danny boy Posted June 8, 2011 Share Posted June 8, 2011 when installing saggy butt shims -after- installation of new struts/springs: Can it be done without removing the lower strut bolt? (undo the top 2 nuts, lower the hub/strut/control arm assembly, slip on the spacer, raise it up and bolt it on?) If new studs are required, can the old ones be pounded out without entirely removing the strut/spring assembly? Presumably, alignment is required? Help me to understand... Link to comment Share on other sites More sharing options...
paranoid56 Posted June 8, 2011 Share Posted June 8, 2011 With stock studs you can do just what you said. But with longer studs you will have to remove the whole strut. Link to comment Share on other sites More sharing options...
danny boy Posted June 8, 2011 Share Posted June 8, 2011 So is the consensus that 1/4" shims are max for stock studs, and 3/8" for Metro studs? Link to comment Share on other sites More sharing options...
paranoid56 Posted June 8, 2011 Share Posted June 8, 2011 Yep. Link to comment Share on other sites More sharing options...
m sprank Posted June 8, 2011 Share Posted June 8, 2011 Yes Dan. Link to comment Share on other sites More sharing options...
jproy12 Posted June 17, 2011 Share Posted June 17, 2011 So any of you ship these to Canada? I'm looking for 3/8'' with longer studs... I am also running a rear strut bar, which means I am cutting it tight! What kind of stud could be used? Its an M10 x 1.25, correct? JP Link to comment Share on other sites More sharing options...
m sprank Posted June 17, 2011 Share Posted June 17, 2011 I ship to Canada. USPS Priority Mail International. Canada Post has been delivering my packages, lol. Link to comment Share on other sites More sharing options...
jproy12 Posted June 17, 2011 Share Posted June 17, 2011 What kind of studs would I need for a 1/2" spacer with a rear strut bar? Don't want to cut it loose! JP Link to comment Share on other sites More sharing options...
m sprank Posted June 17, 2011 Share Posted June 17, 2011 No studs. With 1/2" spacers you need to switch to bolts and nuts. Link to comment Share on other sites More sharing options...
jproy12 Posted June 17, 2011 Share Posted June 17, 2011 Mike, can you explain how I would do this? If I use bolts, may as well get some real long ones! Thanks, JP Ps: could I weld the bolt on the strut mount? Link to comment Share on other sites More sharing options...
paranoid56 Posted June 17, 2011 Share Posted June 17, 2011 If you have a welder then tea. Just put the bolt from the bottom and tac the head. Link to comment Share on other sites More sharing options...
jproy12 Posted June 17, 2011 Share Posted June 17, 2011 Yea! I have access to a welder! JP Link to comment Share on other sites More sharing options...
m sprank Posted June 18, 2011 Share Posted June 18, 2011 Yup. That works like a champ. Link to comment Share on other sites More sharing options...
