IceCold81 Posted December 21, 2012 Share Posted December 21, 2012 LGT = Thirsty... End of story I've concluded Link to comment Share on other sites More sharing options...
Tooslick Posted January 13, 2013 Share Posted January 13, 2013 I've had very low oil consumption (less than a quart every 10,000 miles), with the Amsoil 10w-30/ATM, Signature Series oil in both my Subaru's and my Audi TT turbo (1.8L/225 Hp). The NOACK volatility of the 10w-30 (5.3%) is significantly lower than either their 5w-30 (6.9%) or 5w-40 European Formula (7.4%). NOACK volatility correlates well with oil consumption in actual service, within a particular SAE grade. It is a much better predictor of oil consumption than using the flashpoint. In a high mileage, worn engine it may be preferable to go up to a 5w-40 or 10w-40 synthetic however. The thicker oil will provide a better piston ring seal in these older engines which will mitigate both excessive oil consumption and fuel dilution. TS Link to comment Share on other sites More sharing options...
bluesubie Posted January 15, 2013 Share Posted January 15, 2013 I've had very low oil consumption (less than a quart every 10,000 miles), with the Amsoil 10w-30/ATM, Signature Series oil in both my Subaru's and my Audi TT turbo (1.8L/225 Hp). The NOACK volatility of the 10w-30 (5.3%) is significantly lower than either their 5w-30 (6.9%) or 5w-40 European Formula (7.4%). NOACK volatility correlates well with oil consumption in actual service, within a particular SAE grade. It is a much better predictor of oil consumption than using the flashpoint. In a high mileage, worn engine it may be preferable to go up to a 5w-40 or 10w-40 synthetic however. The thicker oil will provide a better piston ring seal in these older engines which will mitigate both excessive oil consumption and fuel dilution. TS Doesn't the TT require a VW 502 oil with a HTHS of 3.5 or higher? I haven't run anything lower than 3.5 in my FXT since my turbo failure. ATM sounds like a great oil! The new Amsoil Euro 5W-40 EFM sounds like it has a nice, manly additive package. It's cheaper than AFL and the NOACK isn't as good so I presume the AFL is made with better base stocks, but the AFL has a lower TBN and is lower SAPS. I did have high consumption with a low NOACK Red Line 5W-30. Two quarts in 5k miles but it was my first run and I didn't continue using it. -Dennis Link to comment Share on other sites More sharing options...
Tooslick Posted January 16, 2013 Share Posted January 16, 2013 Dennis, The new Amsoil European oil (EFMQT), looks to be predominately a Group III, "hydroisomerized" base stock. (Fine for a N/A Subie engine, but not my first choice for a turbo.) An even better (albeit more expensive), Amsoil product would be the 5w-40, Premium Synthetic diesel oil ("DEO"). This oil is now an API Licensed, CJ-4/SN formulation, so it meets the latest specs for gas engines. This includes improved compatibility with gas containing ethanol; up to and including E85. TS Link to comment Share on other sites More sharing options...
