psucaptainkickass Posted January 15, 2014 Share Posted January 15, 2014 hmmmmm I don't remember seeing one for Md. I searched the recalls here: http://www.cars101.com/recalls.html#outback/legacy I found one that was spot on, but it was for 2002-2003 WRXes. Seems like we have the same problem, but no official recall was issued. Sucks. Link to comment Share on other sites More sharing options...
c-lo Posted January 22, 2014 Share Posted January 22, 2014 course it was like 5 deg out this morning. wooooo!! man did my car smell when I opened it up while it sat to warm up. found turning the recirc off helped. 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
XT_racer Posted January 27, 2014 Share Posted January 27, 2014 man i have the same problem, I tightened the clamp last winter and it solved the problem. But then it came back again this year so i replaced the hose section and 2 new clamps. But the problem still persists in another area, that i or my mechanic cant find after 3 trips to the garage! Link to comment Share on other sites More sharing options...
Max Capacity Posted January 27, 2014 Share Posted January 27, 2014 You may have to lift the intake manifold and flip it over to find the leaking clamp. http://i185.photobucket.com/albums/x40/92Si/DSCN4748.jpg 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
D-VO Posted January 27, 2014 Share Posted January 27, 2014 Does anyone have a parts list for the GT motors on all three hoses? Link to comment Share on other sites More sharing options...
D-VO Posted January 27, 2014 Share Posted January 27, 2014 http://i.imgur.com/wemGOdC.jpg These are the offending clamps. Link to comment Share on other sites More sharing options...
emosound Posted January 28, 2014 Share Posted January 28, 2014 Just go to the auto parts store and buy a length of 5/16" (7.9mm) Fuel INJECTION hose and fuel injection clamps. Note that regular "fuel hose" is not for fuel injection pressures. Naturally, the good stuff is more expensive. Link to comment Share on other sites More sharing options...
HDTurbo Posted January 28, 2014 Share Posted January 28, 2014 No. Will keep the DD in the above freezing garage and let the spec b sit in the deep freeze. Maybe I'll yank the manny in the spring when I plan to update the "blue T" with TurkeyLord's barb-u-lator.... You may have to lift the intake manifold and flip it over to find the leaking clamp. http://i185.photobucket.com/albums/x40/92Si/DSCN4748.jpg Link to comment Share on other sites More sharing options...
foxracern11 Posted January 28, 2014 Share Posted January 28, 2014 I recently heard about the fuel sending unit seals go bad! Maybe with this cold they are shrinking witch it creating the vapor. Shouldn't be the reason for decrease in gas milledge cause it would have to be a good leak. Just a thought didn't tear it open yet still stumped Link to comment Share on other sites More sharing options...
Adoniram Posted November 26, 2014 Share Posted November 26, 2014 Can anyone attest to how much of a PITA it is to remove the intake manifold? Do I need to get new gaskets or is it like the IC where the gaskets generally maintain good seals? Link to comment Share on other sites More sharing options...
Max Capacity Posted November 26, 2014 Share Posted November 26, 2014 Its a little job. I talk about it in my click here link in my sig. I removed the whole thing as a unit. You'll need to drain some of the coolant. remove the turbo coolant tank. tmic, leave the hose on the TB. Fuel lines from the shock tower. 8 bolts, four on wither side for the TGV's to head a few electrical connectors and vacuum hoses. While its off repalce the o-rings between the intake and TGV's. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
