HAMMER DOWN Posted February 19, 2008 Posted February 19, 2008 (edited) Here you go. Pics. of the BMK-13 in 05 Legacy GT. It will filtrate your oil down to 2 microns & add 2qts. to oil system. The "NEEDS" is what you need besides what come in the BMK-13 installation Kit. Plus look at the pic. for other misc. parts. Links; https://www.amsoil.com/shop/by-product/filters-and-by-pass-systems/by-pass/filters-and-mounts/general-use-dual-remote-oil-bypass-unit/?code=BMK23-EA https://www.amsoil.com/bypassfilters...ions/BP152.pdf http://i99.photobucket.com/albums/l293/HAMMERDOWNGT/Subaru/0210082156.jpg http://i99.photobucket.com/albums/l293/HAMMERDOWNGT/Subaru/0210082155.jpg http://i99.photobucket.com/albums/l293/HAMMERDOWNGT/Subaru/0210082154.jpg http://i99.photobucket.com/albums/l293/HAMMERDOWNGT/Subaru/0210081135.jpghttp://i99.photobucket.com/albums/l293/HAMMERDOWNGT/Subaru/0210081403.jpghttp://i99.photobucket.com/albums/l293/HAMMERDOWNGT/Subaru/0210081402.jpg need (4) 3.5"-1/4-20 bolts to mount threw the frame. And another 8' of hose. http://i99.photobucket.com/albums/l293/HAMMERDOWNGT/Subaru/0210081403.jpg http://i99.photobucket.com/albums/l293/HAMMERDOWNGT/Subaru/0215081643.jpg http://i99.photobucket.com/albums/l293/HAMMERDOWNGT/Subaru/0216081202.jpg The EaO-26 is to long, had to cut out a releaf in the botten fender skirt. Pick short full flow filter from the installation sheet. http://i99.photobucket.com/albums/l293/HAMMERDOWNGT/Subaru/0216081756.jpg http://i99.photobucket.com/albums/l293/HAMMERDOWNGT/Subaru/0216081756a.jpg http://i99.photobucket.com/albums/l293/HAMMERDOWNGT/Subaru/0216081945.jpg need (2) 45 deg fittings http://i99.photobucket.com/albums/l293/HAMMERDOWNGT/Subaru/0216081854.jpg http://i99.photobucket.com/albums/l293/HAMMERDOWNGT/Subaru/0216081857.jpg http://i99.photobucket.com/albums/l293/HAMMERDOWNGT/Subaru/0216081851.jpg need (2) short 90deg. fittings. And a 2"in dia hot air tube. http://i99.photobucket.com/albums/l293/HAMMERDOWNGT/Subaru/0216081859a.jpg http://i99.photobucket.com/albums/l293/HAMMERDOWNGT/Subaru/0216081922.jpg http://i99.photobucket.com/albums/l293/HAMMERDOWNGT/Subaru/0216081924.jpg http://i99.photobucket.com/albums/l293/HAMMERDOWNGT/Subaru/0216082035.jpg Link for more pics. http://legacygt.com/forums/showpost.php?p=3619385&postcount=16 Mike Edited November 26, 2013 by HAMMER DOWN Mileage:331487 Retired/Sold
mwiener2 Posted February 19, 2008 Posted February 19, 2008 this would do more good https://www.amsoil.com/StoreFront/amk.aspx My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons
HAMMER DOWN Posted February 19, 2008 Author Posted February 19, 2008 ^^^ Yes, I look at it. But very little room for the dual filter kit. I didn't think I would of found room for that too. Now where I mounted the unit. If I go to a different CAI & releaf the inner wheel well alittle. It my just fit. Mike Mileage:331487 Retired/Sold
HAMMER DOWN Posted February 20, 2008 Author Posted February 20, 2008 A good read, https://www.amsoil.com/dealer/techservicesbulletin/TSB_oil_filter_particle_size.pdf Mike Mileage:331487 Retired/Sold
Prime Power Posted March 1, 2008 Posted March 1, 2008 Well, placed the order. I have leave 17-21 march so I will probably install it then. They wanted $50 for the 90 degree fittings. That is crazy, and I am a dealer. I will go to the local store and pay a few bucks instead. Ordered the eao-15, I hope that is smaller. Couldn't find a dimensions page. How long do you think it took you to install it all?
HAMMER DOWN Posted March 1, 2008 Author Posted March 1, 2008 Well, placed the order. I have leave 17-21 march so I will probably install it then. They wanted $50 for the 90 degree fittings. That is crazy, and I am a dealer. I will go to the local store and pay a few bucks instead. Ordered the eao-15, I hope that is smaller. Couldn't find a dimensions page. How long do you think it took you to install it all? Click on link, go down to part "B" Filter selection. Will give you Dia. & length. https://www.amsoil.com/bypassfilters...ions/BP152.pdf I tride to go to a Tractor supply store. They didn't have what I needed. I needed 90 deg. fitting. One end needed to be felmale the other male. The tractor supply store hand only double male ends. About 4 to 5 hrs. If you have everything you need. It took me a weekend, With no idea where I was mounting it & not having & or now what I really need until I found a place to mount it. Good luck, Mike Mileage:331487 Retired/Sold
hogmeat Posted March 1, 2008 Posted March 1, 2008 I'd rather just have normal filtering instead of having the risk of ripping/ruputuring/blowing off hoses that could kill my engine in the matter of seconds. I'm pleasantly surprised... It was most certainly worth the couple bucks and 10 mins of my time. CLICK HERE FOR THE HOGZAUST
warteaufmich Posted March 1, 2008 Posted March 1, 2008 Links; https://www.amsoil.com/storefront/bf.aspx "It draws approximately 10 percent of the oil pump’s capacity at any one time" Does this mean it reduces oil pressure by 10% too?
PhilT Posted March 1, 2008 Posted March 1, 2008 So basically you have no filtering until the oil gets up to operting temperature ? Double Award Winning Legacy GT Wagon
HAMMER DOWN Posted March 1, 2008 Author Posted March 1, 2008 "It draws approximately 10 percent of the oil pump’s capacity at any one time" Does this mean it reduces oil pressure by 10% too? Not that I'm a where of. I Didn't use the BMK-11 or 12. If you have any "?" can contact Amsoil here, http://www.amsoil.com/techservices.aspx In using the BMK-11 & 12. The 10% is what going threw the by-pass filter at any given time. That why they call it “partial-flow” . I used BMK-13 & like the other By-Pass system that connect right at the OEM's spin-on filter location. So making the a "full-flow" system. Which making it a close system and no worrys of oil pressure drop off. IMO the BMK-11 & 12, a "partial-flow" system can be a closed system if the return oil line is install below the oil level in the oil pan. Mike Mileage:331487 Retired/Sold
HAMMER DOWN Posted March 1, 2008 Author Posted March 1, 2008 So basically you have no filtering until the oil gets up to operting temperature ? No, but I'm where did you get that thought from. Mike Mileage:331487 Retired/Sold
Prime Power Posted March 1, 2008 Posted March 1, 2008 I have one on my truck, and have for about 3 years now. No problems. Also, all large diesel engines have these, and the power plants I work on also have bypass filters. The only concern one really should have with these, is to ask themself is it overboard? I say no because I plan to remove the banjo bolt filters and use this to cover the smaller particles.
warteaufmich Posted March 1, 2008 Posted March 1, 2008 I say no because I plan to remove the banjo bolt filters and use this to cover the smaller particles. You're installing the filter inline with the turbo oil supply line?
warteaufmich Posted March 1, 2008 Posted March 1, 2008 Sorry, stupid question, you don't need a 2 qt. filter right before the turbo. It just seems like one could have clean one-day-old oil and still have an iron or lead shaving make its way into the turbo - so in my mind at best there would be some small easily-serviceable filter in the turbo oil feed line. This has been discussed to death, but the only thing I ever hear about is people removing the banjo bolt filter and making the oil in the sump "cleaner" with synthentic oil or or shorter OCIs or bypass filters. I've never heard of anyone actually putting a serviceable filter right before the turbo though.
HAMMER DOWN Posted March 1, 2008 Author Posted March 1, 2008 AMSOIL Ea By-Pass Filter operates by filtering oil on a “partial-flow” basis. BMK-11 & 12 AMSOIL Ea By-Pass & dual By-Pass Filter operates by filtering oil on a “full-flow” basis. BMK- 13, 14, 15Ea, 16Ea & 17Ea warteaufmich, You seem . I won't speak for prime power. But from reading his post. I think he's doing the BMK-13 Dual filter kit, like I did. Mike Mileage:331487 Retired/Sold
warteaufmich Posted March 1, 2008 Posted March 1, 2008 warteaufmich, You seem . Yes, I often wonder why I don't just stfu.
Prime Power Posted March 8, 2008 Posted March 8, 2008 Well, almost ready. The extra line was on backorder so I will have to wait a week. I ran into hell finding those fitting, not exactly the ones you have but should work. I am having no luck though finding that hot air tubing. Where did you get it?
HAMMER DOWN Posted March 8, 2008 Author Posted March 8, 2008 ^^^ I got mine at CarQuest. You should be able to find it at NAPA or any other auto parts store. Another name for it is, "preheater tube." For carbed vehicels. Brings hot air off the exhaut manifold to the air intake. Mike Mileage:331487 Retired/Sold
HAMMER DOWN Posted March 8, 2008 Author Posted March 8, 2008 I ran into hell finding those fitting, not exactly the ones you have but should work. Becareful, you don't have much room. When I was done. I only have 1.5" or maybe 2", between the bottem of the skid pan & the 90deg. fittings going to the spin-on adapter. Mileage:331487 Retired/Sold
Prime Power Posted March 8, 2008 Posted March 8, 2008 I should have room then, I will get on this next week. I went to Oreilly and they didn't have the tube. I will try another store or 2 today.
Prime Power Posted March 15, 2008 Posted March 15, 2008 Well, got home after work and started. I have the bracket and bypass plate mounted. Tomorrow morning I will get the lines ran and the spin on adapter done. Then tidy it up. That was some work getting through that frame. Glad it is done and on.
HAMMER DOWN Posted March 15, 2008 Author Posted March 15, 2008 Did you use a 90deg. drill when you drilled your holes. 3" box frame + tight space to drill = PITA to have your holes line up. Did you find a hot air tube. If not you could ues some exhaust header wrap. To wrap around the oil supply lines instead. Mike Mileage:331487 Retired/Sold
Prime Power Posted March 15, 2008 Posted March 15, 2008 Yep, no other way to do it. I did find a hot air tube. It is resting against the down pipe, that is fine right? So glad I got it done. The filter I used protudes a little into the fender well but it doesn't appear it will hit. I turned the tires and it looks to have enough room. We will see.
