keithk831 Posted April 2, 2010 Share Posted April 2, 2010 P.S. I have a new Lexar 2GB card. Formatted in FAT. And I installed the ecuFlash beta and updated the firmware. Link to comment Share on other sites More sharing options...
keithk831 Posted April 2, 2010 Share Posted April 2, 2010 Geez....noob error. I had my file named as logcfg.txt.txt I just went and tested the logging while parked. Looks like it's working fine except some of the values are weird. Namely the manifold relative pressure. The values look like "63508700" Another weird thing is the engine speed is recording decimals as well. But that's not as important. I'll attach a log so you can see...log0002.csv Link to comment Share on other sites More sharing options...
enthusiast Posted April 3, 2010 Share Posted April 3, 2010 <snip> ...some of the values are weird. Namely the manifold relative pressure. The values look like "63508700" What ECUID are you using? My mod list Link to comment Share on other sites More sharing options...
enthusiast Posted April 3, 2010 Share Posted April 3, 2010 Sample times are not microSD dependent here. If you use K-line, which you do then yes this is normal. K-line is half-duplex and operates at 4800bps. The more parameters you log the longer the query interval. Two parameters: RPM, Throttle = 0.08 secs per sample Nine parameters like for a WOT run = 0.15 secs per sample Basically each parameter adds about 0.012 secs to the query interval. Good explanation. Where is this documented? As for the updated firmware in the OP2, you should still be able to use the older version 1.42 of ECUFlash without a problem. If you installed 1.43 just uninstall it and the drivers and go back to 1.42. I saw a post about that but can't find it ATM. Dale Was it this one? http://www.romraider.com/forum/topic5999.html Presently I am trying to get the RPN function on the online generator to not have any division (for better speed). The stack switching is driving me crazy. My mod list Link to comment Share on other sites More sharing options...
keithk831 Posted April 3, 2010 Share Posted April 3, 2010 what ecuid are you using? a2wc510n Link to comment Share on other sites More sharing options...
LGTspecB1657615261 Posted April 3, 2010 Share Posted April 3, 2010 Geez....noob error. I had my file named as logcfg.txt.txt I just went and tested the logging while parked. Looks like it's working fine except some of the values are weird. Namely the manifold relative pressure. The values look like "63508700" Another weird thing is the engine speed is recording decimals as well. But that's not as important. I'll attach a log so you can see... MRP 4 byte does not work for me either. Just use the standard 8 bit (listed first), it works fine. Engine load 4 byte does not work, 2 byte is the only one that works. Just keep trying the different variations of the parameter and one will work. Link to comment Share on other sites More sharing options...
keithk831 Posted April 3, 2010 Share Posted April 3, 2010 MRP 4 byte does not work for me either. Just use the standard 8 bit (listed first), it works fine. Engine load 4 byte does not work, 2 byte is the only one that works. Just keep trying the different variations of the parameter and one will work. Thanks for the tip...i'll try that! Link to comment Share on other sites More sharing options...
dschultz Posted April 3, 2010 Share Posted April 3, 2010 Good explanation. Where is this documented? It maybe somewhere on the RR or OpenECU sites, but really it's just math. In it's simplest form, Logger sends a request which is a header and parameter(s) to retrieve. The ECU responds with a header and the value. Most parameter requests are 3 bytes long and replies are 1 byte long. So 4 bytes of data (ignoring headers) are passed on the K-line. At 4800 bps the 4 byte = 32 bits. 32/4800 = 0.007 seconds for this parameter. When you add the headers it's longer of course. One parameter request takes a baseline of about 0.065 seconds. So you can start adding from there. Was it this one? http://www.romraider.com/forum/topic5999.html Yes Link to comment Share on other sites More sharing options...
keithk831 Posted April 4, 2010 Share Posted April 4, 2010 So what's the difference between 2-byte and 4-byte? Link to comment Share on other sites More sharing options...
LGTspecB1657615261 Posted April 4, 2010 Share Posted April 4, 2010 So what's the difference between 2-byte and 4-byte? 16 bit vs 32 bit. resolution of the signal I believe. For logging purposes, it does not matter IMO. Link to comment Share on other sites More sharing options...
dschultz Posted April 5, 2010 Share Posted April 5, 2010 So what's the difference between 2-byte and 4-byte? If you are referring to the parameters you are able to retrieve...? some have three options: 1 byte, lowest resolution and will be limited in dynamic range, 0 - 256 2 byte, better dynamic range with some loss of precision, 0 - 65535 4 byte, this is the value the ECU uses internally for calculations. It gives the best dynamic range but the cost is that it takes much longer to transmit these values on the wire. So only a couple can be queried at a rate of x samples per second. Link to comment Share on other sites More sharing options...
keithk831 Posted April 5, 2010 Share Posted April 5, 2010 So, in most cases, which option is the best for datalogging purposes? Link to comment Share on other sites More sharing options...
dschultz Posted April 5, 2010 Share Posted April 5, 2010 Well that depends on what you are trying to identify in the log you are doing. Logged parameters should be specific to what you want to learn, whether it be a WOT run looking for knock or tuning boost, etc. If you are using K-line the 1-byte parameters will allow for more samples per second which may be better than a 2 byte parameter and few samples per second, especially if you are looking for a blip or some transitional state. The RR FAQ has some info about what is good to log: http://www.romraider.com/Documentation/RomRaiderFAQ#toc62 Link to comment Share on other sites More sharing options...
Legacy_GT_Pilot Posted April 6, 2010 Share Posted April 6, 2010 Is there anything special that you need to do so a PC recognizes the card? I've installed the newest version of ECU Flash and did the firmware update. But when I plug my Tactrix cable into my PC with the SD mini card inserted, my computer doesn't recognize it. Thoughts? Link to comment Share on other sites More sharing options...
dschultz Posted April 6, 2010 Share Posted April 6, 2010 It most likely needs to be powered from the ODB-II connector. USB power is probably not enough to get the OP2 booted up. Link to comment Share on other sites More sharing options...
keithk831 Posted April 6, 2010 Share Posted April 6, 2010 Is there anything special that you need to do so a PC recognizes the card? I've installed the newest version of ECU Flash and did the firmware update. But when I plug my Tactrix cable into my PC with the SD mini card inserted, my computer doesn't recognize it. Thoughts? Not sure. Mine works just fine connected to my laptop without being connected to the car. Try restarting your computer and try the firmware update again to see if it lets you. What size of SD card did you get? Link to comment Share on other sites More sharing options...
LGTspecB1657615261 Posted April 6, 2010 Share Posted April 6, 2010 Is there anything special that you need to do so a PC recognizes the card? I've installed the newest version of ECU Flash and did the firmware update. But when I plug my Tactrix cable into my PC with the SD mini card inserted, my computer doesn't recognize it. Thoughts? Update firmware in Tactrix? Link to comment Share on other sites More sharing options...
Legacy_GT_Pilot Posted April 6, 2010 Share Posted April 6, 2010 Thanks - I will try that tonight and see if it works. It most likely needs to be powered from the ODB-II connector. USB power is probably not enough to get the OP2 booted up. Link to comment Share on other sites More sharing options...
Underdog Posted April 6, 2010 Author Share Posted April 6, 2010 +1 to what Keith said. If I have the OP2 hooked up to my laptop and not to the car, it still lights up and registers the mSD card as a removable disk. The Crimson Dynamo Link to comment Share on other sites More sharing options...
Legacy_GT_Pilot Posted April 6, 2010 Share Posted April 6, 2010 I've tried 2 different 2GB cards. I've done the firmware update multiple times and rebooted my machine several times as well. Everytime the SD card doesn't show up, but the port lights up as expected. I will try the connection to my car, and will also try the cable on my home PC to see if that works as well. Dave Not sure. Mine works just fine connected to my laptop without being connected to the car. Try restarting your computer and try the firmware update again to see if it lets you. What size of SD card did you get? Link to comment Share on other sites More sharing options...
Underdog Posted April 6, 2010 Author Share Posted April 6, 2010 I found that I had to put the card in first, then plug it into the computer. If I plugged it into the computer first, then inserted the card, it wouldn't show up as a separate drive. The Crimson Dynamo Link to comment Share on other sites More sharing options...
05pearl Posted April 6, 2010 Share Posted April 6, 2010 Link to comment Share on other sites More sharing options...
keithk831 Posted April 6, 2010 Share Posted April 6, 2010 I found that I had to put the card in first, then plug it into the computer. If I plugged it into the computer first, then inserted the card, it wouldn't show up as a separate drive. X2. I haven't tried plugging in the card after the cable was already plugged in, but I have my card in the cable all the time and I have never had a problem. Link to comment Share on other sites More sharing options...
H2Otx Posted May 10, 2010 Share Posted May 10, 2010 Here is a stupid question but does the mSD card click in? Or do you just slide it in and it chills? Link to comment Share on other sites More sharing options...
keithk831 Posted May 10, 2010 Share Posted May 10, 2010 Here is a stupid question but does the mSD card click in? Or do you just slide it in and it chills? Mine clicked in. Link to comment Share on other sites More sharing options...
