MiniStiGuy Posted October 5, 2011 Author Share Posted October 5, 2011 It's brighter because it overlays the driver side. If you had them on one at a time they would be the same brightness. Which lens holders and lens did you use? OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
Golf4283 Posted October 5, 2011 Share Posted October 5, 2011 I'm still looking for some OEM LGT shields if anyone has an extra pair. Lemme know. Link to comment Share on other sites More sharing options...
MiniStiGuy Posted October 5, 2011 Author Share Posted October 5, 2011 Extra until I take my lights apart when I get some time... Did Mr Luv not have any? OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
a.lim Posted October 6, 2011 Share Posted October 6, 2011 It's brighter because it overlays the driver side. If you had them on one at a time they would be the same brightness. Which lens holders and lens did you use? i used the rx holder. the e30 lens dropped right in i covered up one side at a time to see the actual output of each projector and the driver side is significantly lower. its also a lot less sharp. apparently the shield being off by 1mm will result in a big difference. i guess thats the issue. ill have to take apart my headlights again. Link to comment Share on other sites More sharing options...
Golf4283 Posted October 6, 2011 Share Posted October 6, 2011 Nah no one had any. Couple guys said they did but ended up not finding them. Keep me posted if you ever get your lights back apart. Link to comment Share on other sites More sharing options...
MiniStiGuy Posted October 6, 2011 Author Share Posted October 6, 2011 I was going to do it this weekend but it is suppose to rain so I don't want to bother unsealing them with it wet out. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
mr_luv Posted October 6, 2011 Share Posted October 6, 2011 I need some oem wiring harness off the housings. Pm me if ya got any. Mr.350 Link to comment Share on other sites More sharing options...
MiniStiGuy Posted October 7, 2011 Author Share Posted October 7, 2011 Lol I think I may have 1 but I'll have to dig through the garage to find it. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
Golf4283 Posted October 7, 2011 Share Posted October 7, 2011 Lemme look through my garage as well. I think I have 1 or 2 from replacement headlights I bought. Link to comment Share on other sites More sharing options...
Golf4283 Posted October 10, 2011 Share Posted October 10, 2011 I have 2 wiring harnesses. They're from replacement lights but they're the same. The wires are cutoff for the headlight bulb cause I couldn't remove them from the housings. They're brand new otherwise. Lemme know if you want them. I can send them your way. Link to comment Share on other sites More sharing options...
a.lim Posted November 27, 2011 Share Posted November 27, 2011 This is what a curved shield looks like I assume? http://i227.photobucket.com/albums/dd241/LNGasMan/IMG_1191-1.jpg] What shield is this on the left? Link to comment Share on other sites More sharing options...
MiniStiGuy Posted November 28, 2011 Author Share Posted November 28, 2011 I'm not sure who would possibly make that shield. It appears to be a HID shield though but doesn't have the top mounting locations that an MDX, RX330 non-asf (the right shield in that pic) and other's have that are identical to ours. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
a.lim Posted November 28, 2011 Share Posted November 28, 2011 im trying to find another shield to use with my rx330 bowl. i bent my stock ones. the one on the left looks like it would work perfect. i would guess the rx330 non-afs shield (right) wont fit inside our housing without heavy trimming.. Link to comment Share on other sites More sharing options...
MiniStiGuy Posted November 28, 2011 Author Share Posted November 28, 2011 What do you mean you "bent" the stock ones. Is it so bad that they can't be repaired? The MDX shield would be the best to use and a dremel is all that would be needed for the trimming of it. You just outline the stock one on it and cut accordingly. It actually has a better light spread then the stock one does because it allows more light out. You might be able to fit Corolla shields as they have the same setup as we do. As far as HID shields go there is cutting the MDX one or getting ahold of some 07 MDX shields (very very hard to find) there is also the RX8 shields from the HID lights (identical to RX330's but with the mounting locations like our cars also have. If you have the RX 330 non-asf shields I'd just say to do the trimming as it can be done in no time and installed. Or see if you can find someone with stock shields that will sell them. I have 1 stock shield that is unmodified and another that was trimmed a little. If you'd like them I'll gladly pack them and bring them back to CA with me later in December when I come home for X-mas. I can meet up with you somewhere like temecula or somewhere off the 5 in the irvine area and give them to you for just the gas money cost of like $10 that it takes for me to drive up from San Diego. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
a.lim Posted November 30, 2011 Share Posted November 30, 2011 What do you mean you "bent" the stock ones. Is it so bad that they can't be repaired? The MDX shield would be the best to use and a dremel is all that would be needed for the trimming of it. You just outline the stock one on it and cut accordingly. It actually has a better light spread then the stock one does because it allows more light out. You might be able to fit Corolla shields as they have the same setup as we do. As far as HID shields go there is cutting the MDX one or getting ahold of some 07 MDX shields (very very hard to find) there is also the RX8 shields from the HID lights (identical to RX330's but with the mounting locations like our cars also have. If you have the RX 330 non-asf shields I'd just say to do the trimming as it can be done in no time and installed. Or see if you can find someone with stock shields that will sell them. I have 1 stock shield that is unmodified and another that was trimmed a little. If you'd like them I'll gladly pack them and bring them back to CA with me later in December when I come home for X-mas. I can meet up with you somewhere like temecula or somewhere off the 5 in the irvine area and give them to you for just the gas money cost of like $10 that it takes for me to drive up from San Diego. My laziness is responsible for the bent shield. After testing my fully assembled retrofit I noticed the shield was a little sideways. Instead of prying apart the headlight again I took a long flathead screwdriver to the bulb opening and tried to put pressure on the side that was high. Ended up bending the step down on the cutoff. Result, my cutoff sharpness and cutoff was thrown off. I actually only need one legacy shield. Please bring! I will gladly offer you gas money. Or if you would rather ship, I would be willing to pay for shipping. Link to comment Share on other sites More sharing options...
MiniStiGuy Posted December 1, 2011 Author Share Posted December 1, 2011 Ok I'll bring one with me and PM you once I'm back in town so we can set something up. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
naimouasta Posted December 7, 2011 Share Posted December 7, 2011 I like the setup but I prefer a curved shield instead of a flat shield. I'm still debating taking them apart tonight and making some custom curved shields for them. sorry if i missed this somewhere but what are the advantages of a curved shield? Link to comment Share on other sites More sharing options...
MiniStiGuy Posted December 9, 2011 Author Share Posted December 9, 2011 a sharp beam all the way across the entire beam pattern. A flat shield is only going to have the correct optics in the center so you end up with a sharp center section but it goes fuzzier as you go out from the center. scroll down to the rx330 section on this page and you can see the comparo with the stock flat shield vs a custom curved shield. http://jvxdriver.com/beam_comparison.htm You'll notice that the curved shield has the beam not only sharper out on the edges but more distinctive. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
enzo.kz Posted December 18, 2011 Share Posted December 18, 2011 How can i buy non afs RX bowls? Got any part number? Thx, enzo. Link to comment Share on other sites More sharing options...
MiniStiGuy Posted December 18, 2011 Author Share Posted December 18, 2011 you can't just buy them that way. You have to either buy the entire headlight assembly or find someone that has removed them from it and is selling them. Search on ebay, hidplanet.com and other headlight forums. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
1-3-2-4 Posted June 26, 2015 Share Posted June 26, 2015 I just brought some non AFS RX330 projectors on TRS they were under clearance for $75 for the two of them because my stock headlights area getting cloudy I will be putting them in new replacements but with so many pages here I'm wondering what about the RX330 lens being replaced with one of the clear lenses that TRS sells? Link to comment Share on other sites More sharing options...
MiniStiGuy Posted June 27, 2015 Author Share Posted June 27, 2015 I believe the lens you would want would be the TSX one but I can't confirm that for sure. I ran E30 clear lens in mine. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
1-3-2-4 Posted June 27, 2015 Share Posted June 27, 2015 (edited) I ordered some lens loong time ago back when I thought they would fit the 2nd gen legacy JDM projectors.. but I can't remember the size of those projectors and I'm trying to find those lenses.. of course I find the boxes but no lenses in them Oh I heard they are 3" so nevermind Edited June 27, 2015 by 1-3-2-4 Link to comment Share on other sites More sharing options...
MiniStiGuy Posted June 27, 2015 Author Share Posted June 27, 2015 yeah the JDM units are 3" as you said. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
PutnamCO Posted July 7, 2015 Share Posted July 7, 2015 (edited) Anyone know if I can buy an OEM replacement headlight lens without the housing assembly? I have a set of RX300 retrofits that I really like, but one of the headlight lenses was cracked last week. Everything else looks to be in good shape and I would like to avoid swapping everything into another housing. I could also probably get a new headlight, take off the lens, and put it on my old one. I doubt the resale value of the housing assembly without a lens is very high. Edited July 8, 2015 by PutnamCO Link to comment Share on other sites More sharing options...
