Northwoods Snowman Posted November 1, 2010 Share Posted November 1, 2010 Make sure all the contacts are clean, and tight. If the contacts started arcing, there could be a layer of carbon on them preventing current flow for an otherwise good bulb/LED. I found the LEDs I put in didn't fit tight so I had to bend the wires out a little to make sure I had good contact. Link to comment Share on other sites More sharing options...
sukaboy Posted November 2, 2010 Share Posted November 2, 2010 I got it working. Is there a longer NEO3 for the fan knob? I noticed that it's not as bright as the slide and buttons. Link to comment Share on other sites More sharing options...
Northwoods Snowman Posted November 2, 2010 Share Posted November 2, 2010 I cut the LED off the base It came on and put it on the stock bulb base. Link to comment Share on other sites More sharing options...
sukaboy Posted November 2, 2010 Share Posted November 2, 2010 Which model are those smaller ones. the ones I ordered from SuperbrightLEDs.com for my 98 LGT didn't look like that. they looked like this. 2 | 74-xHP3 Wedge Base LED bulb | Blue 74-BHP3 Link to comment Share on other sites More sharing options...
sukaboy Posted November 2, 2010 Share Posted November 2, 2010 I cut the LED off the base It came on and put it on the stock bulb base. did that make a huge difference? do I just untwist the leads off the LED one and put it on the long base one? is it enough wire? Link to comment Share on other sites More sharing options...
Northwoods Snowman Posted November 3, 2010 Share Posted November 3, 2010 I had to cut the top of the LED off carefully with a razor blade as it is glued to the base. But there are components on the wires that you do not want to cut all the way through. I might have had to play with the wires a little, but they were long enough to work. I might have some pictures of it a while back, not sure. Link to comment Share on other sites More sharing options...
sukaboy Posted November 3, 2010 Share Posted November 3, 2010 i went back thru the forum and found your post on using the old base and saw your pics. But it was only the finished LED on the old base. I may give it a shot. But I'm just concerned I may wreck the LED. Link to comment Share on other sites More sharing options...
Northwoods Snowman Posted November 3, 2010 Share Posted November 3, 2010 Just cut carefully, and don't cut very deep. I don't guess I'll be doing any more work on my car. Got word from the insurance company that they're totaling it after my accident yesterday morning. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted November 4, 2010 Share Posted November 4, 2010 update on my gauge cluster.. turns out those superbrightled bulbs suck :-/ the LED behind the fuel gauge is flickering like a damn strobe light now.. the rest are fine.. Same happened with my HVAC controls (same vendor) but those started to go out last year :-/ I think Im going to try another vedor.. gauges still look nice but the damn led flickering is annoying at night. Link to comment Share on other sites More sharing options...
Northwoods Snowman Posted November 4, 2010 Share Posted November 4, 2010 Try pulling the bulb, bend the wire leads out from the base to about 45 degrees, and put the bulb back in. See if that doesn't fix your problem. If they are flickering it's a bad connection. Link to comment Share on other sites More sharing options...
amm203 Posted November 5, 2010 Share Posted November 5, 2010 Make sure all the contacts are clean, and tight. If the contacts started arcing, there could be a layer of carbon on them preventing current flow for an otherwise good bulb/LED. I found the LEDs I put in didn't fit tight so I had to bend the wires out a little to make sure I had good contact. Thanks for the feedback. I tried what you said. No light. I even tried using the light that is working on the left LCD and it did not light. The bulb that did not light up on the left LCD did work when put behind the right LCD. The contact point does not appear to have any carbon on it. Does this essentially mean it is an issue with the circuitry? Link to comment Share on other sites More sharing options...
sukaboy Posted November 5, 2010 Share Posted November 5, 2010 Just cut carefully, and don't cut very deep. I don't guess I'll be doing any more work on my car. Got word from the insurance company that they're totaling it after my accident yesterday morning. Hey I did it. Works. Thanks for the tip. Sorry about your car. Link to comment Share on other sites More sharing options...
W_Spoiler Posted January 16, 2011 Share Posted January 16, 2011 Saw the video - doesn't get more specific than that. But I think he was doing that on a 98. Is that procedure pretty close to what I would need to use for a 2002 Legacy GT? Link to comment Share on other sites More sharing options...
gimmie3steps138 Posted May 18, 2011 Share Posted May 18, 2011 Ok, my local subaru isnt any help, they wont or cant give me the bulb numbers and keep trying to sell me the gauge cluster and a new ac unit. all i need is the damn bulbs.. i also called superbrightled.com and they dont know either.. can someone please give me the right bulb info for a 1997 subaru legacy GT? all i need is.. all hvac/ac bulbs EXCEPT the green one under the buttons. so thats the speed dial, temp control and button icon bulb. also i need a hazard bulb and finally a low fuel light. i was thinking of changing all my bulbs for the ac and gauge cluster to white. does anyone know which leds and how many id need to change all of the gauge cluster and ac? please no guesses, i know someone on here has this info.. thanks everyone.. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted May 23, 2011 Share Posted May 23, 2011 Try pulling the bulb, bend the wire leads out from the base to about 45 degrees, and put the bulb back in. See if that doesn't fix your problem. If they are flickering it's a bad connection. hey sorry for the very late update.. crashed that car and got me an outback now. but I pulled the whole gauge cluster out and the LED's were dead all 4 of them.. Now I don't know if I want to buy those same one (5 LED) again.. I knew it was dead when I took it in the house and hooked it up on the bench.. For right now I will do my HVAC controls since the stock bulbs are blown on them. Link to comment Share on other sites More sharing options...
sukaboy Posted November 18, 2012 Share Posted November 18, 2012 OK, so here's a taste of what actually white gauges look like. I screwed up though and didn't get the fuel gauge completely cleaned up, but it's a good comparison for before and after. I put some mixed white LED's I had laying around in to see what it would look like and I like it. The blue looks better too now that I got the green gunk off the back of the gauges. It's more vibrant and not so dull. Hi Guys, I changed my dash to the instrument cluster to the BLUE LEDs and i'm not sure if it was like this in the beginning, but lately I've noticed that the needle is hard to see. It's not lit up. The numbers light up fine, but the needle is not lit up at all. Is there a bulb for the needle itself? How can I get the needle to be lit? Link to comment Share on other sites More sharing options...
sukaboy Posted November 19, 2012 Share Posted November 19, 2012 Hi Guys, I changed my dash to the instrument cluster to the BLUE LEDs and i'm not sure if it was like this in the beginning, but lately I've noticed that the needle is hard to see. It's not lit up. The numbers light up fine, but the needle is not lit up at all. Is there a bulb for the needle itself? How can I get the needle to be lit? I can't remember if it was like this from the beginning when I changed the bulbs. I thought I had taken pics way back, but I cannot find them. This is how it looks today. As you can see, or not see. The fuel gauge needle is not lit up at all. The speedometer is barely visible and the same goes with the RPM gauge. I bought the LEDs from SuperbrightLEDs.com this is what I installed in the instrument cluster. 3 | NEOx High Power LED Instrument bulb | | Blue NEOx-BHP 3mm NEO3-xHP ------------------------------------------------------------ 2 | 74-xHP3 Wedge Base LED bulb | | Blue 74-BHP3 ------------------------------------------------------------ 4 | WLED-xHP5 Wedge Base Bulb | | Blue WLED-BHP5 Link to comment Share on other sites More sharing options...
leviwhoelse Posted February 23, 2013 Share Posted February 23, 2013 With the new LED's in, can you still adjust the brightness with the twisty thing on the blinker switch?? Link to comment Share on other sites More sharing options...
sukaboy Posted February 24, 2013 Share Posted February 24, 2013 With the new LED's in, can you still adjust the brightness with the twisty thing on the blinker switch?? yes you can. Link to comment Share on other sites More sharing options...
carlthewebmaster Posted March 18, 2016 Share Posted March 18, 2016 Old thread, but this worked great on my 1996 Legacy wagon (which just turned twenty!) Went with the blue LEDs for the instrument cluster. Thanks OP for the video!!! Link to comment Share on other sites More sharing options...
