HAMMER DOWN Posted March 15, 2008 Author Share Posted March 15, 2008 Should be fine. Got pics. Mine runs under the cross over pipe & don't touch at all. http://i99.photobucket.com/albums/l293/HAMMERDOWNGT/Subaru/0216081922.jpg http://i99.photobucket.com/albums/l293/HAMMERDOWNGT/Subaru/0216081924.jpg My next thing is to block off the air inllet hole at the botten of the air box. So it wont suck the heat off the dual filter manifold. I'm of drilling a hole the same size as the bottem in the side of the air box. Then run PVC piping down to the bottem of the inner fender cavity. Mike Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
Prime Power Posted March 15, 2008 Share Posted March 15, 2008 No pics, figuered yours would suffice if anyone wanted any. I have the spt intake with a k&n filter and still have the snorkel attached. Air flow should be fine. I don't think the top of the plate would get too hot. Especially with the snorkel feeding cold air to it. Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted March 15, 2008 Author Share Posted March 15, 2008 Oh, sounds that your good togo. The OEM air box almost sits right on top of the oil filter mount. So it time to build a snorkel for the OEM box. Mike Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
CTATV Posted March 26, 2008 Share Posted March 26, 2008 subscribe Link to comment Share on other sites More sharing options...
drd Posted September 3, 2008 Share Posted September 3, 2008 I noticed the bypass kit has changed to the BMK23 which has some slightly different adapters and twelve feet of hose. Was there much hose excess from the eight foot section? Also, is there adequate room at the location for the oil sampling petcock? Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted September 3, 2008 Author Share Posted September 3, 2008 (edited) I noticed the bypass kit has changed to the BMK23 which has some slightly different adapters and twelve feet of hose. Was there much hose excess from the eight foot section? Also, is there adequate room at the location for the oil sampling petcock? There was 19" of hose cut off both 8' hoses. A 12' hose is going to be a 1' short. Maybe you can run the hose a different way to make up the 1' . There's room for the oil sampling petcock, but it will be tight. Mike Edited September 4, 2008 by HAMMER DOWN Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
Prime Power Posted September 4, 2008 Share Posted September 4, 2008 No room on mine for the petcock and I had to order extra hose. This came out like a week after I installed mine. Argh. Link to comment Share on other sites More sharing options...
2006Specb122 Posted May 14, 2009 Share Posted May 14, 2009 Can someone give me cliff notes .... simply explain why someone would want to filter down to 2 microns. WHy add this to the LGT? Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted May 15, 2009 Author Share Posted May 15, 2009 The smaller the dirt you can filter out of the oil, the less wear on the motor. Most off the shelf oil filter, filter down between 20 & 40 microns. Amsoil full-flow oil filter is 15 microns & Amsoil By-Pass oil filter is 2 microns. This filtration system add 2qts. of oil to you motor. Which help keep the oil cool. In short, the cooler & cleaner you keep your oil. The long your oil, motor & turbo will last. Mike. Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
ViscousSquirrel Posted February 19, 2012 Share Posted February 19, 2012 Any updates on this? it's been a few years what are your impressions? Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted February 20, 2012 Author Share Posted February 20, 2012 Been using it for 4yrs. & 114700 miles. With no oil filtration system failures. At 15k OCI using Amsoil 0w-30 SSO & Ea filters. Went stage2+ at 174k & no shaft play on the original VF-40 turbo. Banjo filter bolts after 100k was clean. So I remove both filters from the two banjo bolts & reinstalled with new washers. Mike Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
Whatisit Posted February 20, 2012 Share Posted February 20, 2012 so at each oci, do you have to change all 3 oil filters? Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted February 20, 2012 Author Share Posted February 20, 2012 No, I only have 2 oil filters, 1 full flow, change every 15k & 1 By-pass, change every 30k. AMSOIL EaBP Filters have an efficiency of 98.7 percent at two microns. At normal operating RPMs the EaBP Filter will filter all of the oil in a typical five quart sump in less than 10 minutes. http://www.amsoil.com/storefront/eabp.aspx Mike Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
ViscousSquirrel Posted February 22, 2012 Share Posted February 22, 2012 Forgive me if I missed this somewhere but what was the cost of the total system and the cost for an oil change with filter? Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted February 22, 2012 Author Share Posted February 22, 2012 Forgive me if I missed this somewhere but what was the cost of the total system and the cost for an oil change with filter? The system as changed sense I bought mine 4 yrs. ago. Total cost for me, around $250 (tax, shipping, extra short 90deg. fitting & hose.) Oil change cost around $125 for 15k OCI (7 qts. of oil, 2 oil filters; 1 full flow; change every OCI, 1 By-pass; change every other OCI, 2-4 extra qts. oil do to oil consumption. Mike Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
ViscousSquirrel Posted February 23, 2012 Share Posted February 23, 2012 That's actually not bad Link to comment Share on other sites More sharing options...
Mega Users paintpollz Posted February 23, 2012 Mega Users Share Posted February 23, 2012 Mike, would you recommend 0w-30 w/o SSO and Ea filters w/o the bypass? Year around, In my location, at 6-8k OCI? It would be perfect to get the car to drink about a quart between that OCI. Maybe adjust OCI a little? "Remember Danny - Two wrongs don't make a right but three rights make a left." Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted February 23, 2012 Author Share Posted February 23, 2012 No, because I have no real world experience with any other 0w30 motor oils. My G\F's 05 WRX use same oil & OCI, but uses 1 single spin-on, Ea15k13 oil filter. The WRX as over 140k. I add 2-4qts over the 15k OCI. This is what I have told Max Capacity & others. That wanted or thinking about running Extends Drain Intervals. If your not going to run Extends Drain Intervals. (IMO at least 7.5k) Them IMO you can use cheaper oil & filter to protect up to Subaru's 3750 OCI. What you do is up to you, at your own risk. If you do Extends Drain Intervals (at least 7.5k) I would do your OA's at your current OCI. Up to you plan on changing you oil & filter. For the 1st oil change. After you AO's come back "Good for Continuous Use" up to whatever OCI you decide, under 15K. Then all you have to do is to watch for oil usage. Remember that Amsoil only Recommends extended drain intervals with their oils. If use with their EA oil filters one is available. Mike Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
Mega Users paintpollz Posted February 23, 2012 Mega Users Share Posted February 23, 2012 wait, what 0w30 are you running "Remember Danny - Two wrongs don't make a right but three rights make a left." Link to comment Share on other sites More sharing options...
Max Capacity Posted February 23, 2012 Share Posted February 23, 2012 I believe he's running this. https://www.amsoil.com/storefront/azo.aspx I run this in my Spec B https://www.amsoil.com/storefront/afl.aspx 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted February 23, 2012 Author Share Posted February 23, 2012 wait, what 0w30 are you running I believe he's running this. https://www.amsoil.com/storefront/azo.aspx I run this in my Spec B https://www.amsoil.com/storefront/afl.aspx Yes, Amsoil SSO = AMSOIL Signature Series Synthetic Motor Oil. Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
Mega Users paintpollz Posted February 24, 2012 Mega Users Share Posted February 24, 2012 you are confusing me mike "Remember Danny - Two wrongs don't make a right but three rights make a left." Link to comment Share on other sites More sharing options...
Mega Users paintpollz Posted February 24, 2012 Mega Users Share Posted February 24, 2012 i understand doing my OAs is important. assuming they are similar to yours, I feel like w/o the bypass, running ams 0w30 SSO /w Ea filters and 7-8k OCI would probably be ok. but then again, I need to do the OAs to really be sure. If you could confirm, you recommend doing one at 3750, and again at 7500 intervals? thanks, kevin "Remember Danny - Two wrongs don't make a right but three rights make a left." Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted February 24, 2012 Author Share Posted February 24, 2012 you are confusing me mike :spin: YOU; paintpollz Mike, would you recommend 0w-30 w/o SSO and Ea filters w/o the bypass? Year around, In my location, at 6-8k OCI? Did I misunderstand you. You wanted my recommend 0w-30 without SSO ( not running, Signature Series Oil. Amsoil top self oil) and Ea filters without running the bypass? Year around, In my location, at 6-8k OCI? I replied; No, because I have no real world experience with any other 0w30 motor oils. Answer to other 0w-30 oils My G\F's 05 WRX use same oil & OCI, but uses 1 single spin-on, Ea15k13 oil filter. The WRX as over 140k. I add 2-4qts over the 15k OCI. Answer to Ea filters without running the bypass? Year around, In my location, at 6-8k OCI? This is what I have told Max Capacity & others. That wanted or thinking about running Extends Drain Intervals. If your not going to run Extends Drain Intervals. (IMO at least 7.5k) Them IMO you can use cheaper oil & filter to protect up to Subaru's 3750 OCI. What you do is up to you, at your own risk. If you do Extends Drain Intervals (at least 7.5k) I would do your OA's at your current OCI. Up to you plan on changing you oil & filter. For the 1st oil change. After you AO's come back "Good for Continuous Use" up to whatever OCI you decide, under 15K. Then all you have to do is to watch for oil usage. Remember that Amsoil only Recommends extended drain intervals with their oils. If use with their EA oil filters one is available. Mike _______________________________________________________ It would be perfect to get the car to drink about a quart between that OCI. Maybe adjust OCI a little? i understand doing my OAs is important. assuming they are similar to yours, I feel like w/o the bypass, running ams 0w30 SSO /w Ea filters and 7-8k OCI would probably be ok. but then again, I need to do the OAs to really be sure. If you could confirm, you recommend doing one at 3750, and again at 7500 intervals? thanks, kevin Yes, that's why I told you about my G|F's 05 WRX. Every car is a different. Do OA's for your car. My G\F's 05 WRX use same oil (0w-30, SSO)& OCI,(15k) but uses 1 single spin-on, Ea15k13 oil filter. The WRX as over 140k. I add 2-4qts over the 15k OCI. Did I help clear up your confusion on what I typed? Mike Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
Mega Users paintpollz Posted February 24, 2012 Mega Users Share Posted February 24, 2012 OMG! My bad! I put an extra "w/o" before the "SSO" in there on mistake! Sorry mike. Everything is clear now. i meant Mike, "would you recommend 0w-30 SSO and Ea filters w/o the bypass? Year around, In my location, at 6-8k OCI" "Remember Danny - Two wrongs don't make a right but three rights make a left." Link to comment Share on other sites More sharing options...
