macautoparts Posted December 2, 2010 Share Posted December 2, 2010 Th3Franz how did the install on the axles go? Link to comment Share on other sites More sharing options...
Th3Franz Posted December 2, 2010 Share Posted December 2, 2010 Just fine. The fit is good. Haven't been driving the car much because of a main shaft seal leak caused by a pilot bearing failure. Once that's fixed I'll drive the car some more -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
lucas569 Posted December 5, 2010 Share Posted December 5, 2010 gotta get one of these soon. was getting high and sick the other day from the foul odor of the grease hitting the downpipe. i freaked thought it was something else til i noticed my cv boot was torn. fml. Link to comment Share on other sites More sharing options...
al-gorithm Posted December 6, 2010 Share Posted December 6, 2010 macautoparts do you guys ship to Canada? Link to comment Share on other sites More sharing options...
macautoparts Posted December 7, 2010 Share Posted December 7, 2010 Th3Franz - its good to hear everything went good on the install. Hope you get your car back in top shape soon. al-gorithm - we do ship to canada, however the shipping is a little expensive due to the weight of the axle. it is $54 which is in the neighborhood of the same price as the axle itself. Some people have it shipped to a friend just across the border and pick it up. Link to comment Share on other sites More sharing options...
ibr_adam09 Posted January 1, 2011 Share Posted January 1, 2011 Since my boot finally dried up and ripped all away around on the driver side, I'll order one cv axle from Mac Auto. I just have a few questions 1) The one on the passenger side is aftermarket cv axle and it's completely fine, but should I replace it as well with a Mac Auto axle ? ( Just the piece of mind there both same brand ) 2) should I order new ball joints since I have to remove it during installation ? 54.95 is a great price ! I don't mind getting a second axle, lol Link to comment Share on other sites More sharing options...
itsme Posted January 2, 2011 Share Posted January 2, 2011 Since my boot finally dried up and ripped all away around on the driver side, I'll order one cv axle from Mac Auto. I just have a few questions 1) The one on the passenger side is aftermarket cv axle and it's completely fine, but should I replace it as well with a Mac Auto axle ? ( Just the piece of mind there both same brand ) 2) should I order new ball joints since I have to remove it during installation ? 54.95 is a great price ! I don't mind getting a second axle, lol You don't have to remove the ball joint to install a new axle. Just remove the bolt on the bottom of the LCA and push down on the LCA you don't need a pickle fork to separate. After that take off the axle nut, turn the wheel and pull out the half shaft. Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
Th3Franz Posted January 2, 2011 Share Posted January 2, 2011 I replaced both of mine at the same time. I recommend doing both of them since they are inexpensive, and it will eliminate the possibility of vibrations from one side being different than the other. My only gripe is that the coating on them isn't very good. They have only been on a couple months and are showing surface rust already. Guess I can't be too surprised, since everything else is working good for the price. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
Mindspin311 Posted January 2, 2011 Share Posted January 2, 2011 Just found out my passenger side inner boot is failing. Got the nice smoking coming off my DP. Also curious about 1 side vs both. Any more input? Link to comment Share on other sites More sharing options...
ibr_adam09 Posted January 14, 2011 Share Posted January 14, 2011 So I finally did my install with the empi from mac auto. For the life of me I couldn't get this axle to go any further into the transmission, but I can't easily take it off either. Is this seated properly ? I took it for a little run all the way up till the engine got to avg. temp and I haven't notice any leaks. http://i344.photobucket.com/albums/p330/ibr_adam09/SAM_0552.jpg http://i344.photobucket.com/albums/p330/ibr_adam09/SAM_0551.jpg http://i344.photobucket.com/albums/p330/ibr_adam09/SAM_0549.jpg Link to comment Share on other sites More sharing options...
fishbone Posted January 14, 2011 Share Posted January 14, 2011 From what I can see on my stock green halfshafts, they are sitting flush with the case. Oh, and my driver's side inner boot on the skinny side has developed a slight tear all around the clamp due to a shop putting a band clamp to stop a leak and tightening it way too much. I loosened it so I hope that stopped the tear from progressing, but if it rips I don't know what route i wanna take. Replace it, rebuild it, replace both with aftermarket just to be sure they're the same? Argh! Link to comment Share on other sites More sharing options...
macautoparts Posted January 17, 2011 Share Posted January 17, 2011 ibr_adam09 I have forwarded your pictures to the manufacturer, i don't think it will be an issue but they told me they have their Research and Development guys looking into it. I will let you know if it is an issue or not. Thank you Link to comment Share on other sites More sharing options...
lucas569 Posted January 28, 2011 Share Posted January 28, 2011 just ordered 2 Link to comment Share on other sites More sharing options...
ibr_adam09 Posted February 4, 2011 Share Posted February 4, 2011 So I can confirm a leak again from the driver side axle transmission housing. I'm thinking this is a separate issue because the car drives fine Does anyone have a pic of all the seals that sit around the axle on the driver side ? Link to comment Share on other sites More sharing options...
Th3Franz Posted February 5, 2011 Share Posted February 5, 2011 It's just one seal for the axle on either side of the transmission. It looks like a big rubber washer -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
ibr_adam09 Posted February 6, 2011 Share Posted February 6, 2011 Yup just found out that the new seal I put in wasn't seated properly. Link to comment Share on other sites More sharing options...
TurboBrett Posted April 27, 2011 Share Posted April 27, 2011 Bumping this up. Anyone get vibrations from these? Just installed two on a customers car yesterda and it vibrated like CRAZY under acceleration, particularly after turning. Put the stockers back on and it completely went away. Has anyone else had this problem with these? Link to comment Share on other sites More sharing options...
itsme Posted April 27, 2011 Share Posted April 27, 2011 I have the aup-190n for the last few years with no problems and I take mine to the drag strip Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
TurboBrett Posted April 27, 2011 Share Posted April 27, 2011 I, too, have one on my DD and never had vibrations from it. unfortunately both of the new ones vibrate very badly, nearly as bad as a wheel with loose studs. Link to comment Share on other sites More sharing options...
goneskiian Posted May 19, 2011 Share Posted May 19, 2011 Bumping again. Are the one's you folks are getting vibrations from the Empi ones from Macauto? Link to comment Share on other sites More sharing options...
TurboBrett Posted May 19, 2011 Share Posted May 19, 2011 Bumping again. Are the one's you folks are getting vibrations from the Empi ones from Macauto? Yes, both of them from macauto vibrated. I swapped the stockers back in one at a time and can confirm that each of them vibrate. I ended up replacing the boots and re-greasing the stockers. Now the customer is stuck with new, vibrating macauto axles that will cost $35 to ship back for evaluation for refund, minus a restocking fee. If they decide there isn't anything wrong with them (they passed QA in the first place, after all, so who's to say they'll find anything wrong) then that would be more wasted $$ sending them back. Macauto wasn't pleasant at all to speak with over the phone, attempting to blame the mechanic as much as possible even though it's only their axles that are vibrating, not the stockers which were also re-installed by me. I won't be buying them again either. Link to comment Share on other sites More sharing options...
goneskiian Posted May 20, 2011 Share Posted May 20, 2011 Yes, both of them from macauto vibrated. I swapped the stockers back in one at a time and can confirm that each of them vibrate. I ended up replacing the boots and re-greasing the stockers. Now the customer is stuck with new, vibrating macauto axles that will cost $35 to ship back for evaluation for refund, minus a restocking fee. If they decide there isn't anything wrong with them (they passed QA in the first place, after all, so who's to say they'll find anything wrong) then that would be more wasted $$ sending them back. Macauto wasn't pleasant at all to speak with over the phone, attempting to blame the mechanic as much as possible even though it's only their axles that are vibrating, not the stockers which were also re-installed by me. I won't be buying them again either. Thanks for the quick reply Brett! Hmmm, that's not good. I'm glad I didn't order one yet. Maybe we'll get macauto to chime in on this issue since they've got somebody there who's contributed here in the past. Link to comment Share on other sites More sharing options...
NSFW Posted May 20, 2011 Share Posted May 20, 2011 That's a bummer. I was thinking of buying a spare set of these and replacing as needed, instead of blowing $$$ for a set of heavy-duty aftermarket axles. I could break a few and still come out way ahead. But not if they don't work right. What year was your customer's car, TurboBrett? And, MT or AT? Not sure if it should matter, but just in case... Link to comment Share on other sites More sharing options...
fishbone Posted May 20, 2011 Share Posted May 20, 2011 Macauto wasn't pleasant at all to speak with over the phone, attempting to blame the mechanic as much as possible even though it's only their axles that are vibrating, not the stockers which were also re-installed by me. That is one thing I did not like about dealing with them either. When I called to inform them I got the wrong axles, got defensive on the phone, said they sold hundreds and never got a complaint. Link to comment Share on other sites More sharing options...
goneskiian Posted May 20, 2011 Share Posted May 20, 2011 I've sent a PM to macautosales. Hopefully who ever it was that opened the account still checks it. Last activity from that user was way back in January though so I'm not too hopeful. Link to comment Share on other sites More sharing options...
