f1anatic Posted October 25, 2008 Share Posted October 25, 2008 So, I am looking for an explanation. When my 2005 Legacy GT (5MT) is on the lift at the mechanic, in neutral, engine shut off, all wheels in the air and if I rotate any one wheel clockwise, the other 3 also rotate in the same direction (clockwise). When my 2009 Forester XP (5 MT) is on the lift at the mechanic, in neutral, engine shut off, all wheels in the air and if I rotate any one wheel clockwise, only the one across from it but on the same axle will rotate in opposite direction. The other 2 wheels on the other axle will not rotate. So the Legacy GT with LSD it is kind of obvious...even when I rotate a front wheel. But what about the Forester ? I thought all wheels should still move should I turn any? What about the center differential ? And then what is the explanation with regards to the other wheel on the same axle spinning in the opposite direction ? How's that....good for the car when I drive it if under no load, I spin the left rear tire clockwise and the right rear spins counter clock wise. Mind you they spin easily as well...I know it has no LSDs...but come on.. Link to comment Share on other sites More sharing options...
rao Posted October 25, 2008 Share Posted October 25, 2008 I know it has no LSDs...but come on.. You answered your own question Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
f1anatic Posted October 27, 2008 Author Share Posted October 27, 2008 But Rob, why are they spinning in opposite directions ? Link to comment Share on other sites More sharing options...
JoeFromPA Posted October 27, 2008 Share Posted October 27, 2008 Cause if one wheel started to slip it would slow down/reverse the other wheel and pull you back in line? In for answer...that's a weird one. Joe Link to comment Share on other sites More sharing options...
rao Posted October 27, 2008 Share Posted October 27, 2008 Start here http://auto.howstuffworks.com/differential2.htm For diffs with LSD the tires will rotate in the same direction. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
LuckyBob Posted October 27, 2008 Share Posted October 27, 2008 From what I know all axels with an open diff will spin the other wheel in the opposite direction; which wheel did you spin while it was in the air for the GT? As to why it spinned in the opposite direction: http://auto.howstuffworks.com/differential2.htm Edit: Beat me to it. Damn coworkers distracting me. Link to comment Share on other sites More sharing options...
outahere Posted October 29, 2008 Share Posted October 29, 2008 .......... When my 2005 Legacy GT (5MT) is on the lift at the mechanic, in neutral, engine shut off, all wheels in the air and if I rotate any one wheel clockwise, the other 3 also rotate in the same direction (clockwise)........ On my '05 LGT with 5MT, only rotating a rear wheel will make the other 3 wheels rotate in the same direction. Rotating a front wheel will make only the one opposite wheel rotate, in the opposite direction. Link to comment Share on other sites More sharing options...
fweasel Posted October 29, 2008 Share Posted October 29, 2008 On my '05 LGT with 5MT, only rotating a rear wheel will make the other 3 wheels rotate in the same direction. Rotating a front wheel will make only the one opposite wheel rotate, in the opposite direction. you are right, he was wrong. LSD in the rear, open on the front ignore him, he'll go away. Link to comment Share on other sites More sharing options...
outahere Posted October 29, 2008 Share Posted October 29, 2008 .............. When my 2009 Forester XP (5 MT) is on the lift at the mechanic, in neutral, engine shut off, all wheels in the air and if I rotate any one wheel clockwise, only the one across from it but on the same axle will rotate in opposite direction. The other 2 wheels on the other axle will not rotate. ...... Your Forester must have open differentials, front and rear. Link to comment Share on other sites More sharing options...
f1anatic Posted October 29, 2008 Author Share Posted October 29, 2008 you are right, he was wrong. LSD in the rear, open on the front At the first oil change I will take a video. Link to comment Share on other sites More sharing options...
fweasel Posted October 29, 2008 Share Posted October 29, 2008 At the first oil change I will take a video. You haven't changed the oil in your Legacy yet? ignore him, he'll go away. Link to comment Share on other sites More sharing options...
f1anatic Posted October 30, 2008 Author Share Posted October 30, 2008 You haven't changed the oil in your Legacy yet? Well no cause it is waiting for you to change my fog lights :-)) If I rotate my either front wheel, my rears move as well when on the lift. Seriously do I have to take the bumper off for those foggers ? Link to comment Share on other sites More sharing options...
j255c Posted October 30, 2008 Share Posted October 30, 2008 no, i dont remember how i did it though, i think i just popped them out. 06 TB EVO IX SE stock turbo monster subaru hater Link to comment Share on other sites More sharing options...
fweasel Posted October 31, 2008 Share Posted October 31, 2008 Well no cause it is waiting for you to change my fog lights :-)) If I rotate my either front wheel, my rears move as well when on the lift. Seriously do I have to take the bumper off for those foggers ? no, just the engine splash shield. ignore him, he'll go away. Link to comment Share on other sites More sharing options...
whitetiger Posted November 4, 2008 Share Posted November 4, 2008 LSD axle = spin one wheel, opposite side spins in the same direction -true for Viscous couplings and clutchpack diffs Open diff axle= spin one wheel, opposite spins in opposite direction. Not sure what happens with a torsen/helical diff. Link to comment Share on other sites More sharing options...
