Tronix Posted April 16, 2005 Share Posted April 16, 2005 R0ut3r, let me know how those Infinity speakers sound. I'd like to upgrade my door speakers, but not if they dont make that much a difference. im worried of not upgrading the headunit, so it just sounds the same. -Tronix(crispy)GT for more pics and info... http://angevine.org/legacy/legacy.html Link to comment Share on other sites More sharing options...
tu11ym0n Posted April 22, 2005 Share Posted April 22, 2005 I tested my settings on Tribe called quest's "low end theory" arguably one of the bassiest rap cd's ever, and my settings sound fine. now we're talking one of my fave albums of all time. can't think of a better CD to use for testing a subwoofer. can someone confirm that it's not a PITA to change the settings? more importantly, for those who had the sub installed afterwards, do you know if the sub limits how far down the seat can go? i need the seat in its lowest and furthest back position in order to have enough headroom and legroom (and it's still not as comfy as my Passat), so if the sub limits the seat position there's no way I can do it. anyone know if it's easy to use a self-amped 6" Kicker instead of the Subaru subwoofer? Can it easily be connected to where the Subaru sub connects to (provided there is an adaptor plug that matches the Subaru connection). Link to comment Share on other sites More sharing options...
deneb Posted April 22, 2005 Share Posted April 22, 2005 I am installing this tomorrow: Infinity 6002i x2 in the rear Infinity 6000CS x2 in the front Rockford Fosgate P4004 for the speakers Sony XS-L102P5 x2 subs in enclosure Sony XM-D500X to drive the subs So how did the install go? Any issues with depth problems replacing the door speakers? Where did you mount the amps? Link to comment Share on other sites More sharing options...
R0ut3r Posted April 24, 2005 Share Posted April 24, 2005 The install went well enough... Speaker did require 1/2 inch spacers in front and none in back. I added Dynamat Extreme (1 layer for the inside of the door and 1 more layer around the speakers). The crossovers for the Infinity components were hard to secure inside the panel. The only PITA is that there seems to be a very low volume, high-pitched whine that follows engine RPM when the radio is off... I did a last minute change to the amp setup, I used the MTX 4004 and am happy with that plus its a smaller footprint. we made a custom board to mount the amps behind the seats. I have the PDFs on how to take off the radio and panels if you need them. Link to comment Share on other sites More sharing options...
Hef Posted April 27, 2005 Share Posted April 27, 2005 The install went well enough... Speaker did require 1/2 inch spacers in front and none in back. I added Dynamat Extreme (1 layer for the inside of the door and 1 more layer around the speakers). The crossovers for the Infinity components were hard to secure inside the panel. The only PITA is that there seems to be a very low volume, high-pitched whine that follows engine RPM when the radio is off... I did a last minute change to the amp setup, I used the MTX 4004 and am happy with that plus its a smaller footprint. we made a custom board to mount the amps behind the seats. I have the PDFs on how to take off the radio and panels if you need them. where did you get the spacers for the fronts? and you said no spacers needed in the back. does that mean that when you removed the stockers, the Infinity's screwed right in without any modification? Link to comment Share on other sites More sharing options...
R0ut3r Posted April 27, 2005 Share Posted April 27, 2005 where did you get the spacers for the fronts? and you said no spacers needed in the back. does that mean that when you removed the stockers, the Infinity's screwed right in without any modification? I got the spacers at a local audio shop. The rear speakers I bought went right in the original hole. the only "spacing effect" would come from the 1/8 inch of Dynamat I applied to the speaker hole and surrounding area. Take note of the model, Infinity 6002i, as I cannot vouch other ones will fit the same way! Link to comment Share on other sites More sharing options...
Hef Posted April 27, 2005 Share Posted April 27, 2005 I got the spacers at a local audio shop. The rear speakers I bought went right in the original hole. the only "spacing effect" would come from the 1/8 inch of Dynamat I applied to the speaker hole and surrounding area. Take note of the model, Infinity 6002i, as I cannot vouch other ones will fit the same way! nice. you didn't even have to redrill holes? in the front or back? Link to comment Share on other sites More sharing options...
R0ut3r Posted April 27, 2005 Share Posted April 27, 2005 You will need to drill holes. I used self-tapping metal screws (4 per speaker), both in front and back. The stock speaker assembly uses 3 screws. which won't work with aftermarket speakers. Link to comment Share on other sites More sharing options...
DSattler Posted April 27, 2005 Share Posted April 27, 2005 Sub does not affect the seat's ability to move up, down, or any other way. Link to comment Share on other sites More sharing options...
Fosgate Posted April 28, 2005 Share Posted April 28, 2005 I thought the factory sub attached to the rear dash. If yo look in the trunk, there is a 6-7 inch ring in the frame that mounts the rear deck. Just assumed that was for a sub. Link to comment Share on other sites More sharing options...
tu11ym0n Posted April 28, 2005 Share Posted April 28, 2005 nope it's definitely under the driver's seat for an 05 Legacy GT Link to comment Share on other sites More sharing options...
Fosgate Posted April 28, 2005 Share Posted April 28, 2005 Look in the trunk. You will see the ring. You just won't did in seven days. Link to comment Share on other sites More sharing options...
sduford Posted April 28, 2005 Share Posted April 28, 2005 The VDC has the standard sub in the back, otherwise theoptional sub goes under the driver's seat. To adjust it you should first set your headunit to flat (0) and at the highest volume you like to listen to, then adjust the sub to the level you like, making sure it doesn't bottom or distort. Once you've set the level, you should play a CD or radio station with a nice deep male voice and adjust the cross-over frequency so that the sub doesn't "muddy" the voice. Sylvain www.digitalfotographer.com - Audi Q5 Club - MB-GLK Club Link to comment Share on other sites More sharing options...
Fosgate Posted April 28, 2005 Share Posted April 28, 2005 Kewl. I still say just put 2 Dual voice coil, 12 inch Fosgate Subs in a ported box in the trunk. Throw about 800 - 1000 watts through it. That's what I do. I promise yo won't be disapointed. Link to comment Share on other sites More sharing options...
retslo Posted April 28, 2005 Share Posted April 28, 2005 How is the leg space/toe space after you install SUB? Link to comment Share on other sites More sharing options...
Fosgate Posted April 28, 2005 Share Posted April 28, 2005 I will let you know when the install is done. Still waiting on my Alpine deck. SHould be near the end of May. Link to comment Share on other sites More sharing options...
S4 Posted April 28, 2005 Share Posted April 28, 2005 I have the gain maxed and the cutoff is not even a 1/4 turn. I listened to talk radio to determine the cutoff, when the voices started to distorted I stopped turning it up. Some may disagree about maxing out gain, but the sub does not put out a ton of bass and having it maxed does not make it boomy in the least, I tested my settings on Tribe called quest's "low end theory" arguably one of the bassiest rap cd's ever, and my settings sound fine. In the end sound is subjective so just tweak to your taste. Also my headunit is set to 0 for bass. Yeah, maxing out the gain will probably have you clipping at even low volumes. You may get better results (and maybe even louder) if you back the gain off a bit. Link to comment Share on other sites More sharing options...
Fosgate Posted April 28, 2005 Share Posted April 28, 2005 Took rough measurments, should be able to put my clubs, or a couple medium size suit cases with a little room to spare. Link to comment Share on other sites More sharing options...
Fosgate Posted April 28, 2005 Share Posted April 28, 2005 Too cut down on sub space, get a sealed box instead of a ported box. They take up less space. Sound is not a deep as a ported box, but will still be night and day from what you are use to. Link to comment Share on other sites More sharing options...
PGT Posted April 28, 2005 Share Posted April 28, 2005 Too cut down on sub space, get a sealed box instead of a ported box. They take up less space. Sound is not a deep as a ported box, but will still be night and day from what you are use to. That's not a blanket statement - some drivers require small ported enclosures. Link to comment Share on other sites More sharing options...
Fosgate Posted April 28, 2005 Share Posted April 28, 2005 That's not a blanket statement - some drivers require small ported enclosures. Yes you are 100% correct, however I was only talking about subs not speakers in general. It can apply to drivers too. Link to comment Share on other sites More sharing options...
PGT Posted April 28, 2005 Share Posted April 28, 2005 Yes you are 100% correct, however I was only talking about subs not speakers in general. It can apply to drivers too. I was referring to subwoofers as well - not all ported enclosures are larger than their sealed iterations. Link to comment Share on other sites More sharing options...
Fosgate Posted April 28, 2005 Share Posted April 28, 2005 A properly built box with a single port is bigger than a Sealed box. Sure you can make it smaller, but won't sound right. Link to comment Share on other sites More sharing options...
PGT Posted April 28, 2005 Share Posted April 28, 2005 A properly built box with a single port is bigger than a Sealed box. Sure you can make it smaller, but won't sound right. Not true. The general rule is that ported enclosures are larger than sealed. As with all rules, there are exceptions. Surely, with a name like 'Fosgate' you should remember the old Rockford-Fosgate Power series woofers. They went into small ported enclosures.....smaller than the sealed boxes for other series at the time. Link to comment Share on other sites More sharing options...
Fosgate Posted April 28, 2005 Share Posted April 28, 2005 There are always exceptions. Link to comment Share on other sites More sharing options...
