bnguyenbb6 Posted February 27, 2012 Share Posted February 27, 2012 I was told by the previous owner of the tactrix(used can logging to his 08) that the drivers were updated. I'm contacting him now to get the license so that I can update it. The LC1 works great with my laptop. I'm starting to suspect the actual 2.5mm port on the tactrix itself. It clicks in but there I don't really see any metal leads coming out to make contact. I did get different values from the LC1 via SD card logging once but the numbers were 58 and 59 and it kept flipping between those two numbers. I'm actually in Austin. Link to comment Share on other sites More sharing options...
lordeldor Posted February 27, 2012 Share Posted February 27, 2012 I was told by the previous owner of the tactrix(used can logging to his 08) that the drivers were updated. I'm contacting him now to get the license so that I can update it. The LC1 works great with my laptop. I'm starting to suspect the actual 2.5mm port on the tactrix itself. It clicks in but there I don't really see any metal leads coming out to make contact. I did get different values from the LC1 via SD card logging once but the numbers were 58 and 59 and it kept flipping between those two numbers. I'm actually in Austin. You don't need a license to update it. It's just the name of the window. If you are using the latest version of ecuflash and it pops up to the licensing window with a text box then it is already updated. It would just start flashing the device if it wasn't updated. You can close the window and continue on without a license. One of the things I have noticed about both the 2.5mm and the usb port is that the only thing holding them in is solder. I have had to repair my usb port a few times. It is very possible the 2.5mm is damaged. I see. I'm in Houston unfortunately I never really get out to Austin. Link to comment Share on other sites More sharing options...
DeltaNu1142 Posted May 3, 2012 Share Posted May 3, 2012 I'm digging this thread up a little... I'm finding next to no documentation on doing microSD logging. I received my Tatrix OpenPort 2.0 rev E today in the mail... I've read about the log config text file, and that's all well & good... but what should be on my microSD card.... Tits mcgee Link to comment Share on other sites More sharing options...
DeltaNu1142 Posted May 3, 2012 Share Posted May 3, 2012 This is actually as helpful as anything I've found (from this thread, pg 1): LINK I'll try it tonight! Tits mcgee Link to comment Share on other sites More sharing options...
bnguyenbb6 Posted May 4, 2012 Share Posted May 4, 2012 Make sure you format your SD card to FAT32. Link to comment Share on other sites More sharing options...
DeltaNu1142 Posted May 4, 2012 Share Posted May 4, 2012 Done. Tactrix customer service advised nothing bigger than a 2GB card, so I traded my 8GB for a 2GB with a buddy, only to discover that my OP is garbage. New one on the way. Tits mcgee Link to comment Share on other sites More sharing options...
Underdog Posted May 4, 2012 Author Share Posted May 4, 2012 I've been running with an 8GB card ever since I started this thread. I have never checked any of the logs, other than to make sure they were there. The Crimson Dynamo Link to comment Share on other sites More sharing options...
DeltaNu1142 Posted May 4, 2012 Share Posted May 4, 2012 I've been running with an 8GB card ever since I started this thread. I have never checked any of the logs, other than to make sure they were there. Crap. I guess it's too late to get my 8GB card back... ehh, they're cheap. ...but has anyone really ever filled up 2GB of logs? That's a LOT of data. Tits mcgee Link to comment Share on other sites More sharing options...
bnguyenbb6 Posted May 4, 2012 Share Posted May 4, 2012 I have a 1gb, I use the standalone logging mainly for dialing in CL as my LC1 still wont feed any data. That being said, those cruise files are usually pretty big but I've never come close to even hitting 1gb. I don't have 30 min logs but still enough for over 7k lines of valid CL data. Link to comment Share on other sites More sharing options...
DeltaNu1142 Posted May 8, 2012 Share Posted May 8, 2012 Kevin @ Tactrix helped a lot. I'm going to edit out my post above, as it is not representative of the log files I've put together so far. I'm using a 2GB file & am creating a few different logcfg.txt files that I can swap in & out of the root directory as needed. Tits mcgee Link to comment Share on other sites More sharing options...
bnguyenbb6 Posted November 10, 2012 Share Posted November 10, 2012 I finally got my LC1 to feed my OP2 so I now have full standalone logging with wideband O2 . I figured out that it wont feed lambda to do the scaling calculation but it will feed AFR directly from the LC1. The only "problem" I see is that it has no upper bound after lifting so I'll see 43-130:1 AFR lol but it will show the lift in the throttle column. I'll be using it to check my tune and only using the laptop for LV's and more precise logging now. My config file: *Edit* Next post has current config file and LC1 will feed lambda but the 2.5mm cable I bought was junk. Now using a 3.5mm cable with 2.5mm adapters on both ends. Cable should "click" in or it wont push the data. Link to comment Share on other sites More sharing options...
bnguyenbb6 Posted January 5, 2013 Share Posted January 5, 2013 I know this is pretty dead and no one uses it but the site that has the parameters is working again. Standalone logging did exactly what I wanted it to do in the previous post. After doing WOT pulls everyday to work and back home, I found my AFR's dipping really rich(9.9 at peak torque, 10.2 at redline) while MAF volts were higher than usual; turned out my BOV was leaking. Daily logging No laptop, with wideband and more info than just LV's. Type your ecu into the space or use the config file creator found on openecu. If you use the program from openecu, make sure the romraider def's are in the same file as the program and run as admin. http://www.verticaltier.net/configtool/logger.php http://forums.openecu.org/viewtopic.php?f=57&t=4396 Also, Ecuflash 1.44 is out which fixed some bugs and added a few features. Here is my current config file: type=ssmk ;-------ENGINE------------- paramname = RPM paramid = 0x00000E databits = 16 scalingrpn = x,4,/ paramname = Load paramid = 0xFF5328 databits = 16 scalingrpn = x,.00006103516,* paramname = Throttle paramid = 0x000015 databits = 8 scalingrpn = x,100,*,255,/ paramname = Total_Timing paramid = 0x000011 databits = 8 scalingrpn = x,128,-,2,/ ;----------AIR FLOW------------- paramname = MAF_V paramid = 0x00001D databits = 8 scalingrpn = x,50,/ ;paramname = MAF_G/S ;paramid = 0x000013 ;databits = 16 ;scalingrpn = x,100,/ paramname = IAT paramid = 0x000012 databits = 8 scalingrpn = 32,9,x,40,-,*,5,/,+ sampgroup = 2 ;---------BOOST---------------------- paramname = MRP paramid = 0xFF5336 databits = 16 scalingrpn = x,760,-,0.01933677,* ;paramname = WGDC ;paramid = 0xFF5314 ;databits = 16 ;scalingrpn = x,.00390625,* ;paramname = MRPTarget ;paramid = 0xFF533C ;databits = 16 ;scalingrpn = x,760,-,0.01933677,* ;-----------KNOCK CONTROL------------- ;paramname = IAM ;paramid = 0xFF5355 ;databits = 8 ;scalingrpn = x,.0625,* ;paramname = FBKC ;paramid = 0xFF5350 ;databits = 8 ;scalingrpn = x,.3515625,*,45,- ;paramname = FLKC ;paramid = 0xFF5353 ;databits = 8 ;scalingrpn = x,.3515625,*,45,- paramname = Knock_Sum paramid = 0xFF5D08 databits = 8 scalingrpn = x ;----------------FUELING---------- paramname = FFB paramid = 0xFF5326 databits = 16 scalingrpn = 14.7,x,.0004882812,*,/ ;paramname = AFCorrection ;paramid = 0x000009 ;databits = 8 ;scalingrpn = x,128,-,100,*,128,/ ;paramname = AFLearning ;paramid = 0x00000A ;databits = 8 ;scalingrpn = x,128,-,100,*,128,/ ;paramname = IPW ;paramid = 0x000020 ;databits = 8 ;scalingrpn = x,256,*,1000,/ ;isvisible = 0 ;paramname = CL/OL ;paramid = 0xFF6FA5 ;databits = 8 ;scalingrpn = x,6,+ ;type=calc ;paraname = IDC ;scalingrpn = RPM,IPW,*,0.0008333333,* ;sampgroup = 2 ;-----------OTHER----------------- ;paramname = MPH ;paramid = 0x000010 ;databits = 8 ;scalingrpn = x,0.621371192,* ;paramname = Gear ;paramid = 0x00004A ;databits = 8 ;scalingrpn = x,1,+ ;sampgroup = 2 ;paramname = ECT ;paramid = 0x000008 ;databits = 8 ;scalingrpn = 32,9,x,40,-,*,5,/,+ ;sampgroup = 2 ;paramname = Misfire1 ;paramid = 0x0000CE ;databits = 8 ;scalingrpn = x ;paramname = Misfire2 ;paramid = 0x0000CF ;databits = 8 ;scalingrpn = x ;paramname = Misfire3 ;paramid = 0x0000D8 ;databits = 8 ;scalingrpn = x ;paramname = Misfire4 ;paramid = 0x0000D9 ;databits = 8 ;scalingrpn = x ;-------------TRIGGERS--------------- ;Logging activated via defogger or when throttle is > 50% paramname = defogger_sw paramid = 0x64 databits = 1 offsetbits = 5 isvisible = 0 conditionrpn = defogger_sw,1,==,Throttle,51,>=,|| action = start conditionrpn = defogger_sw,0,==,Throttle,49,<=,&& action = stop ;-----------WIDEBAND LC1--------- type=inno paramname = LC1 paramid = 0x0101 scalingrpn = x,14.7,* **note: IDC will not work unless IPW is defined. "isvisible=0" means that it will define it but not log it(I actually haven't confirmed that type= calc works). Any line with a semicolon is not seen so you can pick and choose parameters by adding in or deleting semicolons. This config file is for ECU A2WF200N with mostly 1 byte or 2 byte parameters for better resolution. Any parameter with "sampgroup = 2" was given lower priority. Link to comment Share on other sites More sharing options...
dschultz Posted January 7, 2013 Share Posted January 7, 2013 BTW: If you already have a RomRaider logging profile defined you can use this tool to convert it to an Openport 2.0 Standalone logging config file. http://www.romraider.com/forum/viewtopic.php?t=9136 Link to comment Share on other sites More sharing options...
PtPixel Posted August 21, 2013 Share Posted August 21, 2013 Geez....noob error. I had my file named as logcfg.txt.txt I just went and tested the logging while parked. Looks like it's working fine except some of the values are weird. Namely the manifold relative pressure. The values look like "63508700" Another weird thing is the engine speed is recording decimals as well. But that's not as important. I'll attach a log so you can see... I was having this exact problem with all of my 4-byte parameters. found THIS romraider thread that answers it. Problem is the line "databits = 32" for each 4-byte parameter. Change this line to "isfloat = 1" and that should solve the issue. I haven't tested on my log yet but will in a few hours to see if that fixes it. Link to comment Share on other sites More sharing options...
