More sharing options...
RuskiTrombone Posted February 10, 2011 Share Posted February 10, 2011 loud. Link to comment Share on other sites More sharing options...
citka Posted February 10, 2011 Share Posted February 10, 2011 You guys are making this way harder than it needs to be. Step one, install this into your intake tube: http://www.mazdamaniac.com/ebayfake_files/TURBO.jpg Step two, plug it into a power supply Step three, fasten your seat belt!!! Link to comment Share on other sites More sharing options...
RuskiTrombone Posted February 10, 2011 Share Posted February 10, 2011 ^ that is much cheaper than buying a turbonator online. Nice DIY Link to comment Share on other sites More sharing options...
Madjik_Man Posted February 10, 2011 Share Posted February 10, 2011 You guys are making this way harder than it needs to be. Step one, install this into your intake tube: http://www.mazdamaniac.com/ebayfake_files/TURBO.jpg Step two, plug it into a power supply Step three, fasten your seat belt!!! Nice! My family truckster will now go from a stage -2 to atleast a stage 0! Thanks! Link to comment Share on other sites More sharing options...
dudeondacouch Posted February 10, 2011 Share Posted February 10, 2011 You guys are making this way harder than it needs to be. Step one, install this into your intake tube: http://www.mazdamaniac.com/ebayfake_files/TURBO.jpg Step two, plug it into a power supply Step three, fasten your seat belt!!! Since when do people who mod their car in this fashion wear seat belts? Link to comment Share on other sites More sharing options...
SneakyFast Posted February 10, 2011 Share Posted February 10, 2011 If I install the fan backwards on my GTO, will it make it more fuel efficient? Link to comment Share on other sites More sharing options...
drewmanman3 Posted February 10, 2011 Share Posted February 10, 2011 i feel bad for the OP he disappeared. you guys legitimately scared him off. i jus hope he realizes that everyone here is right when they say its retarded to try. it jus is not worth the money or the work. you could easily mod a gt with the extra money. turbo a beetle or a 240 or something cheap instead of trying to turbo something with sophistication when theres already a turbo'd model out. Link to comment Share on other sites More sharing options...
bsquarewi Posted February 10, 2011 Share Posted February 10, 2011 Serious question here.... Obviously the "trade and buy a GS" is the easiest and (on the surface) least expensive way to go but what about a couple of other factors. Let's say the AVO kit costs $3200.. 1. Later model GT's aren't exactly easy to find (08, 09) and when they do they are at least 3k or more than a 2.5i which are readily found (at least here in the mid-west) 2. Insurance costs. If the OP is a Male 20something then there may be a significant insurance difference insuring a 2.5i vs. GT Turbo. The diff could be hundreds of $$'s per year. Would buying a 2.5i and putting the AVO kit in it still be insured as a 2.5i? Seriously, I don't know, I'm asking. If so, all of a sudden, the AVO kit looks like it could earn it's price back over the years in insurance costs alone. not advocating or looking at doing anything like this myself, I'm genuinely curious about the insurance implications of turboing a non-turbo car like the 2.5i. Link to comment Share on other sites More sharing options...
Gire Posted February 10, 2011 Share Posted February 10, 2011 By that rationale, a 2.5i buyer would realistically have to own the car with the aftermarket AVO kit installed for 10 years. my insurance is 120 per month. a 2.5i would be about 80 bucks a month. 460 savings per year. Having a garage install this thing and getting it tuned and working right would be 8-10 hours I'm figuring... needs to be considered in the price of that kit. And what does the AVO kit gain a 2.5i driver? 80hp gain would be a 50% increase in power, but that would only get an N/A Legacy to stock LGT power levels. It ain't worth it... not considering a 2005 LGT with less than $1000.00 in go-fast parts will get you a safe 280+HP (and a shit-load of TQ), which you could run for years and years... like I have. Link to comment Share on other sites More sharing options...
boymk123 Posted February 10, 2011 Share Posted February 10, 2011 Serious question here.... Obviously the "trade and buy a GS" is the easiest and (on the surface) least expensive way to go but what about a couple of other factors. Let's say the AVO kit costs $3200.. 1. Later model GT's aren't exactly easy to find (08, 09) and when they do they are at least 3k or more than a 2.5i which are readily found (at least here in the mid-west) 2. Insurance costs. If the OP is a Male 20something then there may be a significant insurance difference insuring a 2.5i vs. GT Turbo. The diff could be hundreds of $$'s per year. Would buying a 2.5i and putting the AVO kit in it still be insured as a 2.5i? Seriously, I don't know, I'm asking. If so, all of a sudden, the AVO kit looks like it could earn it's price back over the years in insurance costs alone. not advocating or looking at doing anything like this myself, I'm genuinely curious about the insurance implications of turboing a non-turbo car like the 2.5i. They have a special section for modified car.. if your insurance doesnt have one, dont assume they will insure u. Once u have an accident and find out u have a modified (not as described as in the contract), they won't pay u a dime.. This is from my past experience. I went to a GT from an impreza 2.5i and leg 2.5i, I do know the pain, understand the enviness whenever I saw a real GT, but it's not worth it to buy the 2.5i and upgrade it or even the 2.5i itself at the first place if u dont seriously need the AWD system (I live in Boston) I rather get myself a real GT and let all the 2.5i envy Good luck modifying.. BTW, its 4pm, this thread has really made my day:lol: Link to comment Share on other sites More sharing options...
