cfdrumr Posted July 18, 2008 Share Posted July 18, 2008 I am currently running stock wheels with 215/45/17 Toyo Proxes4. What should I be running the tires at? I know some people prefer very inflated tires while others like them nice and soft... I am a daily driver on terrible Los Angeles streets and acceleration is important so I know I should be leaving mine right in the middle is not on the soft side... any help...? Link to comment Share on other sites More sharing options...
Gire Posted July 18, 2008 Share Posted July 18, 2008 I guess manufacturer 'suggests' 33 psi, but I like my 225-40-18 Kumho's to be at about 36 cold. Link to comment Share on other sites More sharing options...
cfdrumr Posted July 18, 2008 Author Share Posted July 18, 2008 seeing as it is summer in los angeles, the coldest it gets is mid-high 80's...how can I get a cold reading? Link to comment Share on other sites More sharing options...
Impulse Posted July 18, 2008 Share Posted July 18, 2008 cold being the relative term here, take a cold reading in the morning, just before you get in and drive when the tires have had a night to cool down. Link to comment Share on other sites More sharing options...
cfdrumr Posted July 18, 2008 Author Share Posted July 18, 2008 sounds good... I should shoot for Mid-Low 30's all around? Link to comment Share on other sites More sharing options...
mwiener2 Posted July 18, 2008 Share Posted July 18, 2008 Read the max psi on the side of the tire. that's gonna get you the best MPG and the harshest ride. Example: My tires max psi is 50psi. I run 44/42 and that gets me a good comprimise between MPG, handling, and ride comfort. The only way to know what works for you is to experiment and see what you like. Cold Inflation Pressure means the tire is the same temp as the ambient air.... before the car has been drivin. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
krzyss Posted July 18, 2008 Share Posted July 18, 2008 seeing as it is summer in los angeles, the coldest it gets is mid-high 80's...how can I get a cold reading? Cold means "before driving". Krzys Link to comment Share on other sites More sharing options...
praedet Posted July 18, 2008 Share Posted July 18, 2008 ^^^Also not sitting in direct sunlight... Link to comment Share on other sites More sharing options...
ilh Posted July 18, 2008 Share Posted July 18, 2008 Driving on them makes a huge difference. My F1As are set to 36/34 "cold", but I measured pressure after some highway driving in 94F and they were 44/42 "hot". Does max inflation pressure (e.g., 50psi) on tire refer to cold or hot? Link to comment Share on other sites More sharing options...
VTGT Posted July 18, 2008 Share Posted July 18, 2008 I run 40 front 38 rear on f1 asymmetric 225/45/17's Link to comment Share on other sites More sharing options...
mwiener2 Posted July 18, 2008 Share Posted July 18, 2008 Does max inflation pressure (e.g., 50psi) on tire refer to cold or hot? COLD My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
ilh Posted July 18, 2008 Share Posted July 18, 2008 Roger. Link to comment Share on other sites More sharing options...
peteyjr Posted August 9, 2008 Share Posted August 9, 2008 I run the same pressure as above poster 40 front and 38 rear on Falken Fk 452's . Then again the roads in South Fla are pretty smooth (at least on the highways). Link to comment Share on other sites More sharing options...
BigBad Posted August 9, 2008 Share Posted August 9, 2008 35F 33R on my conti's. Link to comment Share on other sites More sharing options...
str8dwn Posted August 10, 2008 Share Posted August 10, 2008 Put Proxes 4s on wife's RSX. They must be larger inside b./c they really needed 10psi more than factory specs to not look flat. Link to comment Share on other sites More sharing options...
racerbynight573 Posted August 11, 2008 Share Posted August 11, 2008 40F 38R on my goodyear eagle F1 A/S....not bad interms of ride comfort and good mileage Link to comment Share on other sites More sharing options...
BoozeRS05 Posted August 11, 2008 Share Posted August 11, 2008 I run my ContiExtreme's at 37f/35r, but I'm going to bump it up about 2psi all-around... EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
