BAC5.2 Posted September 3, 2010 Share Posted September 3, 2010 Sears charged my wife and I (then girlfriend) $60 to take her Passat from mostly green to all red on the printout. I made them give us our money back. Worst case scenario, take the car to a Subaru dealer. The ones in MD that I know of all have laser-equipped Hunter Alignment Racks. A monkey can do a halfway decent alignment on one of those. I do my own alignments on an older Hunter rack with amazing results. All it takes is time. Find a technician who cares, and it'll get done right. You could also check the Cali section of Nasioc for recommendations. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
OhBe1 Posted September 4, 2010 Share Posted September 4, 2010 Annapolis Subaru seems performance-oriented. Maybe I'll try them next time. 06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest. Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted September 4, 2010 Mega Users Share Posted September 4, 2010 I don't know of any up there, but a good tip is to search the forums for tire shops that are involved in autoX or something similar. If they know how to set up a car for any kind of race, then they should know what they are doing. Link to comment Share on other sites More sharing options...
rixstark Posted September 24, 2010 Share Posted September 24, 2010 I am about to do the same swap this weekend. I have KYB Gr2 Legacy GT struts and brand new Stock OEM Legacy GT springs. I also got the LGT rear bumpstops. Does anyone know if the front strut bumpstops are a different part number from the LGT to the OBXT? If not the same, are they just shorter? How much shorter? Also, I have 18x8 rims with 48mm offset. Has anyone that has done this swap use these rim dimensions? Can I use 235/45/18 tires? What about 245/45/18? Will they fit under the LGT perch in the front? Alot of questions I know, thanks in advance to anyone that has had these experiences and can share. Link to comment Share on other sites More sharing options...
ssbtech Posted September 24, 2010 Share Posted September 24, 2010 (edited) Someone was talking about the Spec B suspension being the same height as the regular Legacy suspension. Are the spring perches in the same position? Would it be possible to put Spec B sedan suspension on the Outback? I seem to recall the back sitting lower with the Spec B suspension too... Edited September 25, 2010 by ssbtech Link to comment Share on other sites More sharing options...
Duffman Posted September 28, 2010 Author Share Posted September 28, 2010 outbackxt05, I went to my local Subi dealer for the alignment. Have you gotten your alignment done yet? Rix, 235 will be pushing it, let alone 245. Not sure how it will be with your wheels and offset though. The standard 225/45 17's for the outback are REALLY close to the front spring perches as it is. ssbtech, you'd need a different rear setup from the Specb anyway since the specB is sedan only. (someone correct me if i'm wrong) Unless you have an outback sedan of course. Link to comment Share on other sites More sharing options...
rixstark Posted October 2, 2010 Share Posted October 2, 2010 Duff, The stock tire size is 225/55-17. The 225/45-18's are .75" smaller in rolling diameter at the same width as stock. 235/45-18's are .5" smaller and a little wider. I put my hand behind the tire when the 225/45-18's were installed and felt all kinds of room to the perch above the tire and all the way down the perch to the strut itself. 235's will be fine. They will be my next size. 245's might be too clozse and not worth the risk.....although they are very, very close to the stock rolling diameter. Link to comment Share on other sites More sharing options...
Duffman Posted October 2, 2010 Author Share Posted October 2, 2010 yeah sorry, I had 225/45's on my GTI. not used to saying 225/55 yet lol. Link to comment Share on other sites More sharing options...
Scooby2.5 Posted October 2, 2010 Share Posted October 2, 2010 245 45 18's fit fine with 48 offset there has been quite a few on the forum that have done it. Link to comment Share on other sites More sharing options...
OutbackXT05 Posted October 7, 2010 Share Posted October 7, 2010 No alignment yet. Been a bit busy lately but this week end itll get done. I am happy with the swap overall and I know once the alignment it done itll be a lot better. The rears are noticeabley toed in. Dont need to measure it to see it. So i know thats my main problem. It has mellowed out though so im looking forward to getting it all lined up. Link to comment Share on other sites More sharing options...
Duffman Posted October 8, 2010 Author Share Posted October 8, 2010 Get that done! asap! Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted October 8, 2010 Mega Users Share Posted October 8, 2010 +1 hurry. You are eating up your rear tires with the toe if you can see it. Link to comment Share on other sites More sharing options...
05 Outback 2.5i Posted October 8, 2010 Share Posted October 8, 2010 Does anyone know if the front strut bumpstops are a different part number from the LGT to the OBXT? If not the same, are they just shorter? How much shorter? '20501AE00A is the part number for the rear bump stops' From This Thread, there is a picture as well.. __________________ ~Scott '05 Outback 2.5i Wagon Willow Green Opal/ Moss Green Metallic 225/60HR16 Bridgestone G009's Link to comment Share on other sites More sharing options...
Shotokan1509 Posted October 9, 2010 Share Posted October 9, 2010 http://i4.photobucket.com/albums/y142/ForceFedGTI/Cars/IMG_0155.jpg Please tell me you are not using the factory jack like a jack stand Link to comment Share on other sites More sharing options...
Duffman Posted October 9, 2010 Author Share Posted October 9, 2010 No, it is on regular jack stands farther towards the front of the car. The factory jack is just holding the spindle up. Link to comment Share on other sites More sharing options...
Shotokan1509 Posted October 9, 2010 Share Posted October 9, 2010 No, it is on regular jack stands farther towards the front of the car. The factory jack is just holding the spindle up. Ok good, I've seen worse but was hoping in this case it was just out of view. Pocono Pines eh? I'm over in Albrightsville a couple times per winter. That's when I'm looking for more ground clearance. http://inlinethumb13.webshots.com/45644/2431625760052327601S600x600Q85.jpg Link to comment Share on other sites More sharing options...
Duffman Posted October 9, 2010 Author Share Posted October 9, 2010 lol, yeah, I did this mod before I knew we were moving here lol...we were in Arkansas Link to comment Share on other sites More sharing options...
BAC5.2 Posted October 9, 2010 Share Posted October 9, 2010 245 45 18's fit fine with 48 offset there has been quite a few on the forum that have done it. What wheel width? I want, desperately, to run a 245/55/17 on STi BBS rims. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
Shotokan1509 Posted October 10, 2010 Share Posted October 10, 2010 (edited) lol, yeah, I did this mod before I knew we were moving here lol...we were in Arkansas I was driving behind an Outback sedan a couple days ago and it got my mind spinning on how awesome that would be for winter setup. I went from my truck being the ski beast with more ground clearance, deeper lug tires, and steel bumper to the Leggy that I have to think about that snow plow mound, and the pretty paint. Hope you like snow! This was last year, after it had settled... and yes I had to dig two vehicles worth, by hand, because my friends wrist was broken. Theres still like 4" packed under my car, and his Infiniti is ramped up on probably 8". http://inlinethumb18.webshots.com/8721/2663879170052327601S600x600Q85.jpg Edited October 10, 2010 by Shotokan1509 Link to comment Share on other sites More sharing options...
Shotokan1509 Posted October 10, 2010 Share Posted October 10, 2010 seriously? I havent doubleposted in years, feel like such a noob. Mod comes through can delete this. Link to comment Share on other sites More sharing options...
SubOperator Posted October 11, 2010 Share Posted October 11, 2010 lol, yeah, I did this mod before I knew we were moving here lol...we were in Arkansas Don't worry about the clearance, I don't have issues with my LGT on STI pinks which drops it 1cm lower from stock. You might want to get some winter tires though. 2005 LGT Wagon Limited 6 MT RBP Stage 2 - 248K 2007 B9 Tribeca Limited DGM - 258K SOLD - 2005 OB Limited 5 MT Silver - 245K SOLD - 2010 OB 6 MT Silver - 205K Link to comment Share on other sites More sharing options...
hollendtino Posted October 14, 2010 Share Posted October 14, 2010 Hey I would like to do the opposite with my 05 GT I would like to swap out the GT susp and put the outback struts in. Has anyone done this or know anyone who has? Is it possible? Looking for some clues? Would greatly appreciate it. Thanks Link to comment Share on other sites More sharing options...
hollendtino Posted October 14, 2010 Share Posted October 14, 2010 I would like to have the clearance and the turbo to go off road and play Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted October 14, 2010 Mega Users Share Posted October 14, 2010 hollentino, just understand that unless you go aftermarket, there will be a significant loss of handling. You would need OB springs as well. Link to comment Share on other sites More sharing options...
Scooby2.5 Posted October 14, 2010 Share Posted October 14, 2010 Hey I would like to do the opposite with my 05 GT I would like to swap out the GT susp and put the outback struts in. Has anyone done this or know anyone who has? Is it possible? Looking for some clues? Would greatly appreciate it. Thanks I wouldnt recommend it, the outback suspension is way under damped, and it floats all over the road even when new. Maybe if you could find aftermarket shocks and struts it would be good but not stock. If it is height you want get the BC/BR coilovers made for outback (only difference is the have longer shock cartridges) and you can go stock lgt height or outback height whenever you want. Link to comment Share on other sites More sharing options...
