Efinirx8 Posted July 19, 2007 Share Posted July 19, 2007 the impact gun is able to spin the center nut fast enough not to require the allen hex key. Link to comment Share on other sites More sharing options...
hal9e3 Posted July 19, 2007 Share Posted July 19, 2007 Frineds don't let friends use impact wrenches on strut nuts:) There's a tag attached to the top of the Tokico HTS (AKA Spec D) struts. Here's what it says: Attention Installer: Do not use an impact wrench on top mount shaft nut. ... Link to comment Share on other sites More sharing options...
Bun707 Posted August 7, 2007 Share Posted August 7, 2007 Frineds don't let friends use impact wrenches on strut nuts:) There's a tag attached to the top of the Tokico HTS (AKA Spec D) struts. Here's what it says: Attention Installer: Do not use an impact wrench on top mount shaft nut. ... The keyword there is "Installer". When you're removing it's not a problem to use an impact wrench. Just don't use one to install the nut on the top, you'll over torque the piss out of it. Bad news. Link to comment Share on other sites More sharing options...
