enthusiast Posted July 30, 2007 Share Posted July 30, 2007 I do notice better shifting. The "notchiness" you have, have you done the shifter bushings? I am up for the Cripple Creek drive. But, if there is any drinking I am staying the night up there. My mod list Link to comment Share on other sites More sharing options...
bskey Posted July 30, 2007 Share Posted July 30, 2007 Ohhh... a sleepover! Pillow fight! life in spin cycle..... Link to comment Share on other sites More sharing options...
praedet Posted July 30, 2007 Author Share Posted July 30, 2007 ^^^ Hmm, subtle differences, but nothing major... According to the manual, you measure the fluid level on the Trans when hot. I was glad to find this out as the cold level is just barely above the low dot, but the hot is full Link to comment Share on other sites More sharing options...
chenc544 Posted July 30, 2007 Share Posted July 30, 2007 I do notice better shifting. The "notchiness" you have, have you done the shifter bushings? I still haven't put in the kartboy bushings, maybe I will give that a go. Thanks. Link to comment Share on other sites More sharing options...
mwiener2 Posted July 31, 2007 Share Posted July 31, 2007 Mike, I think that was the one I plugged in, so I am truly sorry. What is the difference between pushing it on all the way and the actual "installed" feel? I have to do this soon too just make sure the plug clicks in and you can't wiggle it or pull it out by the cord. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
praedet Posted July 31, 2007 Author Share Posted July 31, 2007 Oh, I plugged in the cords on the driver's side. On the passenger I just did the coil-pack on the plugs. I thought you meant the coil-pack was not fully engaged on the plug on #1. Then this wasn't my fault Have you found a new coil-pack yet? Link to comment Share on other sites More sharing options...
bskey Posted July 31, 2007 Share Posted July 31, 2007 I blame Rocky life in spin cycle..... Link to comment Share on other sites More sharing options...
praedet Posted July 31, 2007 Author Share Posted July 31, 2007 ^^^True Link to comment Share on other sites More sharing options...
mwiener2 Posted July 31, 2007 Share Posted July 31, 2007 i havn't looked yet. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
praedet Posted August 1, 2007 Author Share Posted August 1, 2007 Of note on the Subaru Trans oil... It is not an "Oh my god, what a difference" change, but I just notice that it is smoother, period. I notice this after the fact, when I realize there was no harshness, or not as much notchiness, on the drive in to work. I think it is more than a placebo effect... Link to comment Share on other sites More sharing options...
chenc544 Posted August 1, 2007 Share Posted August 1, 2007 ^^ Same here. I noticed the most improvement after it warms up. Link to comment Share on other sites More sharing options...
mwiener2 Posted August 2, 2007 Share Posted August 2, 2007 cool.. now lets change my oil!!! My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
scottybuckeye Posted August 2, 2007 Share Posted August 2, 2007 Yeah, me too. Oil change, tranny fluid change, coolant change. Then I think I'm good for my 30k mi service. Right? Link to comment Share on other sites More sharing options...
enthusiast Posted August 2, 2007 Share Posted August 2, 2007 MAINTENANCE DETAILS Vehicle: 2005 LEGACY 2.5 GT SEDAN Interval: 30000 miles / 30 month service Action Description Recommended Inspection Fuel systems, lines and connections Inspect Drive belt(s) [Except camshaft] Inspect Camshaft drive belt Replace Engine oil Replace Engine oil filter Perform Replace engine coolant and inspect cooling system, hoses and connections Replace Air cleaner element Inspect Transmission/Differential (Front & Rear) lubricants (Gear oil) Inspect Automatic transmission fluid Replace Brake fluid Inspect Disc brake pads and discs, front and rear axle boots and axle shaft joint portions Inspect Brake linings and drums Perform Inspect brake lines and check operation of parking and service brake system Inspect Clutch operation Inspect Steering and suspension Perform Rotate and Inspect Tires The above services should be performed at the mileage / time intervals indicated. To keep your vehicle running its best and ensure the continued safe operation of your Subaru, your dealer may also recommend additional inspections and services. Please contact your dealer for a list of these services. I was surprised that replacing transmission fluid was not on the list. My mod list Link to comment Share on other sites More sharing options...
chenc544 Posted August 2, 2007 Share Posted August 2, 2007 I was surprised that replacing transmission fluid was not on the list. Apparently the official schedule doesn't think the transmission or diff fluid ever need to be changed, just inspected. Link to comment Share on other sites More sharing options...
mwiener2 Posted August 3, 2007 Share Posted August 3, 2007 whats it say for 60k miles? My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
chenc544 Posted August 3, 2007 Share Posted August 3, 2007 whats it say for 60k miles? Replace oil, oil filter, spark plugs, fuel filter, air filter, coolant and brake fluid. Inspect everything else. Pretty much the same as 30k except for the spark plugs. Interestingly the fuel filter replacement is recommend for 30k, 60k, 90k but it's not required until 120k. Link to comment Share on other sites More sharing options...
scottybuckeye Posted August 3, 2007 Share Posted August 3, 2007 When should the fuel filter actually be replaced? Link to comment Share on other sites More sharing options...
mwiener2 Posted August 3, 2007 Share Posted August 3, 2007 Fuel filter can't even be replaced...... it's part of the fuel pump My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
scottybuckeye Posted August 3, 2007 Share Posted August 3, 2007 Well, fuel pump then. Link to comment Share on other sites More sharing options...
mwiener2 Posted August 3, 2007 Share Posted August 3, 2007 replace it when it get gets clogged and causes problems or when you put a bigger one in My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
scottybuckeye Posted August 11, 2007 Share Posted August 11, 2007 Okay guys, I know I'm late on posting my durty durty wheels. But here ya go (go ahead and laugh)... http://i116.photobucket.com/albums/o19/oftoast/GolfProsTennisHos016.jpg http://i116.photobucket.com/albums/o19/oftoast/GolfProsTennisHos015.jpg Link to comment Share on other sites More sharing options...
bskey Posted August 11, 2007 Share Posted August 11, 2007 Dude, those are some sweet wheel patterns! Are they custom?? life in spin cycle..... Link to comment Share on other sites More sharing options...
tommypenguin Posted August 11, 2007 Share Posted August 11, 2007 Looks pretty authentic to me, I love the dirt lines, we should get a group buy going on that finish for the rims:lol: Link to comment Share on other sites More sharing options...
scottybuckeye Posted August 13, 2007 Share Posted August 13, 2007 Dude, those are some sweet wheel patterns! Are they custom?? They are! I'm not sure I'm happy w/ them though. I wanna contact "Boner Brett" and get em redone. Link to comment Share on other sites More sharing options...
