BravoZero Posted March 16, 2010 Share Posted March 16, 2010 I am new to Subaru's so I want to make sure I don't do anything that will cause total uber destruction. My 2.5i has 57k miles and I dunno if any fuel cleaning has been done, or if any oil additives have been added to help with the cylinder walls and compression. My question is... What products work best on Subaru engines? I want to run a tank of fuel treatment to clean the gunk out and run some oil additive to help protect the inners. Suggestions? Link to comment Share on other sites More sharing options...
rao Posted March 16, 2010 Share Posted March 16, 2010 The best suggestion is not to waste your money on any of that stuff Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
bluesuby Posted March 16, 2010 Share Posted March 16, 2010 Techron fuel injector cleaner is a very good product but it costs a little more than the bargain brands. Advance Auto parts usually has a 2 for 1 12oz bottle(s) for $7.99. If you have Chevron gasoline in your area Techron is already added. Link to comment Share on other sites More sharing options...
GTTuner Posted March 16, 2010 Share Posted March 16, 2010 Techron is really good stuff and is the only product I would recomend for your fuel system. I would put valve/combustion chamber cleaner in there once every 6-8 months. Just buy a good brand name engine oil and you should not need any additives. Link to comment Share on other sites More sharing options...
BravoZero Posted March 16, 2010 Author Share Posted March 16, 2010 Thanks guys. Would BG44K be a little much for the flat-4 engines? What about using Restore after an oil change? Link to comment Share on other sites More sharing options...
GTTuner Posted March 16, 2010 Share Posted March 16, 2010 Stay away from the Restore, please!!!! BG's oil supliment is fine. Link to comment Share on other sites More sharing options...
NJLGT Posted March 16, 2010 Share Posted March 16, 2010 I use Lucas fuel injector cleaner every couple of tanks Link to comment Share on other sites More sharing options...
GEE-OTTO Posted March 16, 2010 Share Posted March 16, 2010 The best suggestion is not to waste your money on any of that stuff + 1 Billion Link to comment Share on other sites More sharing options...
fishbone Posted March 16, 2010 Share Posted March 16, 2010 The best suggestion is not to waste your money on any of that stuff Usually when someone asks this sort of thing, you can rest assured they will pour something in their car anyways and not pay attention to this sort of advice because they are already in the frame of mind something needs attention. Opie, if it really makes you feel better then just run a can of good injector cleaner and that's that. Fuel flushes, additives, etc. are 100% not needed and can cause more harm than good. Link to comment Share on other sites More sharing options...
theflystyle Posted March 16, 2010 Share Posted March 16, 2010 For my 94 Legacy with a ton of miles a good Seafoam bottle did seem to make things a little smoother (such as idling, etc). When put through the PCV with a little throttle, plenty of smoke was coming out the exhaust (carbon buildup, correct?) i dont know of newer gen cars needing this kinda treatment but i would suggest searching the forums for seafoam or any of the other brands mentioned. Link to comment Share on other sites More sharing options...
Jeepis Posted April 13, 2010 Share Posted April 13, 2010 I use Lucas fuel injector cleaner every couple of tanks On sale at AutoZone right now, really good stuff, I have used it to bring a clogged up gokart engine carb back to life. Link to comment Share on other sites More sharing options...
IcEWoLF Posted April 18, 2010 Share Posted April 18, 2010 I was using Arco AM/PM gas (I think its BP the supplier). I went ahead and switched to Chevron and it comes with Techron just today...I've had the car only for 3 weeks plus now..only 3 fills I think so far, so it shouldn't be a huge deal on switching gas provider. Its a bit pricier, but at least its cleaner and always good for my car. Link to comment Share on other sites More sharing options...
NORULZleggy Posted April 19, 2010 Share Posted April 19, 2010 I use Lucas fuel injector cleaner every couple of tanks I am with him, they have some go products. Link to comment Share on other sites More sharing options...
