mschmidt Posted January 28, 2008 Share Posted January 28, 2008 Well, the LGT is at 42K and been at stage 2 for about 10K. The clutch is starting to slip so I'm going to remove the AP and take it in on Friday to see if they will cover it. I did think ahead and complaing about it a few times prior to 36K so maybe I will get lucky if I complain more. I don't feel like removing the UP/DP so it may be a hard sell. Let's say they are going to try and stick me with the $1,500 repair... What other options do I have? Last time I did some research the best option seemed to be an ACT clutch and WRX flywheel. This is a daily driver, but I like to drive "spirited" every once in awhile. Doesn't happen too often anymore with a 19month old and a preganant wife! Let me know guys! Mike Link to comment Share on other sites More sharing options...
PhillyWilly Posted January 28, 2008 Share Posted January 28, 2008 if you have stock parts i would revert to stock and try to get it covered. dont know what the chances are tho. Link to comment Share on other sites More sharing options...
HansGT Posted January 28, 2008 Share Posted January 28, 2008 This helps... Link to comment Share on other sites More sharing options...
HansGT Posted January 28, 2008 Share Posted January 28, 2008 Let's say they are going to try and stick me with the $1,500 repair... What other options do I have? Last time I did some research the best option seemed to be an ACT clutch and WRX flywheel. ACT HD clutch + 06 OEM WRX Fly here. No issue. Drives like stock. Holds like a mutha (stage 2+). If you have a Subaru Master Card and have Subie Bucks (or purchase them here...usually $75 on the $100) you can purchase everything from some online vendors which are dealerships like "thekingofparts". Or if you get the clutch from your installer they may knock some off the install....mine did. Your looking at about $1200 installed. 550 clutch + 200 fly + 450 install. Link to comment Share on other sites More sharing options...
mschmidt Posted January 28, 2008 Author Share Posted January 28, 2008 thanks guys... I planned on playing the dumb card saying the DP was there when I bought it used. I just don't have much time right now. Do you really think they can use the DP against me? I doubt they will see the UP. Link to comment Share on other sites More sharing options...
rc0032 Posted January 28, 2008 Share Posted January 28, 2008 if you have stock parts i would revert to stock and try to get it covered. dont know what the chances are tho. Hey **** you! You pay to play but thanks to ***holes like you my car cost me more than it should have. No go back in your hole you ***** Link to comment Share on other sites More sharing options...
Max Capacity Posted January 28, 2008 Share Posted January 28, 2008 Spec also makes a nice set up. I've had mine in for 15,000 miles. Check out Specs web site. I have there flywheel and 2+ clutch. There are a number threads about this. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
wichitalegacy Posted January 28, 2008 Share Posted January 28, 2008 ............. Link to comment Share on other sites More sharing options...
RobE Posted January 28, 2008 Share Posted January 28, 2008 Hey **** you! You pay to play but thanks to ***holes like you my car cost me more than it should have. No go back in your hole you ***** ^^^ What he said. You gotta pay to play. http://newenglandsubarus.com/ Link to comment Share on other sites More sharing options...
qikslvr Posted January 28, 2008 Share Posted January 28, 2008 Mine started slipping a little at 36K and lasted until 40K. Good luck with warranty since the clutch isn't covered as it is a wear item. I went with the SPEC Stage2 and LWFW. So far so good. I'm at 4K miles and the pedal feels like stock, all the chatter is gone and the release is smooth as stock now too. Hooks up great and hasn't slipped at all yet. I listed the HP levels for all the different stages in a review thread. Here is a link to it: http://legacygt.com/forums/showthread.php?t=78095&highlight=spec+clutch Let's kick this pig! Link to comment Share on other sites More sharing options...
ABPillinois Posted January 29, 2008 Share Posted January 29, 2008 Clutch is covered to 36000 they will replace once. Mine started slipping at 39k so no go on warranty. +1000 on the ACT clutch and OEM wrx flywheel what a great setup 1-2 shifts feel like you could rip the diffs out. cost me about $1100 + - a few :rolleyes:"All right, brain, I don't like you and you don't like me - so let's just do this and I'll get back to killing you with beer." Link to comment Share on other sites More sharing options...
mschmidt Posted January 29, 2008 Author Share Posted January 29, 2008 thanks guys... I will let you know how Friday goes. Link to comment Share on other sites More sharing options...
BLKGT5 Posted January 29, 2008 Share Posted January 29, 2008 My opinion might differ from those already posted, but if your looking for a stock feel then you'll have to stay stock. Their is no substitute for a dual mass flywheel. My lwfw and hd act setup becomes a chore in stop in go traffic with it wanting to either grab too hard or slip too much. I'm having throw out bearing issues and I'm just going to ditch it all for a stock setup. I might sounds crazy but hard launches isn't worth the drawbacks or the risk of destroying my transmission. Link to comment Share on other sites More sharing options...
SeeeeeYa Posted January 29, 2008 Share Posted January 29, 2008 Hey **** you! You pay to play but thanks to ***holes like you my car cost me more than it should have. No go back in your hole you ***** You diplomatic devil you Link to comment Share on other sites More sharing options...
PhillyWilly Posted January 29, 2008 Share Posted January 29, 2008 Hey **** you! You pay to play but thanks to ***holes like you my car cost me more than it should have. No go back in your hole you ***** like subaru hasn't screwed others before. how do you know the clutch wouldnt have went on a stock setup. its easy to talk shit on the internet isnt it? i'll bet you've never talked to anyone like that in peron. Link to comment Share on other sites More sharing options...
rc0032 Posted January 29, 2008 Share Posted January 29, 2008 like subaru hasn't screwed others before. how do you know the clutch wouldnt have went on a stock setup. ok :lol: its easy to talk shit on the internet isnt it? i'll bet you've never talked to anyone like that in peron. You might want to hedge that bet Link to comment Share on other sites More sharing options...
qikslvr Posted January 29, 2008 Share Posted January 29, 2008 i'll bet you've never talked to anyone like that in peron. You don't know him very well do you? Let's kick this pig! Link to comment Share on other sites More sharing options...
HansGT Posted January 29, 2008 Share Posted January 29, 2008 My lwfw and hd act setup becomes a chore in stop in go traffic with it wanting to either grab too hard or slip too much. GET THE OEM WRX FLY. FEELS LIKE STOCK! Link to comment Share on other sites More sharing options...
integroid Posted January 29, 2008 Share Posted January 29, 2008 Or you can get teh SPEC Clutch and stay with a Stock FW. Link to comment Share on other sites More sharing options...
mschmidt Posted January 29, 2008 Author Share Posted January 29, 2008 options options... thanks. Link to comment Share on other sites More sharing options...
HansGT Posted January 29, 2008 Share Posted January 29, 2008 Or you can get teh SPEC Clutch and stay with a Stock FW. sure if you want to spend $450 for a flywheel, yes that is an option. Honestly with the OEM WRX FLY + ACT HD and two months of driving I can't tell it isn't the same as the day I drove it off the Subaru lot when I first bought the car. Link to comment Share on other sites More sharing options...
mschmidt Posted January 29, 2008 Author Share Posted January 29, 2008 OK, OEM WRX flywheel seems to be a good way to go for me... As for the clutch, I don't plan on going past stage II and do put about 20K per year on my car with some stop and go traffic. I want something that can handle the power and that will not die on me in two years. Though, I would also like to maintain most of the stock drivability... Link to comment Share on other sites More sharing options...
HansGT Posted January 29, 2008 Share Posted January 29, 2008 ACT HD = 420ft.lbs (crank) max. Your most likely in the 330-350 range now. Link to comment Share on other sites More sharing options...
JoeFromPA Posted January 29, 2008 Share Posted January 29, 2008 Sounds like Act HD would be perfect, since you want 30% more torque capacity than you actually produce....330 x 1.3 = 429....so sounds like the ACT has ~ just enough reserve torque capacity to reliably handle the Stage II output. Am I wrong? This thread was great....WRX flywheel and ACT HD sounds like a great solution for those who just want to go stage II, want a reliable clutch and a slightly better than stock flywheel with stock driveability... IIRC, the WRX flywheel is a single mass design that's only a few pounds lighter than the stock dual-mass LGT flywheel, right? Does it spin up faster? Joe Link to comment Share on other sites More sharing options...
integroid Posted January 29, 2008 Share Posted January 29, 2008 sure if you want to spend $450 for a flywheel, yes that is an option. Honestly with the OEM WRX FLY + ACT HD and two months of driving I can't tell it isn't the same as the day I drove it off the Subaru lot when I first bought the car. He wanted options so I gave him one since he wanted the stock feel. You can also get a SPEC clutch and SPEC FW. ACT is not the only aftermarket company that makes a clutch/FW for our car. Link to comment Share on other sites More sharing options...
