Th3Franz Posted April 5, 2005 Share Posted April 5, 2005 Are these coilovers inverted? Should we start coming to a consensus on spring rates..? -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
JINSU-POWER Posted April 5, 2005 Author Share Posted April 5, 2005 ksport could possiblly give out shock dynos if needed. But the best way to do it is to have a prototype made and let one of the members to try it out and give reviews. The ksport uses much stiffer spring rates is to keep body movement to a minimum during cornering. Just about everyone that have had kpsort so far love it handles and the ride quality isn't affected too much. Inputs are much appreciated so Ksport can have a general idea of what most potential buyers would like the kit to act. Link to comment Share on other sites More sharing options...
scans007 Posted April 5, 2005 Share Posted April 5, 2005 Sweet, so I get a set to Drift Monkey (who I trust with information like this - not much else ;p)....let him test them out........ If he gives his OK, people (I know me) will be much more likely to bite. Like I stated, I can't make a decision until I return in 2 weeks.... Link to comment Share on other sites More sharing options...
ChruiSSer Posted April 5, 2005 Share Posted April 5, 2005 I'm pretty interested...funds are tight right now because I've almost saved up for a couple other mods. I'm guessing that once they are built and tested, you would want to see the remainder of the payment...? So the remainder would be due in 3 months or so? If this is the case then I'm *probably* in. Link to comment Share on other sites More sharing options...
JINSU-POWER Posted April 5, 2005 Author Share Posted April 5, 2005 that is correct, the rest of the payment will be due once the full production begins. Link to comment Share on other sites More sharing options...
gmorris Posted April 5, 2005 Share Posted April 5, 2005 I think I'm in. I'm not interested in an extremely stiff setup however. A little stiffer than stock is great but our roads aren't the greatest and I like my teeth the way they are. I realize that the damping adjustment should allow us each to get close to the setup we want. What is the height adjustability likely to be? Stock height to -55mm or so? Is the 3 months a realistic figure? I'm not interested in getting involved in a vaporware group buy. Link to comment Share on other sites More sharing options...
JINSU-POWER Posted April 5, 2005 Author Share Posted April 5, 2005 3 months should be more than enough to design the kit. But as you can see, the longer it takes to get the inital 5 confirmation, the longer the delay of the 3 months R&D period. Link to comment Share on other sites More sharing options...
Th3Franz Posted April 5, 2005 Share Posted April 5, 2005 For spring stiffness, I guess I'd like where on the softest setting, the ride quality is fairly close to stock. But, I also will be doing some autocross, so the coilovers will have to be good for that as well. Are these coilovers inverted? -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
JINSU-POWER Posted April 5, 2005 Author Share Posted April 5, 2005 height adjustment usually are 0 to 3inch drop. I will have to check to see if the coilivers are inverted. Link to comment Share on other sites More sharing options...
Th3Franz Posted April 5, 2005 Share Posted April 5, 2005 I found this.. I think D2 and Ksport are related? http://www.legacycentral.org/library/coilover.htm -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
JINSU-POWER Posted April 6, 2005 Author Share Posted April 6, 2005 D2 and Ksport shares most of the designs and are built in the same factory. But two seperate company. D2 currently has no plan of making kits for 05 legacy. I have been working with Ksport on this application solely. But i am a dealer for both company. The overdamping feel describled by that particular user is most likely due the suspension setting is dailed in currectly. It usualy takes couple weeks before a user find the eactly spot of how he/she would like the suspension to feel. On the question about the shock, ksport kit usually follow the same mounting postion as the stock suspension. Link to comment Share on other sites More sharing options...
gmorris Posted April 6, 2005 Share Posted April 6, 2005 Deposit sent, I'm in. Now 2 more people get in quick so I have a chance of seeing these before the snow flies again. If we don't have 5 by the end of April I'll want to bail out. Link to comment Share on other sites More sharing options...
JINSU-POWER Posted April 7, 2005 Author Share Posted April 7, 2005 2 more deposits and we will be rolling in full speed guys! Link to comment Share on other sites More sharing options...
JINSU-POWER Posted April 8, 2005 Author Share Posted April 8, 2005 bump for interest! COME ON! Link to comment Share on other sites More sharing options...
Th3Franz Posted April 8, 2005 Share Posted April 8, 2005 If you could get some shock dynos from them and determine whether they are inverted or not, those two things would help convince me.. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
JINSU-POWER Posted April 8, 2005 Author Share Posted April 8, 2005 The shocks most likely would be the same oriientation as all other coilovers for the legacy. Ksport would willing to put shock dyno out once they are in prototype stage, and the sooner we get enough ppl interested the sooner we will see these things happen. Link to comment Share on other sites More sharing options...
Drift Monkey Posted April 8, 2005 Share Posted April 8, 2005 Franz - we don't want an inverted setup anyway...they don't last nearly as long between rebuilds. These won't be inverted. Link to comment Share on other sites More sharing options...
BrownBoy Posted April 8, 2005 Share Posted April 8, 2005 should i do it guys? i wanna..but i cant seem to bring myself to it.....but i wanna... Link to comment Share on other sites More sharing options...
gmorris Posted April 8, 2005 Share Posted April 8, 2005 Come on guys, just do it! These guys have a pretty good rep and it's a great deal. Price ends up being less than a used spec b setup with pinks and is bound to be at least as good plus you gain the added adjustability. Can't lose! Link to comment Share on other sites More sharing options...
Drift Monkey Posted April 8, 2005 Share Posted April 8, 2005 I'm waiting for 4 so I can be #5... Link to comment Share on other sites More sharing options...
gmorris Posted April 8, 2005 Share Posted April 8, 2005 I was going to do that but it seemed to be dying so I jumped in. Come on guys, less than 1K for fully adjustable coilovers! You'd have to be on glue to miss this. Link to comment Share on other sites More sharing options...
Drift Monkey Posted April 8, 2005 Share Posted April 8, 2005 I was going to do that but it seemed to be dying so I jumped in. Come on guys, less than 1K for fully adjustable coilovers! You'd have to be on glue to miss this. Don't worry, scans will probably jump in with me by Monday. Link to comment Share on other sites More sharing options...
gmorris Posted April 11, 2005 Share Posted April 11, 2005 Bumpity Bump. Come on, lets get this rolling! Link to comment Share on other sites More sharing options...
RobY Posted April 11, 2005 Share Posted April 11, 2005 http://www.d2racing.com.tw/ Some good info... If the test results are legit... http://www.d2racing.com.tw/CERTIFICATE.htm Link to comment Share on other sites More sharing options...
BrownBoy Posted April 11, 2005 Share Posted April 11, 2005 Ah..wut the hell..I'm IN! Let's get number 5 in guys! DM, you wanted sumoen to put in #4, I'm #4, and you can be #5 now... Link to comment Share on other sites More sharing options...
