07GTLEG Posted September 30, 2008 Share Posted September 30, 2008 i have an 07 legacy.i was thinking of adding the factory sub.does it sound noticably better and how is the fit and quality? Link to comment Share on other sites More sharing options...
rao Posted September 30, 2008 Share Posted September 30, 2008 Sound is OK - if you are expecting it to sound like a pair of 12" subs in sealed boxes powered by 2000 watts you will be disappointed. Fit and quality are great. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
Beanboy Posted September 30, 2008 Share Posted September 30, 2008 What rao said. I put one in after about six months. I certainly noticed a difference in the positive, but I've always had OEM radio systems. Keep that in mind and note the size of it, and you won't be disappointed. -B http://www.standardshift.com Link to comment Share on other sites More sharing options...
07GTLEG Posted September 30, 2008 Author Share Posted September 30, 2008 is it a plug and play item.are the plugs there under the seat and ready to go? Link to comment Share on other sites More sharing options...
rao Posted October 1, 2008 Share Posted October 1, 2008 You have to pull the radio out, but it is a simple installation. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
LGT Dave Posted October 1, 2008 Share Posted October 1, 2008 The wiring for it is not already there. Like rao said, you'll have to pull the radio out and you'll also have to run the wiring for it down under the front driver's seat. Link to comment Share on other sites More sharing options...
slomoe2008 Posted October 1, 2008 Share Posted October 1, 2008 I added the factory sub. It was an easy install. Don't have anything a/m to compare it to but I am very satisfied. Plus for plug & play no hacked wires. Link to comment Share on other sites More sharing options...
VXCL Posted October 1, 2008 Share Posted October 1, 2008 +1 just picked one up on the black market. running the wire sucked, but other then that easy install. setup properly it easily doubles the bass while allowing you to drop the bass level down so the speakers can play clearer and louder before breaking up. would not buy one new but used for a $100 was worth it. MAYHEM #122/22 STS NNJR SCCA AUTOX4U.COM XENON RETRO GUIDE Link to comment Share on other sites More sharing options...
