the_marquis78 Posted April 17, 2007 Share Posted April 17, 2007 Ok, so entertain me, a relative newbie, this question. I rented a spring compressor from my local autopart store that looks like this < how do I use the compressor if I'm at this stage of the install: i have the strut off and on my table please help me!! Link to comment Share on other sites More sharing options...
rao Posted April 17, 2007 Share Posted April 17, 2007 You don't - you need the other type of compressor. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
the_marquis78 Posted April 17, 2007 Author Share Posted April 17, 2007 lame, why did the auto parts store give me this one? Link to comment Share on other sites More sharing options...
rao Posted April 17, 2007 Share Posted April 17, 2007 It is what you would use for a lot of cars, but as you discovered you need ones that attach from the outside.. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
the_marquis78 Posted April 18, 2007 Author Share Posted April 18, 2007 how do I get the top nut off the strut?? i've read several explanations but we can't seem to get it off...anyone have advice? Link to comment Share on other sites More sharing options...
itsme Posted April 18, 2007 Share Posted April 18, 2007 if you have air tools, an impact wrench should work. don't take the nut off till you have the spring compress. Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
super.duper.BL6 Posted April 18, 2007 Share Posted April 18, 2007 If working with regular hand tools and no vice, its much easier to first break the torque on the top nut while the spring/shock assembly is still on the car. The weight of the car acts as your vice....preventing the assembly from spinning around. Link to comment Share on other sites More sharing options...
AWDxBOOST Posted April 18, 2007 Share Posted April 18, 2007 you need a pass thru socket and an allen wrench to get the top bolt off i hit it with an air impact and got it off, but it was iffy getting it off that way Link to comment Share on other sites More sharing options...
the_marquis78 Posted April 18, 2007 Author Share Posted April 18, 2007 ok, we tried it on the other side and it did break the torque but it didn't seem to make any difference. will the spring noticeably lighten up when we break the torque on the still-connected strut? Link to comment Share on other sites More sharing options...
pillboy Posted April 18, 2007 Share Posted April 18, 2007 Step one: make sure medical insurance is paid up. It is still ugly. Link to comment Share on other sites More sharing options...
the_marquis78 Posted April 18, 2007 Author Share Posted April 18, 2007 what is a pass thru socket???? Link to comment Share on other sites More sharing options...
Waxiboy Posted April 18, 2007 Share Posted April 18, 2007 or you can use an offset box wrench Link to comment Share on other sites More sharing options...
NutBucket Posted April 18, 2007 Share Posted April 18, 2007 My ghetto-rigged method; 17mm deep socket Vice Grips 5 or 6 mm allen wrench. Worked as well as can be expected. My electric impact gun only managed to spin the shaft on the shock. Link to comment Share on other sites More sharing options...
hal9e3 Posted April 18, 2007 Share Posted April 18, 2007 or you can use an offset box wrench Good for getting the nut off but you need a crow's foot to torque it when you reinstall it. Link to comment Share on other sites More sharing options...
hutru01 Posted April 18, 2007 Share Posted April 18, 2007 The real question is why the hell is it that tight to begin with. This is exactly why I don't like to take my car to stealerships. Link to comment Share on other sites More sharing options...
AKSubie Posted April 18, 2007 Share Posted April 18, 2007 Good for getting the nut off but you need a crow's foot to torque it when you reinstall it. theres enough room to get the crows foot in there? Link to comment Share on other sites More sharing options...
BoxerGT2.5 Posted April 18, 2007 Share Posted April 18, 2007 Ok, so entertain me, a relative newbie, this question. I rented a spring compressor from my local autopart store that looks like this <[ATTACH]35432[/ATTACH] how do I use the compressor if I'm at this stage of the install: i have the strut off and on my table [ATTACH]35433[/ATTACH] please help me!! See that spring compressor sitting to the right of the shock in the last pick.....use those. To get the top nut off you have three options. Pass-thru socket, 17mm offset wrench, air impact (don't worry about taking it off with the impact, you just don't want to put it back on with it......ask PGT ) Wait till you get to the rears. OBAMA......One Big Ass Mistake America! Link to comment Share on other sites More sharing options...
hal9e3 Posted April 18, 2007 Share Posted April 18, 2007 theres enough room to get the crows foot in there? Yeah, but it takes a little work. I trimmed the rubber portion back, which prevents using the dust cap BTW, and used washers to raise the nut as close to the top of the strut shaft as possible w/o exposing any net threads. Link to comment Share on other sites More sharing options...
Waxiboy Posted April 18, 2007 Share Posted April 18, 2007 1. break the nut loose while still mounted on the car 2. remove struts 3. compress spring 4. dis-assemble You can re-torque when installed on the car. You think the front is hard? Wait 'till you get to the lower rear strut bolt Link to comment Share on other sites More sharing options...
the_marquis78 Posted April 19, 2007 Author Share Posted April 19, 2007 the only thing I worry about is that that the top nut of one of the struts might have gotten a little stripped when we were trying to get it off. Nothing too bad but I'm nervous to use air tools on it now. Link to comment Share on other sites More sharing options...
the_marquis78 Posted April 19, 2007 Author Share Posted April 19, 2007 and yeah I've heard only awesome things about that rear bolt that I just can't even wait!!!! it seems like it's just going to be a party Link to comment Share on other sites More sharing options...
FourMoBro Posted April 19, 2007 Share Posted April 19, 2007 and yeah I've heard only awesome things about that rear bolt that I just can't even wait!!!! it seems like it's just going to be a party rear bolt is easy: 1. liquid wrench 2. attach wrench/attach breaker bar 3. use the floor jack to jack up on breaker bar 4. once broken, move jack to support strut. 5. pound out bolt Link to comment Share on other sites More sharing options...
BoxerGT2.5 Posted April 19, 2007 Share Posted April 19, 2007 rear bolt is easy: 1. liquid wrench 2. attach wrench/attach breaker bar 3. use the floor jack to jack up on breaker bar 4. once broken, move jack to support strut. 5. pound out bolt Or you can just use a impact with a 6in extension to clear the rotor. OBAMA......One Big Ass Mistake America! Link to comment Share on other sites More sharing options...
jerm07 Posted July 18, 2007 Share Posted July 18, 2007 anyone want to sell there stock gt wagon springs Link to comment Share on other sites More sharing options...
vet Posted July 19, 2007 Share Posted July 19, 2007 If you use an air impact gun to break it loose how are you holding the center section which requires the 6mm allen/hex key? Link to comment Share on other sites More sharing options...
