wagonsled Posted November 20, 2013 Share Posted November 20, 2013 Two weeks ago I had my front left axle replaced due to torn CV boot. About two weeks later, I noticed oil drips on the garage floor. I checked my trans, engine and diff. fluids. Only the diff. fluids were low. In fact, the diff. fluid was below the low markings on the dip stick. Today I topped off the diff. with 75 90 Mobil 1. Drove around the block, .6 mile, parked. Half hour later, I smell oil...the entire quart of diff oil I topped was on the ground. What gives? Tomorrow I am driving to the mechanic who replaced the front left axle. It's almost like the oil was pumped out...What do you guys think is going on here? Thank you. Link to comment Share on other sites More sharing options...
MasAyinde Posted November 20, 2013 Share Posted November 20, 2013 Was the oil puddled under the drain plug? Link to comment Share on other sites More sharing options...
wagonsled Posted November 20, 2013 Share Posted November 20, 2013 Yes. It was puddled under the drain plug. But I don't think that's enough info to know exactly where it's leaking?? Link to comment Share on other sites More sharing options...
MasAyinde Posted November 20, 2013 Share Posted November 20, 2013 And did you use a new crush washer when tightening the drain plug? Link to comment Share on other sites More sharing options...
wagonsled Posted November 20, 2013 Share Posted November 20, 2013 The fluids were not drained at all. The front left axle was replaced and the fluid was topped off from under the hood, not at the diff. Link to comment Share on other sites More sharing options...
MasAyinde Posted November 20, 2013 Share Posted November 20, 2013 Ah, then you should see a leak coming from somewhere. 9/10 times, these things aren't magic. Link to comment Share on other sites More sharing options...
wagonsled Posted November 20, 2013 Share Posted November 20, 2013 That's funny! So you think there's a leak!? Link to comment Share on other sites More sharing options...
MasAyinde Posted November 20, 2013 Share Posted November 20, 2013 Shouldn't be that hard to trace where it's coming from. Nothing in that area is really obscured by anything Link to comment Share on other sites More sharing options...
caramall2 Posted November 20, 2013 Share Posted November 20, 2013 The ring seals around axel area on diff case can leak. Mine has and sometimes the seal is bad or ring is lose (looks kind of like sprocket ). Can add tracer of leak hard to see. Link to comment Share on other sites More sharing options...
ktmrider Posted November 20, 2013 Share Posted November 20, 2013 Highly likely they snagged or nicked the shaft seal in the tranny during the axle R&R. Easy to do BTW if not extremely careful. Link to comment Share on other sites More sharing options...
wagonsled Posted November 21, 2013 Share Posted November 21, 2013 You guys are right on que. The "seal" to the diff. had hardened and this is were my mechanic thinks it leaked. Then after he completed the job, he said, that if the fluids were topped off too much, that the excess will drain itself. Question..how does a rubber seal completely intact and covered with a little oil harden? Repair cost was $70 includes labor and $10 seal. Link to comment Share on other sites More sharing options...
specialB Posted February 2, 2014 Share Posted February 2, 2014 So when I pulled my axles out of the diff and separated my transmission I had a TON of fluid leaking out of the axle sockets, this doesn't necessarily mean the seals are shot right? I then again I remember I replaced the drivers side seal and it only seemed like it was leaking from the passenger side... Sent from my HTC6500LVW Link to comment Share on other sites More sharing options...
Drogos Posted August 3, 2015 Share Posted August 3, 2015 Hey guys, so axle seal part numbers are good across the board: 5MT, 6MT spec Bs and STIs? Link to comment Share on other sites More sharing options...
Max Capacity Posted August 7, 2015 Share Posted August 7, 2015 I seem to recall JmP's sticky in the 4th gen forum has a post about axle seals. You do know there is a left and a right seal. don't put them in backwards. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Drogos Posted August 11, 2015 Share Posted August 11, 2015 haven't spill a drop during axle swap. Seal in great shape Link to comment Share on other sites More sharing options...
RustyRuu Posted August 13, 2015 Share Posted August 13, 2015 my solution use one quart higher viscosity gear oil. use the three or whatever recommended quarts of (70w90 i think) gear oil then one quart higher viscosity oil (90w120 again dont remember for sure). 50k miles later no issues. no seals replaced and no more oil loss. nana na booboo Link to comment Share on other sites More sharing options...
Claw Posted May 29, 2017 Share Posted May 29, 2017 806735230 = oil seal, right or passenger side 806735240 = oil seal, left or driver side 806975010 = o-ring ( both sides same ) Just went in for the parts, new superseded part numbers: 806735300 = oil seal, right or passenger side 806735290 = oil seal, left or driver side Link to comment Share on other sites More sharing options...
axisofevol Posted February 15, 2018 Share Posted February 15, 2018 Just went in for the parts, new superseded part numbers: 806735300 = oil seal, right or passenger side 806735290 = oil seal, left or driver side The seal numbers are the same for the 5EAT differential, up to '09. The numbers change in '09 and newer. The O-rings for the 5EAT are part number 806984040. Link to comment Share on other sites More sharing options...
