Moderators BarManBean Posted July 12, 2013 Moderators Share Posted July 12, 2013 Looks like the same clearance I get for the same tire size and offset with the LGT swap on my OBXT. Pictures are a few pages back post #151. Your pic in post #151 is with bilsteins, correct? Not just regular LGT suspension? They look to be yellow, but maybe that's just the camera. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Sideways the Seven Posted July 12, 2013 Share Posted July 12, 2013 Wondered the same thing, but I'm pretty sure they're Bils. Sent from my SGH-T699 using Tapatalk 2 -Brandon 2007 Chevrolet Suburban LT3 1981 Chevrolet C10 LWB Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted July 12, 2013 Moderators Share Posted July 12, 2013 There's a guy that's somewhat local to me that has a set of 245/45s mounted up right now, need to make the time to meet up with him and test fit them with my tokicos...curious to see how the perch on them sits... bleh, no time! "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Sideways the Seven Posted July 12, 2013 Share Posted July 12, 2013 Tokicos are OEM LGT spec, correct? Or am I confusing them with the KYBs? -Brandon 2007 Chevrolet Suburban LT3 1981 Chevrolet C10 LWB Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted July 12, 2013 Moderators Share Posted July 12, 2013 Tokicos are OEM LGT spec, correct? Or am I confusing them with the KYBs? Tokicos are lgt spec, yes--but technically so are bilsteins, konis, and kybs. The fact that the perches on the bilsteins are a bit higher is recent news to me and many others. Konis are installed in a stock housing, so the perch will obviously be stock. Tokicos are sold as a full bolt on strut w/ housing, so I'm not sure where my perches line up in terms of stock / bilstein location. Tokicos are also adjustable like konis, although konis only adjust dampening where the tokicos adjust dampening and compression, though not independently (i believe...) "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Sideways the Seven Posted July 12, 2013 Share Posted July 12, 2013 Ah, good to know. Thanks for making me look into another suspension option now! Lol Sent from my SGH-T699 using Tapatalk 2 -Brandon 2007 Chevrolet Suburban LT3 1981 Chevrolet C10 LWB Link to comment Share on other sites More sharing options...
whitetiger Posted July 12, 2013 Share Posted July 12, 2013 Tokicos are lgt spec, yes--but technically so are bilsteins, konis, and kybs. The fact that the perches on the bilsteins are a bit higher is recent news to me and many others. Konis are installed in a stock housing, so the perch will obviously be stock. Tokicos are sold as a full bolt on strut w/ housing, so I'm not sure where my perches line up in terms of stock / bilstein location. Tokicos are also adjustable like konis, although konis only adjust dampening where the tokicos adjust dampening and compression, though not independently (i believe...) it depends if tokicos require spec b top hats or lgt top hats. if spec b top hats, then they should also have the higher perch like bilsteins, but i dont think that is the case. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted July 12, 2013 Moderators Share Posted July 12, 2013 they do use spec.b hats. I am excite! "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted July 12, 2013 Moderators Share Posted July 12, 2013 That almost makes it sound like in a sense the konis are adjustable LGT/KYB struts while the tokicos are adjustable spec.b/bilsteins. I know that's not going to be entirely accurate in terms of behavior, but in terms of shape / size / spring perch it sounds like that's a possibility. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Sideways the Seven Posted July 12, 2013 Share Posted July 12, 2013 Very interesting! Where can I find the Tokicos? Sent from my SGH-T699 using Tapatalk 2 -Brandon 2007 Chevrolet Suburban LT3 1981 Chevrolet C10 LWB Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted July 12, 2013 Moderators Share Posted July 12, 2013 On my car Here's a thread about them: http://legacygt.com/forums/showthread.php/tokico-hts-d-spec-struts-05-legacy-gt-great-strut-96832.html They came on my car from the previous owner. I'm sure I could find out where he bought them from. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Sideways the Seven Posted July 12, 2013 Share Posted July 12, 2013 Just read the thread. Definitely want more info on those! Sent from my SGH-T699 using Tapatalk 2 -Brandon 2007 Chevrolet Suburban LT3 1981 Chevrolet C10 LWB Link to comment Share on other sites More sharing options...
whitetiger Posted July 12, 2013 Share Posted July 12, 2013 That almost makes it sound like in a sense the konis are adjustable LGT/KYB struts while the tokicos are adjustable spec.b/bilsteins. I know that's not going to be entirely accurate in terms of behavior, but in terms of shape / size / spring perch it sounds like that's a possibility. yes that sounds accurate size/shape wise. to confirm this, if are able to measure from the bottom of the strut to the bottom of the spring perch, along the body, of you tokicos, then i or someone can measure the bilsteins and we can compare. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted July 12, 2013 Moderators Share Posted July 12, 2013 I should be able to pull a wheel off and do that without much trouble. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Sideways the Seven Posted July 12, 2013 Share Posted July 12, 2013 Awaiting results. What's the take on Epic Springs vs Tein H-Tech? -Brandon 2007 Chevrolet Suburban LT3 1981 Chevrolet C10 LWB Link to comment Share on other sites More sharing options...
dschultz Posted July 12, 2013 Share Posted July 12, 2013 (edited) Your pic in post #151 is with bilsteins, correct? Not just regular LGT suspension? They look to be yellow, but maybe that's just the camera.As stated, I have OEM LGT suspension. I put Koni inserts in them but otherwise they are stock LGT. The yellow colour is a feature of the previous owner of the stocks (he painted them). Edited July 12, 2013 by dschultz Link to comment Share on other sites More sharing options...
Sideways the Seven Posted July 12, 2013 Share Posted July 12, 2013 Interesting. I know wheel specs have a lot to do with it, but I'm really surprised it doesn't rub. -Brandon 2007 Chevrolet Suburban LT3 1981 Chevrolet C10 LWB Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted July 12, 2013 Moderators Share Posted July 12, 2013 As stated, I have OEM LGT suspension. I put Koni inserts in them but otherwise they are stock LGT. The yellow colour is a feature of the previous owner of the stocks (he painted them). Well there ya go. Cool "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Sideways the Seven Posted July 16, 2013 Share Posted July 16, 2013 Just as an FYI, I had BC coilovers on my OBXT. I used the model spec'd for a LGT. I had no problem reaching a decent ride height with them. But in doing so left only a few inches of travel which does not work well on public roads. When I switched to the LGT OEM suspension with the Koni inserts I found the stock LGT spring rate to soft or the spring too short. So I removed them and put the OBXT stock springs in. So what I have now is LGT bodies, Koni inserts and OBXT springs. This is the best setup I've tried on my car. Hmm... You've got me thinking again. This might be worth a shot. -Brandon 2007 Chevrolet Suburban LT3 1981 Chevrolet C10 LWB Link to comment Share on other sites More sharing options...
arthurj Posted July 16, 2013 Share Posted July 16, 2013 These tires are spec'd for mounting on 7.5" as the minimum wheel width. I snapped some pictures for you so you can see the clearances. With stock OBXT suspension you will have more tire height to spring perch clearance. Even an 8" or 8.5" wheel with the proper offset would still clear as the tire is wider than the wheel as you can see. What I suggest is that you find a tire shop willing to order in your chosen wheel and test fit it for you at no cost. That is what I did, because of my brakes and the shop could return the wheels to the supplier if they didn't fit and were not mounted. Pictures: Komodo (18x7.5 +45) by Fastwheels OEM stock LGT suspension (painted yellow by previous LGT owner) Tires Falken FK-452 245/45-18 Thanks for the pic showing OB sized tires using Legacy strut housings. Reading thru this topic and other postings, I see you are at 15 3/8" front and 15 1/4" rear from hub to fender lip, correct? That would make you 2" lower then OEM OB ride height and still using OB sized tires? I wounder if I could make a 2" saggy butt spacer to get back to OEM OB ride height. Link to comment Share on other sites More sharing options...
dschultz Posted July 17, 2013 Share Posted July 17, 2013 Thanks for the pic showing OB sized tires using Legacy strut housings. Reading thru this topic and other postings, I see you are at 15 3/8" front and 15 1/4" rear from hub to fender lip, correct? That would make you 2" lower then OEM OB ride height and still using OB sized tires? I wounder if I could make a 2" saggy butt spacer to get back to OEM OB ride height. I suppose you could. What would you do up front though? Post #54 has the OEM specs. Link to comment Share on other sites More sharing options...
dschultz Posted July 17, 2013 Share Posted July 17, 2013 Hmm... You've got me thinking again. This might be worth a shot. Are you referring to the LGT/Koni setup or my old BC Racing coilovers (post #59)? Link to comment Share on other sites More sharing options...
Sideways the Seven Posted July 17, 2013 Share Posted July 17, 2013 Are you referring to the LGT/Koni setup or my old BC Racing coilovers (post #59)? Koni w/OB springs. Just not sure I want the height Sent from my SGH-T699 using Tapatalk 2 -Brandon 2007 Chevrolet Suburban LT3 1981 Chevrolet C10 LWB Link to comment Share on other sites More sharing options...
whitetiger Posted July 18, 2013 Share Posted July 18, 2013 the car will be lower regardless of the spring used. the OB ride height is not from the springs, but from the extended shock bodys. so if you run konis in LGT bodys, the OB will be 2" lower even with OB springs. Link to comment Share on other sites More sharing options...
frank_ster Posted August 23, 2013 Share Posted August 23, 2013 whats the thead on the bumpstop for the rear ? m10 or m8 ? Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
