Legend Posted October 24, 2008 Posted October 24, 2008 I figured I'd be starting a thread sooner or later to discuss how to handle cold starting engines running E85 in cold temps. Different strategies can be employed, including mixing a gallon or two of straight gas, altering cold-start fueling tables, etc. My fuel trims tell me I am still running summer blend E85 (min 79% alcohol), so these thresholds might change for the better. Anyhow, here's my experience so far: ~45 degrees seems to be threshold where I can detect starting takes an extra crank. No big deal at all and wouldn't be noticeable if I werent looking for it. ~32 degrees it definitely takes a few cranks, but not many. I've tried counting the cranks and it's around 6-7 here, but still only takes 1.5s or so to start. ~24 degrees. Well, this is the coldest I've started it. I was parked overnight in the mountains Weds night and was interested to see how the start would go in the a.m. Just fine! Maybe 7-8 cranks and still started in 2.0s or less. Anybody have any different experience or is my experience on par with yours? I was anticipating further tweaking of my winter tune to deal with cold starts, but it might not be much of an issue at all. When/if I make changes, I'll post back here. My '05 LGT My '07 Supercharged Shelby
mickeyd2005 Posted October 25, 2008 Posted October 25, 2008 Good info. Frankly, I'm surprised it works that well.
mwiener2 Posted October 25, 2008 Posted October 25, 2008 mine takes just a tic less cranking that yours, but once it fires up, it's no different than gas My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons
Legend Posted December 15, 2008 Author Posted December 15, 2008 I had been really pleased with cold starting E85 in cold temps.... until tonight. I went out after work tonight after my car had sat for 9 hours and arctic cold set in. The temp was 1 degree F. The most cranking I had ever done was ~10 cranks or so and the coldest temp I had ever started was around 15-20F. I cranked for 10+ seconds and it didn't come close to starting. I waited about 10 seconds again and still nothing close to starting at all. I did this for 5 minutes, repeating cycles of 10-12 seconds of cranking followed by a 20 second break. I kept the breaks pretty short because I was attempting to build any heat I could. The battery grew weaker and the engine would occasionally hiccup/stumble. The battery light on the dash came on as I just had a little amperage left. I tried a couple more times and thank goodness the engine finally came to life and I gave it a touch of gas. It was about 8-10 minutes of attemting to start before it finally caught, and then it didn't want to idle. I had to hold the throttle and the lowest smooth rpms I could, which were around 2300rpms. Bottom line: Don't try to cold start pure E85 at zero degrees!! I immediately went to a gas station and added 2.5 gallons of 91oct to my nearly full tank of E85. I'm virtually certain that I have the FT headroom to accommodate it. There is a dramatic change in start-ability somewhere between 0F and 15F. My '05 LGT My '07 Supercharged Shelby
05pearl Posted December 15, 2008 Posted December 15, 2008 I wonder how the GM flex fuel vehicles handle starting w/ E85 at low temps?
mwiener2 Posted December 15, 2008 Posted December 15, 2008 legend, the poor idle may have been from killing the battery My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons
tommypenguin Posted December 15, 2008 Posted December 15, 2008 I was wondering how e85 would do in the blistering cold. I had to take a pic of my temp gauge this morning, it was really cold. Wiener, how is the temp in boulder? http://pictures.sprintpcs.com//mmps/RECIPIENT/001_1670b244389e289e_1/2?inviteToken=FEPr2N5qPUPmrhFzokJh&limitsize=258,258&outquality=90&squareoutput=255,255,255&ext=.jpg&iconifyVideo=true&wm=1
Legend Posted December 15, 2008 Author Posted December 15, 2008 I can't read your temp gauge... and I didn't know they put them down there (where my ashtray/lighter is). My temp gauge read -6F this a.m. I hope my starting goes smoother this afternoon... should be a little warmer and with some straight gas I thinnk I'll be okay. mwiener... interesting about the dead battery causing idle problems - thanks. My '05 LGT My '07 Supercharged Shelby
tommypenguin Posted December 15, 2008 Posted December 15, 2008 I can't read your temp gauge... and I didn't know they put them down there (where my ashtray/lighter is). My temp gauge read -6F this a.m. I hope my starting goes smoother this afternoon... should be a little warmer and with some straight gas I thinnk I'll be okay. mwiener... interesting about the dead battery causing idle problems - thanks. It says 1 degree:redface:, I took the pic with my cell phone. I moved my trip computer down with the AVO relocation kit when I cut out my cubby hole for my tv and deck. Back when I put in my in deck and tv there was no other option to get one in and I'm a car audio junky at heart and just couldn't stick with the stock HU. How old is your battery Legend?
05pearl Posted December 15, 2008 Posted December 15, 2008 time for a $40 block heater? http://www.brandsport.com/sub-a0910as100-subaru-legacy.html
tommypenguin Posted December 15, 2008 Posted December 15, 2008 time for a $40 block heater? http://www.brandsport.com/sub-a0910as100-subaru-legacy.html It would help for startups in the morning at the garage where there is access to an electric plug for the block heater. After the car has sat in a parking lot at work for 9 hours while the temp is frigid like today it won't do him much good without having a plug to hook the block heater up to.
Legend Posted December 15, 2008 Author Posted December 15, 2008 -5 degrees Set a record cold in Denver today. Brrrrrrrrrr. I'm happy to report that I had much better luck today starting at -5F versus yesterday starting at 0F (see above). Adding 2.5 gallons to ~13 gallons of E85 makes a huge difference. The starter cranked about a dozen times and I thought I had it started but it stumbled for a second and died. I let the key go and turned again to start and it started right up. Also, this time it idled perfectly right away which leads me to believe mwiener was right about it not wanting to idle last night because I killed the battery. I don't believe that was a tune issue. So... I don't think any tuning is necessary for cold starting with E85, other than ensuring that lambda has a lean margin of error up top and that fueling is dialed in well enough so that the LTFT's can adjust for the addition of ~20% straight gas. I'll be checking my LTFT's in a few days. I can't drive WOT right now due to ice and can't drive fast enough to set up AFR D, so it's certainly safe for the kind of driving I am doing now, and more than likely ready for WOT on dry pavement in a day or two... My '05 LGT My '07 Supercharged Shelby
Infamous1 Posted December 16, 2008 Posted December 16, 2008 Wheww thats cold, last night was the coldest I have seen out here in a while (45 degees )
mwiener2 Posted December 16, 2008 Posted December 16, 2008 It was -13 when I left the other day. Even on 91oct I had to crank a few times and she made some noises while she fired up (Fuel Pressure regulator issue) My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons
Legend Posted January 23, 2009 Author Posted January 23, 2009 Update: With tanks of nearly pure E85 winter seasonal blend, AFR Learning D has been -2% to -5%. Cold starts are only good down to around 20 degrees. Colder than that and expect minutes of cranking and possibly not starting at all. With tanks of winter E85 augmened with straight gas (13 gallons gas, 2.5 gallons winter E85 - I call it "E58" since it's somewhere around 58% alcohol at this point), AFR Learning D has been -6% to -10%. Tested down to -6F and starts rather quickly, in around 2 seconds of cranking (maybe 10 cranks). Conclusion: E85 can be run easily throughout the winter without map changes. The ecu has more than enough FT authority to deal with seasonal blends and augmentation with up to 2.5 gallons of straight gas. No knock increase observed in WOT logs despite lean E85 fueling and higher timing. Note that I did richen my WOT targets to around 0.77 lambda or so instead of the 0.81 I run for my summer tune, so technically I did make a map change. I'm not sure if I would of had to, however, but did so this year as a precaution. My '05 LGT My '07 Supercharged Shelby
tommypenguin Posted October 2, 2009 Posted October 2, 2009 Bump for update. Did your wideband indicate you needed to richen the tune a tad running on E58 despite not seeing knock, ie lean afr numbers in boost? I was curious as I don't want to run straight 91octane this winter and temps are quickly going down, I will log anyways when I attempt but if your findings indicate I for sure will need to richen up the tune might as well do it at some point next month to be ready for adding 91octane.
mickeyd2005 Posted October 2, 2009 Posted October 2, 2009 In the next romraider defs update, there might be some additional cold start parameters that might help.
tommypenguin Posted October 2, 2009 Posted October 2, 2009 That would be awesome. Any word on when the update is going to be released?
Legend Posted October 2, 2009 Author Posted October 2, 2009 Bump for update. Did your wideband indicate you needed to richen the tune a tad running on E58 despite not seeing knock, ie lean afr numbers in boost? I was curious as I don't want to run straight 91octane this winter and temps are quickly going down, I will log anyways when I attempt but if your findings indicate I for sure will need to richen up the tune might as well do it at some point next month to be ready for adding 91octane. I don't plan on making any map changes at all this year. Last year around this time I was concerned about how E85 would fare over the winter. I richened it a bit but don't think I had to. I'm running 0.80 lambda WOT now and think I will continue over the winter. I will get some fresh WOT logs this week in 60-70F temps and then make a point of getting logs again down around 30-40F and again around 10-20F. I've got two October road trips planned to some cold places... Eagle one time and Craig another... so the LGT will be getting some cold weather driving soon. Just about time for my brand new Blizzak LM-60's! My '05 LGT My '07 Supercharged Shelby
tommypenguin Posted October 2, 2009 Posted October 2, 2009 I don't plan on making any map changes at all this year. Last year around this time I was concerned about how E85 would fare over the winter. I richened it a bit but don't think I had to. I'm running 0.80 lambda WOT now and think I will continue over the winter. I will get some fresh WOT logs this week in 60-70F temps and then make a point of getting logs again down around 30-40F and again around 10-20F. I've got two October road trips planned to some cold places... Eagle one time and Craig another... so the LGT will be getting some cold weather driving soon. Just about time for my brand new Blizzak LM-60's! I bet those Blizzak's will kick arse. Thanks for the info. I will contribute my findings with cold starting on e85 as I encounter them. Off topic... I want to take some logs also when its 10-20degrees out. The coldest I have logged lately i believe it was 45 degrees on a morning and i was able to hit 286g/sec. When it was 90 degrees out I was consistently hitting high 260 g/sec to low 270 g/sec. Pretty significant increase with the cold weather also I'm going to be interested to see if my 50-80mph time improves when I put on my 17” winter wheels in culmination with the dense air.
mickeyd2005 Posted October 4, 2009 Posted October 4, 2009 That would be awesome. Any word on when the update is going to be released? Looks like today. http://www.romraider.com/forum/topic360.html
tommypenguin Posted October 4, 2009 Posted October 4, 2009 Thanks for the FYI I just did the download.
johnAWD Posted October 4, 2009 Posted October 4, 2009 Pretty much what I've been seeing as well. My car lives in a garage, so my cold start temps are somewhat higher, but I've seen as low as 40 on the in car thermometer. 6-7-8 cranks to get her to fire. I figured I'd be starting a thread sooner or later to discuss how to handle cold starting engines running E85 in cold temps. Different strategies can be employed, including mixing a gallon or two of straight gas, altering cold-start fueling tables, etc. My fuel trims tell me I am still running summer blend E85 (min 79% alcohol), so these thresholds might change for the better. Anyhow, here's my experience so far: ~45 degrees seems to be threshold where I can detect starting takes an extra crank. No big deal at all and wouldn't be noticeable if I werent looking for it. ~32 degrees it definitely takes a few cranks, but not many. I've tried counting the cranks and it's around 6-7 here, but still only takes 1.5s or so to start. ~24 degrees. Well, this is the coldest I've started it. I was parked overnight in the mountains Weds night and was interested to see how the start would go in the a.m. Just fine! Maybe 7-8 cranks and still started in 2.0s or less. Anybody have any different experience or is my experience on par with yours? I was anticipating further tweaking of my winter tune to deal with cold starts, but it might not be much of an issue at all. When/if I make changes, I'll post back here.
LGTspecB1657615261 Posted October 5, 2009 Posted October 5, 2009 It is starting to get cold here and it takes one or two more cranks to start... so I can imagine it will get worse over the even colder winter. The mornings here are in the 30's right now. Barely turn the key and let the engine half-crank, then pull back (just enough to get the starter to make noise). Wait a sec, then start the car normally. If I do this, the car starts the normal number of cranks every time. I read this somewhere else on this forum and so far it actually works.
tommypenguin Posted October 5, 2009 Posted October 5, 2009 Looks like today. http://www.romraider.com/forum/topic360.html Mickey, any suggestions on which changes to make to the cranking tables? Should I just add 30% pulse width to all the cranking tables for e85 in the qualifying temp cells that pertain to cold start temps. Then test and see if it makes a noticeable difference in cranking and continuing adding in 5% increments till I get startups dialed in? I apologize if I sound like a newb, I don’t truly understand the logic behind getting easy start ups with e85 in the cold. I assume the goal is to get enough fuel in the cold spraying that there is enough pump gas in the e85 mixture to spark an easier startup. At a certain threshold I will flood the engine with too much fuel at startup I assume. Any knowledge you could contribute on the subject would be appreciated.
