Yebbey Posted January 3, 2011 Share Posted January 3, 2011 sorry, i didn't read the coupon either. Link to comment Share on other sites More sharing options...
Mortal2None Posted April 23, 2011 Share Posted April 23, 2011 I'm guessing by Whitetiger's car info the front LSD works? Sorry just found this now. What about the VTD on the 5EAT's? Will this mod interfere with that functionality? Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted April 23, 2011 Author Share Posted April 23, 2011 I have the prototype, just need to install it for the next round of trans swappage. It should work very well with the LGT powertrain. [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
bill harvey Posted April 23, 2011 Share Posted April 23, 2011 this makes me miss my old front lsd i had in my 98 rs turbo but that one was better because brett from MRT sent it to me as a gift Link to comment Share on other sites More sharing options...
Leonardo Posted April 24, 2011 Share Posted April 24, 2011 I'm guessing by Whitetiger's car info the front LSD works? Sorry just found this now. What about the VTD on the 5EAT's? Will this mod interfere with that functionality? His is a 5MT! Link to comment Share on other sites More sharing options...
Mortal2None Posted April 24, 2011 Share Posted April 24, 2011 His is a 5MT! I saw that in WT's other thread. Bummer Link to comment Share on other sites More sharing options...
Leonardo Posted June 24, 2011 Share Posted June 24, 2011 Updates?? Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted June 24, 2011 Author Share Posted June 24, 2011 Aiming to install this Sunday & Monday At some point my dream of really launching Hexagram Modifications came true. One of my statements was that the STOCK 5eat could be made to handle 400whp/wtq with ease. So I'm going to swap this front LSD into the STOCK transmission. Excited to see how it performs. [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
ean611 Posted June 24, 2011 Share Posted June 24, 2011 If you have the parts and the instructions (and it works), this is something I would love to install. Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted June 30, 2011 Author Share Posted June 30, 2011 My torque-sensing front LSD is installed! I just need traffic to clear out so I can go test it. It was not easy to install, but it was straight-forward per the instructions. Fits like a glove! [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
fishbone Posted July 1, 2011 Share Posted July 1, 2011 Drop-in fitment? Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted July 1, 2011 Author Share Posted July 1, 2011 Drop-in fitment? You have to follow the procedure in the FSM. You have to set the load by screwing in/out the two caps that the axle shafts go through. This requires a special tool, which I made out of an oil filter removal cap. These caps hold the oil seal and the bearing seat. My new press-on bearings for the new diff were different than the bearings on the stock diff. This means the bearing seat in each cap had to be removed as well. There is a special claw tool for this, but I used a hammer and crow bar, gently! Then I gently tapped in the new seat into each of the two end caps. Set the preload per exact FSM instructions. Worked like a charm. MUST USE GREASE on the stub axles before sliding them into each end of the diff. I had to hammer tap the axles in, snug fit. The manufacturer of the diff assured me this was fine, and I tend to agree. Anyways it's been totally transparent so far, and is stock quiet (which means I didn't blatantly screw up setting it up). I don't exactly live at a race track, so I have to go looking for places to really test it out. Going to do that. But I'm not worried BECAUSE this is basically the existing 4eat LSD internals adapted to work with the 5eat fitment constraints. Fitment is great, so I think we are good to go! But let me just hammer the car some more first. I like to confirm via gas pedal [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
fishbone Posted July 1, 2011 Share Posted July 1, 2011 So, no Thanks. Let us know how it works! Link to comment Share on other sites More sharing options...
Leonardo Posted July 1, 2011 Share Posted July 1, 2011 AWESOME!!! Now go update the thread in NABISCO!! Link to comment Share on other sites More sharing options...
ean611 Posted July 1, 2011 Share Posted July 1, 2011 You have to follow the procedure in the FSM. You have to set the load by screwing in/out the two caps that the axle shafts go through. This requires a special tool, which I made out of an oil filter removal cap. These caps hold the oil seal and the bearing seat. My new press-on bearings for the new diff were different than the bearings on the stock diff. This means the bearing seat in each cap had to be removed as well. There is a special claw tool for this, but I used a hammer and crow bar, gently! Then I gently tapped in the new seat into each of the two end caps. Set the preload per exact FSM instructions. Worked like a charm. MUST USE GREASE on the stub axles before sliding them into each end of the diff. I had to hammer tap the axles in, snug fit. The manufacturer of the diff assured me this was fine, and I tend to agree. Anyways it's been totally transparent so far, and is stock quiet (which means I didn't blatantly screw up setting it up). I don't exactly live at a race track, so I have to go looking for places to really test it out. Going to do that. But I'm not worried BECAUSE this is basically the existing 4eat LSD internals adapted to work with the 5eat fitment constraints. Fitment is great, so I think we are good to go! But let me just hammer the car some more first. I like to confirm via gas pedal WANT!!! I'm very interested in getting one so Paul can install it along with your pending 08+ Shift kit!! Link to comment Share on other sites More sharing options...
Leonardo Posted August 31, 2011 Share Posted August 31, 2011 Updates? Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted August 31, 2011 Author Share Posted August 31, 2011 Yes, I need to start a group buy for a special manufacturing run of 05-09 5EAT front Torque Biasing Differentials. They are a mechanical diff, but are manufactured by Guard Transmission, not Torsen. I believe I need 5 orders minimum with deposits, and there is a lead time of several months since manufacturing the order only can begin once the group buy is firmly established. Lastly, these are not cheap. It is strictly pay to play with R160 performance differentials, more so for a custom product required by the 5eat. Pleade post here for preliminary interest. Thank you. I should also mention that FlatIronsTuning on NASIOC has exclusive rights to Guard Transmission vendor status. I have the rights to it on LegacyGT.com and OutbackXT.com. So if they also launch a Group Buy, and I get 3 and they get 2, that counts as 5, and we can move ahead with production. Their terms may be different than mine, but end sale price and delivery time will be the same. I ask you join the group buy on whichever forum or whichever vendor you wish to work with going forward, as you can only pick one. Thank you. [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
Leonardo Posted August 31, 2011 Share Posted August 31, 2011 Any preliminary guesstimate on price? Preliminary I'm in. Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted August 31, 2011 Mega Users Share Posted August 31, 2011 Outbackxt.com? Link to comment Share on other sites More sharing options...
notthesnail Posted August 31, 2011 Share Posted August 31, 2011 I'll bite for preliminary interest. But without a guesstimate, I can't say whether that's the tiniest nibble or a full chomp. Link to comment Share on other sites More sharing options...
Soda Popinski Posted August 31, 2011 Share Posted August 31, 2011 I asked the dealership to repackage my 5EAT for you. Just PM me with the shipping address Link to comment Share on other sites More sharing options...
quick4dr Posted August 31, 2011 Share Posted August 31, 2011 subscribed. Very interested in more details, as i love my HEX F1 Link to comment Share on other sites More sharing options...
lieutenantcolumbo Posted August 31, 2011 Share Posted August 31, 2011 Possibly interested as well pending cost estimate for an '05 5EAT. Guessing you'll help Jeff out at my shop if he has any questions on the install. Link to comment Share on other sites More sharing options...
AlWheelDrive Posted August 31, 2011 Share Posted August 31, 2011 Who do I send the paypal payment to? This would be a kickass mod for the nasty winter we've got coming! Link to comment Share on other sites More sharing options...
