SBT Posted September 27, 2011 Share Posted September 27, 2011 And in .csv format too. You may not need all of these parts, but if anything looks sketchy or worn, then replace it.Coolant Change Hard Parts.csv - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
PCvillain Posted October 11, 2011 Share Posted October 11, 2011 I called five different service depts and got some confusion but majority stated mid 2008 and newer uses blue coolant. Older than this recommends uses any green coolant but said Subaru green is better for engine block. One service guy, seemed most knowledgeable, said you might as well call it "Prestone" as it was the same. None said you need the additive. I asked all if the blue coolant was worth switching to and all agreed but one said you should never mix blue and green as the blue will coagulate and possible block radiator. The block drain plug is a hex bit 14mm. Unusual bloody thing but makes sense to save room. Link to comment Share on other sites More sharing options...
fishbone Posted October 11, 2011 Share Posted October 11, 2011 You're not supposed to mix the two because the green takes away the benefits of the long life blue. Is it even possible for a shade tree mechanic to get the old coolant completely out? Link to comment Share on other sites More sharing options...
RustyShackleford Posted October 11, 2011 Share Posted October 11, 2011 Mine is due and I'd like to avoid getting the Subaru green - not too expensive if you mail-order it, but shipping is expensive. Sure would like to confirm the Prestone thing - maybe the fine print on the Subaru stuff would tell you (I don't have any now). As far as draining, I don't see any reason to mess with the two items in the photograph above - the radiator drain valve and the 14mm hex block drains. I just remove both radiator hoses as well as the thermostat cover. This allows me to flush the bejesus out of both the radiator and the block. Link to comment Share on other sites More sharing options...
compsurge Posted October 12, 2011 Share Posted October 12, 2011 I believe the Subaru long life and Peak long life are identical. Link to comment Share on other sites More sharing options...
Subadozer Posted October 12, 2011 Share Posted October 12, 2011 You're not supposed to mix the two because the green takes away the benefits of the long life blue. Is it even possible for a shade tree mechanic to get the old coolant completely out? I did 2 drain-outs into the bucket and the second still had a noticeable green shade to it. I did 2 more fills and drains (including pulling the thermostat housing) and what was draining out on the 4th draining was pretty much clear. I ran the engine with the heat on between drains to make sure I was flushing the whole system. I'm confident that I got almost all of the green stuff out sufficiently but it took a while with having the let things cool enough to drain again. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 12, 2011 Share Posted October 12, 2011 Mine is due and I'd like to avoid getting the Subaru green - not too expensive if you mail-order it, but shipping is expensive. Sure would like to confirm the Prestone thing - maybe the fine print on the Subaru stuff would tell you (I don't have any now). As far as draining, I don't see any reason to mess with the two items in the photograph above - the radiator drain valve and the 14mm hex block drains. I just remove both radiator hoses as well as the thermostat cover. This allows me to flush the bejesus out of both the radiator and the block. My 05 has been on 50/50 Prestone since I replaced the timing belt and water pump 3 years ago. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Hanger Posted October 18, 2011 Share Posted October 18, 2011 May be Offtopic....:i have no idea about the subaru coolant conditioner until i found out my head gasket might be leaking. So... i had no idea whether or not when i had my coolant changed was the coolant conditioner used. Through google researches, the coolant conditioner helps prevent head gasket leakage and might also stop leakage. It may take it a while to actually stop the leak. Basically what happens is the little chunks in the coolant conditioner get caught in the area that is leaking. Then when exposed to heat and air, the chunks kind of harden and maybe even enlarge slightly, thus stopping the leak. The type of leak you are describing is where this type of conditioner or stop leak usually works. My question is... how do i add the subaru coolant conditioner? Just pop open the cap and fill? ○ ○ ○ Instagram: itshangertime :spin: ○ ○ ○ Link to comment Share on other sites More sharing options...
SBT Posted October 18, 2011 Share Posted October 18, 2011 Wait till it's cool, take off the radiator cap and add it there. Squeeze the top hose a bit before you take off the cap completely off to help push some coolant into the overflow tank and make room for that extra four ozs. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
legacyshawn Posted October 19, 2011 Share Posted October 19, 2011 yup, just make sure you shake. i remember giant globs of the stuff in the bottle that might potentially cause coolant flow blockage... SHAKE THE CONDITIONER BOTTLE PRIOR TO ADDING Link to comment Share on other sites More sharing options...
lordchilly Posted October 20, 2011 Share Posted October 20, 2011 Is this conditioner only for the green stuff or can it be used with the blue? Link to comment Share on other sites More sharing options...
SBT Posted October 20, 2011 Share Posted October 20, 2011 Use it with all Subaru coolant. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
Drogos Posted December 7, 2011 Share Posted December 7, 2011 So it looks like my coolant is low I don't even see it in overflow tank. Have no clue what's in there. I guess I will have to drain a little bit to be able to tell. So should I just add to the overflow when engine cold? Link to comment Share on other sites More sharing options...
mustangendsley Posted December 7, 2011 Share Posted December 7, 2011 Putting in a new allum rad with samco hoses this weekend. i got 50/50 prestone fluid to put into the rad. Should I get a new thermostate and gasket and also get the conditioner? No problems with over heating for me just wanted to know. I have 90k on the car. Link to comment Share on other sites More sharing options...
Drogos Posted December 7, 2011 Share Posted December 7, 2011 ok so my 08 spec b. built date 07/07 had green coolant. Can I just top it off when engine cold/off or should I start adding slowly when engine running and warm Link to comment Share on other sites More sharing options...
bmx045 Posted December 7, 2011 Share Posted December 7, 2011 fill it up at the radiator fill first, put cap back on, then fill it at the turbo coolant tank, leave cap off turbo tank, let it run with the heat on, add coolant while engine is running. Link to comment Share on other sites More sharing options...
Drogos Posted December 7, 2011 Share Posted December 7, 2011 fill it up at the radiator fill first, put cap back on, then fill it at the turbo coolant tank, leave cap off turbo tank, let it run with the heat on, add coolant while engine is running. Thanks. Radiator is topped off.....didn't check turbo tank and overflow is empty. So after I start the engine and put the heat on, should I add coolant to the open turbo tank of overflow tank? thanks again Link to comment Share on other sites More sharing options...
bmx045 Posted December 7, 2011 Share Posted December 7, 2011 Lol yes. Turbo res tank should be full and overflow at the max mark. The overflow is also a reserve tank for the system to pull from when its low! Run the engine with the turbo cap off and watch and add if needed. After a couple minutes recap and youre done. Link to comment Share on other sites More sharing options...
Drogos Posted December 9, 2011 Share Posted December 9, 2011 running engine with turbo cap off didn't work that well but in the end system is refilled so it's all good again Link to comment Share on other sites More sharing options...
mustangendsley Posted December 9, 2011 Share Posted December 9, 2011 I just got the Koyo rad in with blue samco hoses on. Go to Napa and get the non spill yellow funel that you put ontop of the radiator. All you have to do is fill the radiator with all other caps on until it dosn't take anymore. Fill the funnel up 1/3 of the way and turn the car on. Bubles will come up and when you see no more bubbles it is all done. Took me about 15 min of the car running. That is how subaru does it. The teck showed me. Link to comment Share on other sites More sharing options...
Zac88 Posted December 11, 2011 Share Posted December 11, 2011 have a friend doing a flush on mine and switching it to the new blue coolant and conditioner. All they had was the pre-mix in stock so will my mix be diluted too much due to having water left in the system from the flush? Link to comment Share on other sites More sharing options...
Subadozer Posted December 11, 2011 Share Posted December 11, 2011 have a friend doing a flush on mine and switching it to the new blue coolant and conditioner. All they had was the pre-mix in stock so will my mix be diluted too much due to having water left in the system from the flush? I think the blue only comes pre-mix (which I discovered can have a down side if you have to add to the system but can't get to the dealership). When I did my flush I pulled the thermostat housing each time so as to make sure as much as possible of the green stuff was gone and my new wouldn't be diluted too much. I was surprised how much remains in the system behind the thermostat. If you don't pull it it takes quite a while for what's behind to seep through the hole with the wiggle pin in it. While I had it apart I replaced the thermostat, gasket and 2 small heater hoses as well. Link to comment Share on other sites More sharing options...
Zac88 Posted December 11, 2011 Share Posted December 11, 2011 I think the blue only comes pre-mix (which I discovered can have a down side if you have to add to the system but can't get to the dealership). When I did my flush I pulled the thermostat housing each time so as to make sure as much as possible of the green stuff was gone and my new wouldn't be diluted too much. I was surprised how much remains in the system behind the thermostat. If you don't pull it it takes quite a while for what's behind to seep through the hole with the wiggle pin in it. While I had it apart I replaced the thermostat, gasket and 2 small heater hoses as well. yes I bought a new thermostat gasket as well. Link to comment Share on other sites More sharing options...
Ari_OutbackWagon Posted February 28, 2012 Share Posted February 28, 2012 FYI, I'm responsible for a $700 repair for using the Coolant Conditioner aka "RAD WELD". I would NEVER have put stop leak into a car so new if I knew what it really was. http://forums.vwvortex.com/showthread.php?5603480-Subaru-quot-Coolant-Conditioner-quot-clogged-my-radiator Link to comment Share on other sites More sharing options...
bmx045 Posted February 28, 2012 Share Posted February 28, 2012 did you put the conditioner in and then wait to start the car? Link to comment Share on other sites More sharing options...
