Scotty Posted September 19, 2008 Share Posted September 19, 2008 I'm pretty sure the Scion's also use the same filter. I ended up cutting the same size filter for my gf's Scion. The standard furnace filters are a PITA to cut. I've been using the Web Absorber. http://www.webproducts.com/Detail.bok?no=46 It's got activated charcoal to reduce odors too. It's super easy to cut since it is two flat sheets. You get about 4+ filters out of one. They are available at Target for about $10. http://www.webproducts.com/stores/w/webproducts/catalog/wabsrbr-300.jpg Link to comment Share on other sites More sharing options...
outahere Posted September 20, 2008 Share Posted September 20, 2008 I installed the aforementioned $27 Wix filter last night................ The WIX/NAPA filter is $17 at fleetfilter.com. Link to comment Share on other sites More sharing options...
outahere Posted September 20, 2008 Share Posted September 20, 2008 Found out that the 2005+ Legacy's & Outbacks use the same air filtration filter as the Toyota FJ Cruiser. Several aftermarket filter companies make filters for the FJ Cruiser that don't list the Legacy/Outback, but they are the same. Usually quite a bit cheaper than the OEM filters. Purolator - C35516 Fram - CF10132 Beck/Arnley - 0422014 Are you sure about that Fram part number? Because I pull up #CF9846A when cross matching against other manufacturer filter numbers. Link to comment Share on other sites More sharing options...
Opie Posted September 20, 2008 Author Share Posted September 20, 2008 Are you sure about that Fram part number? Because I pull up #CF9846A when cross matching against other manufacturer filter numbers. That's what pops up on the Advanced Auto Parts website... Link to comment Share on other sites More sharing options...
BigBad Posted September 20, 2008 Share Posted September 20, 2008 Good info! Link to comment Share on other sites More sharing options...
outahere Posted September 20, 2008 Share Posted September 20, 2008 Found out that the 2005+ Legacy's & Outbacks use the same air filtration filter as the Toyota FJ Cruiser. .......................... Purolator - C35516 Fram - CF10132 Beck/Arnley - 0422014 If you go to the Fram site, and type in CF10132, these are the matches you get: BECK/ARNLEY 042-2024 BOSCH P3785 PUROLATOR C35479 TOYOTA 87139-06030 TOYOTA 87139-32010 TOYOTA 87139-YZZ05 WIX 24883 If you go to the Fram site, and type in CF9846A, these are the matches you get: BOSCH P3785 PUROLATOR C35516 WIX 24875 Link to comment Share on other sites More sharing options...
TC525 Posted September 20, 2008 Share Posted September 20, 2008 Is there a trick to getting the glovebox off? I did the walk through (which seemed to involve taking way too many interior pieces off) posted somewhere on this site, but didn't want to crank on the glovebox because it felt like it was being held by some fragile plastic clips that weren't visible. Oh, and good find with the FJ Cruiser filter! Link to comment Share on other sites More sharing options...
Opie Posted September 20, 2008 Author Share Posted September 20, 2008 http://www.partsamerica.com/product_images/aap/logos/pur_logo.gif Purolator Cabin Air Filter [/url]http://www.partsamerica.com/images/spaclear.gifPart Number: C35516 http://www.partsamerica.com/product_images/img/logos/fra.gif Fram Comfortaire Cabin Air Filter http://www.partsamerica.com/images/spaclear.gifPart Number: CF10132 http://www.partsamerica.com/product_images/img/logos/bar.gif Beck/Arnley Cabin Air Filter http://www.partsamerica.com/images/spaclear.gifPart Number: 0422014 From: http://www.partsamerica.com/ProductList.aspx?parttype=10&ptset=A&searchfor=Cabin+Air+Filter Link to comment Share on other sites More sharing options...
outahere Posted September 22, 2008 Share Posted September 22, 2008 WOW! PartsAmerica wants $49 for the Purolator. Link to comment Share on other sites More sharing options...
D_J Posted September 22, 2008 Share Posted September 22, 2008 Bosch was in stock + sale discount today at Kragen = $19.47 w/tax out the door. Original filter after 14,000 miles was toast - Link to comment Share on other sites More sharing options...
Opie Posted September 22, 2008 Author Share Posted September 22, 2008 WOW! PartsAmerica wants $49 for the Purolator. $28.88 online: http://www.partsamerica.com/ProductList.aspx?parttype=10&ptset=A&searchfor=Cabin+Air+Filter Link to comment Share on other sites More sharing options...
CTATV Posted September 22, 2008 Share Posted September 22, 2008 schweet ive been putting off changing mine i had it in to have the AC condensor replaced & they said i needed it done (for 140 bucks....) so ive been planning on doing it myself sometime this fall Link to comment Share on other sites More sharing options...
mbcracken Posted September 22, 2008 Share Posted September 22, 2008 $28.88 online: http://www.partsamerica.com/ProductList.aspx?parttype=10&ptset=A&searchfor=Cabin+Air+Filter When I put in my zipcode 98024, I get the price of $48.99. Sounds like pricing varies per zipcode for this purolator filter. But, thanks for the tips on the other pricing. I have done the 3M furnace filter hack and found it frustrating to get just right. I will look into these others for better deals. Cheers, Mike Link to comment Share on other sites More sharing options...
fishbone Posted September 22, 2008 Share Posted September 22, 2008 Amazon stocks the Purolator, $20.40 shipped directly from them [ame=http://www.amazon.com/Purolator-C35576-Cabin-Air-Filter/dp/B000E93GEE/ref=pd_bbs_1?ie=UTF8&s=automotive&qid=1222102474&sr=8-1]Amazon.com: Purolator C35576 Cabin Air Filter: Automotive[/ame] It qualifies for Super Saver Shipping so if you add $4.60 or so, you'll get it shipped for free. Otherwise they show that they'd charge me $5.26 shipped to Lincoln, NE Later edit: crap, that link is for a different model, C35576. I knew it was too good to be true Keep checking anyways, the C35516 might show up in stock eventually. Link to comment Share on other sites More sharing options...
VtspecB Posted September 22, 2008 Share Posted September 22, 2008 When I put in my zipcode 98024, I get the price of $48.99. Sounds like pricing varies per zipcode for this purolator filter. But, thanks for the tips on the other pricing. I have done the 3M furnace filter hack and found it frustrating to get just right. I will look into these others for better deals. Cheers, Mike That's zip code descrimination, report it to the Post Master General. Actually, I couldn't believe, but when I ran your zip code and mine ... sure enough there was a $20+ difference. Strange :spin: my vBGarage Link to comment Share on other sites More sharing options...
D_J Posted September 22, 2008 Share Posted September 22, 2008 Bosch p/n P3785 Kragen retail stores have plenty of stock for these, plus they have a 10% off sale. I found that the quality of the Bosch filter was outstanding and better than the stock part. In the future I plan on replacing every 10K miles cause it's relatively easy to do and costs $120 less than what the dealer charges. Link to comment Share on other sites More sharing options...
fishbone Posted September 22, 2008 Share Posted September 22, 2008 So the BOSCH P3785 is a definite fit on the Legacy? Link to comment Share on other sites More sharing options...
D_J Posted September 22, 2008 Share Posted September 22, 2008 So the BOSCH P3785 is a definite fit on the Legacy? Yes Opie was right. It is the exact same part that Toyota uses. Fits perfect, tucks into the filter tray tabs and no gaps. Kragen told me that Fram was special order only and cost $50. Then they cross-searched and found this Bosch in stock and a match for Subaru. Pep Boys had almost no cabin filters in stock, don't bother with them. Link to comment Share on other sites More sharing options...
mbcracken Posted September 22, 2008 Share Posted September 22, 2008 That's zip code descrimination, report it to the Post Master General. Actually, I couldn't believe, but when I ran your zip code and mine ... sure enough there was a $20+ difference. Strange :spin: Marketing folks seem to think that Fall City, a little podunk unincorporated town, has money. The local Tesoro gas station is also ripping us off. Super Unleaded can be had for about 15 cents/gal cheaper just 5 miles away (the main way in and out of town) and 26 cents/gal by driving about 12 miles away from here. Sorry for the thread creap. Back to filters... Cheers, mike Link to comment Share on other sites More sharing options...
Guest Posted September 23, 2008 Share Posted September 23, 2008 rockauto has the Bosch for $13.23 + shipping Strangely enough shipping cost for 4 filters is less than for 2 Link to comment Share on other sites More sharing options...
Mr. Sinister Posted September 23, 2008 Share Posted September 23, 2008 rockauto has the Bosch for $13.23 + shipping Strangely enough shipping cost for 4 filters is less than for 2 Thanks for the tip! I just picked up 4 of them and used coupon code 11764471022070 for an extra 5% off. Link to comment Share on other sites More sharing options...
ShrinerMonkey Posted September 23, 2008 Share Posted September 23, 2008 RockAuto also has this filter in their catalog for $8: TYC GENERA Part # 800005P Not sure about the quality but that is a really good deal. I am going to order one and I will report on the fit/quality. Link to comment Share on other sites More sharing options...
outahere Posted January 1, 2009 Share Posted January 1, 2009 RockAuto also has this filter in their catalog for $8: TYC GENERA Part # 800005P Not sure about the quality but that is a really good deal. I am going to order one and I will report on the fit/quality. How do you like the TYC filters? I see them for $4 at logical-source.com. A review at Amazon was not favorable about TYC filters. Link to comment Share on other sites More sharing options...
outahere Posted January 1, 2009 Share Posted January 1, 2009 Found out that the 2005+ Legacy's & Outbacks use the same air filtration filter as the Toyota FJ Cruiser. Several aftermarket filter companies make filters for the FJ Cruiser that don't list the Legacy/Outback, but they are the same. Usually quite a bit cheaper than the OEM filters. Purolator - C35516 Fram - CF10132 Beck/Arnley - 0422014 That Purolator # also fits these other Toyotas: TOYOTA 4Runner - V6 4.0L F.I. (VIN U) (1GR-FE) 2003-2008 TOYOTA 4Runner - V8 4.7L F.I. (VIN T) (2UZ-FE) 2003-2008 TOYOTA Celica - 4 cyl. 1.8L F.I. (1ZZ-FE) 2000 TOYOTA Celica - 4 cyl. 1.8L F.I. (VIN R) (1ZZ-FE) 2001-2005 TOYOTA Celica - 4 cyl. 1.8L F.I. (2ZZ-GE) 2000 TOYOTA Celica - 4 cyl. 1.8L F.I. (VIN Y) (2ZZ-GE) 2001-2005 TOYOTA FJ Cruiser - V6 4.0L F.I. (VIN U) (1GR-FE) 2007-2008 TOYOTA Prius - 4 cyl. 1.5L F.I. (VIN B) (1NZ-FXE) 2004-2008 Strangely enough, when I go to Purolators web site, and do a part look up for 2005 LGT, they do not show a cabin filter # Link to comment Share on other sites More sharing options...
Molal24 Posted January 2, 2009 Share Posted January 2, 2009 So the '05 Legacy's are the only ones that need you to tear your whole console apart. Is there any way of going around the tear apart stage? Link to comment Share on other sites More sharing options...
