Scooby2.5 Posted October 4, 2009 Share Posted October 4, 2009 Will the steering rack from a 2007 Spec b fit in a 2005 legacy GT/outback XT sedan or wagon? Its 2.6 turns like the STI according to cars101.com which is better than the outback at 3.2 and the GT at 2.8 Link to comment Share on other sites More sharing options...
Beanboy Posted October 4, 2009 Share Posted October 4, 2009 Same exact rack at GT. If there is a different in lock-to-lock, it is suspension/wheel size dictating larger turning radius as listed, meaning the wheels can't physically turn as much, not a difference in the rack itself. -B http://www.standardshift.com Link to comment Share on other sites More sharing options...
Scooby2.5 Posted October 4, 2009 Author Share Posted October 4, 2009 So the 2.6 on the spec b and the 2.6 on the sti VS the 2.8 on the GT is not the steering gear? I guess it's just the outback that has the different gear at 3.2? Link to comment Share on other sites More sharing options...
Guest Posted October 4, 2009 Share Posted October 4, 2009 Same exact rack at GT. If there is a different in lock-to-lock, it is suspension/wheel size dictating larger turning radius as listed, meaning the wheels can't physically turn as much, not a difference in the rack itself. It's not exact same. I checked part #s and the part numbers for SpecB, incl. the 06 SpecB is different, and unique to all SpecBs. It indeed has to do with the larger wheels, it seems. The ratio is the same so it appears, the steering range is limited. SpecB per car101.com has larger turning radius: http://www.cars101.com/subaru/legacy/legacy2009.html Link to comment Share on other sites More sharing options...
Scooby2.5 Posted October 4, 2009 Author Share Posted October 4, 2009 Hey unclemat, the outback has a really short turning radius, would I be better off trying to find a legacy GT rack to get the quicker steering? what about an STI rack? when I looked at cars101 it showed the rack on teh spec B (2007) and the sti as 2.6 turns and the LGT as 2.8, the outback was 3.2 Thanks in advance Link to comment Share on other sites More sharing options...
Scooby2.5 Posted October 4, 2009 Author Share Posted October 4, 2009 here is the data on the 2006 wrx and wrx sti WRX Steering variable assist, speed sensitive rack-and-pinion. Quick Ratio: 16.5:1 STI (same as LGT??) Quick Ratio steering 15.0:1 Rack and Pinion, Leather Momo STi wheel WRX Turning radius: Lock-to-lock: 2.7 turns Turning circle: 35.4 ft STI Lock-to-lock 2.6 turns Turning circle: 37.4 ft Link to comment Share on other sites More sharing options...
Scooby2.5 Posted October 4, 2009 Author Share Posted October 4, 2009 Here is the 2005/2007 GT and spec B GT: Turning Circle: 35.4 ft (center of tires) GT: Steering wheel lock-to-lock 2.8 turns spec.B turning circle 38ft spec.B Steering wheel Lock-to-lock 2.6 turns Link to comment Share on other sites More sharing options...
Scooby2.5 Posted October 4, 2009 Author Share Posted October 4, 2009 Looks like the spec B is the same as the sti and the GT is inbetween the sti and the outback. Turning circle of the car: 35.4ft Turns, lock-to-lock 3.2 Link to comment Share on other sites More sharing options...
PGT Posted October 4, 2009 Share Posted October 4, 2009 you're forgetting camber....it has everything to do with turning circle. Link to comment Share on other sites More sharing options...
Guest Posted October 4, 2009 Share Posted October 4, 2009 Hey unclemat, the outback has a really short turning radius, would I be better off trying to find a legacy GT rack to get the quicker steering? what about an STI rack? when I looked at cars101 it showed the rack on teh spec B (2007) and the sti as 2.6 turns and the LGT as 2.8, the outback was 3.2 Thanks in advance Again, the answer is it is related to wheel diameter. I don't think any (sensibly) lowered non-SpecB LGT guys with larger wheels have any rubbing issues. Besides noone sane installs huge (overall - before someone says, they are 18" ) diameter wheels such as stock SpecB wheels. Just get regular Legacy rack, which should be pletiful in junkyards. Link to comment Share on other sites More sharing options...
scoobydoobie Posted October 5, 2009 Share Posted October 5, 2009 So the STI and LGT do not have the same steering rack? Link to comment Share on other sites More sharing options...
Scooby2.5 Posted October 5, 2009 Author Share Posted October 5, 2009 Again, the answer is it is related to wheel diameter. I don't think any (sensibly) lowered non-SpecB LGT guys with larger wheels have any rubbing issues. Besides noone sane installs huge (overall - before someone says, they are 18" ) diameter wheels such as stock SpecB wheels. Just get regular Legacy rack, which should be pletiful in junkyards. someone on the forum had a 2007 spec b rack with only 27000 on it so I was going to get that, but if the turning radius is that much worse I would want the LGT rack. Could you give us some part number comparisons unclemat? Link to comment Share on other sites More sharing options...
PGT Posted October 5, 2009 Share Posted October 5, 2009 someone on the forum had a 2007 spec b rack with only 27000 on it so I was going to get that, but if the turning radius is that much worse I would want the LGT rack. Could you give us some part number comparisons unclemat? why not get a donor rack and send it to Q-Rack and order exactly what you want? Link to comment Share on other sites More sharing options...
Scooby2.5 Posted October 5, 2009 Author Share Posted October 5, 2009 why not get a donor rack and send it to Q-Rack and order exactly what you want? Q-Rack? Link to comment Share on other sites More sharing options...
PGT Posted October 5, 2009 Share Posted October 5, 2009 Q-Rack? http://lmgtfy.com/?q=Q-Rack Link to comment Share on other sites More sharing options...
sportwagon Posted January 4, 2010 Share Posted January 4, 2010 http://lmgtfy.com/?q=Q-Rack That was so cool! I've never seen "let me google that for you" Link to comment Share on other sites More sharing options...
swaginwagin Posted June 16, 2017 Share Posted June 16, 2017 Has anyone performed the swap on an OBXT? Sent from my SM-N920T using Tapatalk Link to comment Share on other sites More sharing options...
Th3Franz Posted June 16, 2017 Share Posted June 16, 2017 People have swapped the new 15+ STI rack into an OBXT/LGT. Even quicker ratio. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
Scooby2.5 Posted June 16, 2017 Author Share Posted June 16, 2017 As Thefranz said i would go with the 2015. With that said yes the spec b rack would bolt right in...... Link to comment Share on other sites More sharing options...
swaginwagin Posted July 1, 2017 Share Posted July 1, 2017 But I guess people had issues with the u joint shaft? Sent from my SM-N920T using Tapatalk Link to comment Share on other sites More sharing options...
Underdog Posted July 1, 2017 Share Posted July 1, 2017 The Outback has spacers that drop the front subframe by roughly an inch, which means you need to use the OBXT u-joint. You can use the Perrin lockdown kit or cut and weld in a rod to eliminate the damper section. The Crimson Dynamo Link to comment Share on other sites More sharing options...
WRX USA Posted July 1, 2017 Share Posted July 1, 2017 I have a SpecB steering rack on my OBXT. I had it swapped at the same time I had the 6MT drivetrain swapped from a SpecB. The SpecB was a total and only had 65K and it didn't cost me anything extra for the parts and the labor, which is why I chose this over a 15+ STi swap. It did make a noticeable difference over the Outback rack. I also have the Perrin steering dampener lockdown. Link to comment Share on other sites More sharing options...
