enthusiast Posted March 10, 2010 Share Posted March 10, 2010 http://www.progressauto.com/products/sfID1/15/sfID2/58/sfID3/131 for beefier mounts and cheaper than the rest. I have these with my 25mm rear sway bar. They are on back order will take 6 weeks to get them. Looks like I will be ordering the AVO ones. My mod list Link to comment Share on other sites More sharing options...
RedDawg Posted March 12, 2010 Share Posted March 12, 2010 Who did you order the beefier clamps from? interested in these beefier clamps also. link? Link to comment Share on other sites More sharing options...
PineyLGT805 Posted March 12, 2010 Share Posted March 12, 2010 Those from progressive autowill work, but if you call Perrin, They carry the beefier ones in stock. (at least last time i called they did) Link to comment Share on other sites More sharing options...
PineyLGT805 Posted March 12, 2010 Share Posted March 12, 2010 Funny thing is, is that i broke 3 sets of stock clamps in about 3 years and have now been on my last set of stock ones for over 2 years (I ordered 4 stock sets the first time i broke them). I wonder why the first 3 sets broke so quick and the last set hasn't. I keep inspecting them and they look good as new. Anyways, I have the beefier ones ready to go, just am waiting for my last stock set to break (if that will even happen) Link to comment Share on other sites More sharing options...
bochinam Posted March 23, 2010 Share Posted March 23, 2010 Good gawd! Unpacked the Perring 25mm rear bar today...this thing is huge. Ok, so what are you guys running for rear endlinks now that Perrin is no longer making them? Link to comment Share on other sites More sharing options...
integroid Posted March 23, 2010 Author Share Posted March 23, 2010 If the stock endlinks are metal, stick with those until they break. Link to comment Share on other sites More sharing options...
CDN 2.5i Posted March 23, 2010 Share Posted March 23, 2010 MSI's get my vote. May be a couple sets left right now... check the "INTEREST in endlinks" thread. Link to comment Share on other sites More sharing options...
PineyLGT805 Posted March 23, 2010 Share Posted March 23, 2010 Why has Perrin stopped making the endlinks? are they phazing out their suspension department? Link to comment Share on other sites More sharing options...
whitetiger Posted March 23, 2010 Share Posted March 23, 2010 as stated earlier in the thread, you will want to invest inthe avo stout mounts and whiteline bushings with the beefy u-clamps. you will bend or break you stock hardware with this bar. Link to comment Share on other sites More sharing options...
Mindspin311 Posted March 23, 2010 Share Posted March 23, 2010 Can someone post a link to the stronger u-clamps? Link to comment Share on other sites More sharing options...
PineyLGT805 Posted March 23, 2010 Share Posted March 23, 2010 http://www.progressauto.com/products/sfID1/15/sfID2/58/sfID3/131 don't forget these, that what I also have for on for the rear. Here it is Link to comment Share on other sites More sharing options...
Mindspin311 Posted March 23, 2010 Share Posted March 23, 2010 Oh, so is that a reinforcement bracket and stronger U clamp all-in-one? I already have the Perrin brackets.. Link to comment Share on other sites More sharing options...
PineyLGT805 Posted March 23, 2010 Share Posted March 23, 2010 Oh, so is that a reinforcement bracket and stronger U clamp all-in-one? I already have the Perrin brackets.. No that is just the U Clamp. It is the part that secures the Sway Bar and Bushing to the Stout Mount. Link to comment Share on other sites More sharing options...
integroid Posted March 23, 2010 Author Share Posted March 23, 2010 Oh, so is that a reinforcement bracket and stronger U clamp all-in-one? I already have the Perrin brackets.. Then you should be fine. There really is no reason to go with aftermarket end links since our rear end links are already metal. I put on a set of Perrin's because I thought they were plastic until I went back there to install the Perrin's. I did not notice one bit of dirrence with the Perrin end links. Link to comment Share on other sites More sharing options...
whitetiger Posted March 23, 2010 Share Posted March 23, 2010 If you buy the right bushings from energy suspension, they come with stronger u clamps. and they are greasable too! here is a direct link http://www.energysuspensionparts.com/proddetail.asp?prod=9.5161 Link to comment Share on other sites More sharing options...
Mindspin311 Posted March 23, 2010 Share Posted March 23, 2010 Are the energy bushings worth it over the perrin supplied ones? Link to comment Share on other sites More sharing options...
whitetiger Posted March 23, 2010 Share Posted March 23, 2010 yes. my perrin ones wore out very quickly and started making noise. the ES ones i have now are going strong after 2+ years, and i autox regularly and beat the hell out of my car. there hasnt been rear end noise since i installed them. Link to comment Share on other sites More sharing options...
Mindspin311 Posted March 23, 2010 Share Posted March 23, 2010 Thanks! Def. gonna look into them for my 22mm bars Im looking to install. Link to comment Share on other sites More sharing options...
PineyLGT805 Posted March 23, 2010 Share Posted March 23, 2010 Then you should be fine. There really is no reason to go with aftermarket end links since our rear end links are already metal. I put on a set of Perrin's because I thought they were plastic until I went back there to install the Perrin's. I did not notice one bit of dirrence with the Perrin end links. Are you sure? My stock endlinks looked like KNEX or Tinker Toys, My aftermarket ones were almost half the weight and twice as beefier. I would highly suggest gettin aftermarket endlinks since the stocks are known to fail if you plan on driving spirited Link to comment Share on other sites More sharing options...
Mindspin311 Posted March 23, 2010 Share Posted March 23, 2010 The stock endlinks have PLASTIC joints. They will eventually break. Check out Rallitek's website for some good info. I went with their HD endlinks. Stock design, but 100% metal. Very stout, annddddd a 5yr warranty! Link to comment Share on other sites More sharing options...
Mindspin311 Posted March 23, 2010 Share Posted March 23, 2010 yes. my perrin ones wore out very quickly and started making noise. the ES ones i have now are going strong after 2+ years, and i autox regularly and beat the hell out of my car. there hasnt been rear end noise since i installed them. Just ordered 2 sets of the 22mm bushings from ES per your suggestion. I think my stock bushings are starting to clunk now when I go over speed bumps and the like. So annoying. Link to comment Share on other sites More sharing options...
TSiWRX Posted March 23, 2010 Share Posted March 23, 2010 If you buy the right bushings from energy suspension, they come with stronger u clamps. and they are greasable too! here is a direct link http://www.energysuspensionparts.com/proddetail.asp?prod=9.5161 ^ OK, I'm stoopid, and need help. So I want to order quantity of 1 (one), right? since they come in a paired set, right? <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
Mindspin311 Posted March 24, 2010 Share Posted March 24, 2010 BTW, for anyone considering the ES bushings.. Buying from ES directly was the cheapest I found them. $42 shipped for front and rear sets. Link to comment Share on other sites More sharing options...
whitetiger Posted March 24, 2010 Share Posted March 24, 2010 ^ OK, I'm stoopid, and need help. So I want to order quantity of 1 (one), right? since they come in a paired set, right? yes, they come in pairs. Link to comment Share on other sites More sharing options...
TSiWRX Posted March 24, 2010 Share Posted March 24, 2010 ^ Sweet. Thank you. <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
