will Audi style lights be the new halos?
YouAreABus
Has everyone seen the headlights Audi is putting on their new cars?
http://img.ledsmagazine.com/objects/news/3/10/23/AudiR82.jpg
I would love to do somethig like this to mine, we even have a similar "dip" in the lights. I'm not trying to be a poser, nor do I wish I had bought an Audi, I just think they look bad-ass. There are a few flexible LED strips available on EBay, and I'm not afraid to try it out, I just don't have the spare money right now. If I were to do it, I would just have them come on as running lights, or maybe turn signals. If the were turn signals wouldn't they have to be amber? If so, I would just do them as running lights.
What do you think?
  • Replies 81
  • Created
  • Last Reply
I think I like the A4's lights a little better. It looks like there are more bulbs and they are closer together. If I did it, I think they would come out more like this
http://www.latimes.com/media/photo/2008-06/40095164.jpg
EBay sells the LED strips in 24cm (about 9.5") and 48cm, it says they can be cut to fit every 3cm, but I think 24cm would be just about perfect.
My co-worker has a 2009 Audi A4 2.0T. The LED's are sweet as is the rear back up camera that has two lines to help navigate which bend depending on your steering wheel. Makes lining up to back into a spot extremely easy.
The Audi guys use the S6 LED strip (goes in the bumper) to retrofit on B6 and B7 A4/S4's. Would be much easier to use.
Any idea the price on those, and are the flexible (in case the contours are not identical)? The EBay kits are $30-$50 for a pair, I know you get what you pay for to an extent, but if the Audi parts are a few hundred dollars I may end up taking my chances.
It's already been done on a Legacy here.
http://www.legacy-hk.com/viewthread.php?tid=4553
Not my type of thing but I'll have to say that it does not look bad.
It's quite a simple mod to do too (same difficulty as clearing your headlights). It's only a flexible LED strip placed under the piece of semi transparent plastic insert at the bottom of the JDM lamp housing.
Edit:
Grr... you beat me to it grimbeaver!!
I was there when the lights were being installed (I helped out installing it). That car also had halos installed too but they burned out in less than a day. Didn't even have the chance to take a photo.
DOWNxSH1FT - That R32 is nice, but not quite what I am going for. That Saab's lights are pretty sexy too, I like that you can't see the LED's but that probalby has to do with the lens that is being used
Hanger - that was my intension, JK 8^)
Bastards! It's okay, that is still not quite what I had in mind. I really like the A4 lights exactaly, but the Saab lights are pretty cool as well, but probably much harder to do myself.
I guess it is rice by definition (all show no go, not my style at all) but I think they are so cool!
Ok I was sucked in.
I found LED strips on eBay for $12 each including shipping. So I bought some to add into the headlights.
http://i64.photobucket.com/albums/h163/gershon23/IMG_0885.jpg
http://i64.photobucket.com/albums/h163/gershon23/IMG_0887.jpg
http://i64.photobucket.com/albums/h163/gershon23/IMG_0890.jpg
I plan to add a switch for them but for now I have them hooked up to my parking lights.
those look nice! did you have to use glue or did they come with sticky stuff on them already?
258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos
+2 yeah, those are almost exactly what I was thinking! I would probably shorten them a little as well, the ones I saw on eBay were a little more expensive, but could be shortened every 3cm.
gershon - How long are those strips? Do you recall the vendor you bought them from? Also, you said you wired them to your parking lights, do they also flash with the turn signal?
