HAMMER DOWN Posted April 28, 2013 Share Posted April 28, 2013 The info. you seek is here in the 1st. post & beyond. http://legacygt.com/forums/showthread.php/turbo-failure-wiki-173358.html Mike Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
LegacyGTurbo Posted April 29, 2013 Share Posted April 29, 2013 Btw; does anyone know where the 2nd Banjo bolt is located? I can't seem to find it to replace it. I found the one that is by the turbo but can't seem to find the other one. thanks Link to comment Share on other sites More sharing options...
LegacyGTurbo Posted April 29, 2013 Share Posted April 29, 2013 Can anyone verify that this turbo will replace my VF40 turbo? I think it does but i just wanted to double check that it does. Thanks for looking and i appreciate it much. http://i136.photobucket.com/albums/q174/truthyaj/Subaru%20Legacy%20Issues/Screenshot2013-04-29atApr2931510PM_zps8f23e9c9.png The link to the eBay is this http://www.ebay.com/itm/160513486717?item=160513486717&viewitem=&sspagename=ADME:X:AAQ:MOTORS:1123&vxp=mtr Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted April 29, 2013 Share Posted April 29, 2013 Btw; does anyone know where the 2nd Banjo bolt is located? I can't seem to find it to replace it. I found the one that is by the turbo but can't seem to find the other one. thanks The driver side Banjo filter bolt is right behind the top cam pulley cover. Pics. in post below. http://legacygt.com/forums/showpost.php?p=1326330&postcount=158 Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted April 29, 2013 Share Posted April 29, 2013 (edited) Can anyone verify that this turbo will replace my VF40 turbo? I think it does but i just wanted to double check that it does. Thanks for looking and i appreciate it much. http://i136.photobucket.com/albums/q174/truthyaj/Subaru%20Legacy%20Issues/Screenshot2013-04-29atApr2931510PM_zps8f23e9c9.png The link to the eBay is this http://www.ebay.com/itm/160513486717?item=160513486717&viewitem=&sspagename=ADME:X:AAQ:MOTORS:1123&vxp=mtr Nope, unless you have a PW TMIC or a FMIC. This will not fit LGT stock TMIC. Plus you'll need new tune at a min. to work right on the car. Read here for info. on turbo upgrade. http://legacygt.com/forums/showthread.php/turboi-wiki-twist-178684.html Edited April 29, 2013 by HAMMER DOWN Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
LegacyGTurbo Posted April 30, 2013 Share Posted April 30, 2013 Nope, unless you have a PW TMIC or a FMIC. This will not fit LGT stock TMIC. Plus you'll need new tune at a min. to work right on the car. Read here for info. on turbo upgrade. http://legacygt.com/forums/showthread.php/turboi-wiki-twist-178684.html Sorry for being a NOOB here but what is a "PW TMIC or a FMIC" regarding to? I think TMIC is some kind of inter-cooler. Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted April 30, 2013 Share Posted April 30, 2013 Ok type in PW TMIC or a FMIC" in any search engine & you will get your answer. http://images.search.yahoo.com/search/images;_ylt=A0PDoKrlOn9RBSEAcDiLuLkF?p=PW+TMIC+&ei=utf-8&fr=ush-mailn&fr2=sfp-img&y=Search http://images.search.yahoo.com/search/images;_ylt=A0PDoYA4O39RswsAw0GJzbkF?p=Subaru+FMIC&fr=ush-mailn&ei=utf-8&n=30&x=wrt&y=Search Search engine are your friend. Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
LegacyGTurbo Posted April 30, 2013 Share Posted April 30, 2013 Ok type in PW TMIC or a FMIC" in any search engine & you will get your answer. http://images.search.yahoo.com/search/images;_ylt=A0PDoKrlOn9RBSEAcDiLuLkF?p=PW+TMIC+&ei=utf-8&fr=ush-mailn&fr2=sfp-img&y=Search http://images.search.yahoo.com/search/images;_ylt=A0PDoYA4O39RswsAw0GJzbkF?p=Subaru+FMIC&fr=ush-mailn&ei=utf-8&n=30&x=wrt&y=Search Search engine are your friend. I got it! haha... Front Mount and Top Mount intercoolers I did a search on it in here but all i got was a bunch of TMIC and FMIC but didn't explain what it was. But yes, i should have done a search on Google instead. haha... Link to comment Share on other sites More sharing options...
Lambose5 Posted May 4, 2013 Share Posted May 4, 2013 Got my turbo and DP in today. Started it up and everything sounded pretty damn good. Small coolant leak which I think is sorted. One issue now is there's a "rattling", for lack of better words, at around 2600-3100 rpm. I think it's only in vacuum (not in boost MAYBE) Anyway it sounds like my V70 turbo wagon sounded when decided to sell it. Could it be cams? Or ya think the turbo? Hmm. I also wonder if it could be an oil pressure thing - maybe a result of those two "oil solenoids" that go in these cars..? Thanks. And thanks for all the help in getting my turbo done! Link to comment Share on other sites More sharing options...
Lambose5 Posted May 5, 2013 Share Posted May 5, 2013 PM return, What did you decide to do, replace hot side or return. Mike Oh - I didn't see this post. I decided to keep the turbo and swap the old hot side housing (turbine housing) over to the new turbo. Put the exhaust/DP back in got the turbo in there and started all the DP bolts and some other stuff (mainly the flimsy rubber hose that connects to the Compressor wheel flange..); then realized I couldn't get at that one UP stud to put the nut on, lol. So, I had to undo the DP bolts and the exhaust hanger below the DP, pull back DP and get that UP bolt on Yadda yadda, she started up first crank. Had a small coolant leak it seemed and it was the hard lines at the turbo; I gave them another...1/8-1/4 turn and it was solved. The turbo guy is supposed to refund me $100.00 for the wac turbo Might post some pics tomorrow. I spent a good 7 hrs today cleaning, detailing, waxing etc. and I didn't even get to the leather. Then work for 7 hrs. Thanks to everyone for the help. Link to comment Share on other sites More sharing options...
TheBlackPearl Posted August 21, 2013 Share Posted August 21, 2013 Thank you very much for taking the time to do this. It just helped me immensely! Self proclaimed PNW Craiglist find of the day Champion, April 2014. Link to comment Share on other sites More sharing options...
dahoseman Posted April 28, 2014 Share Posted April 28, 2014 Thanks for the write-up. The pictures and descriptions are pretty useful. I reviewed this before attempting to replacing my 16G with another turbo. Unfortunately, I snapped off the third turbo-up bolt that sits underneath the compressor, soooo I ended up reinstalling everything (minus one bolt) so I could decide what to do Link to comment Share on other sites More sharing options...
wcbjr Posted April 5, 2017 Author Share Posted April 5, 2017 Bump. I forgot what I was supposed to remember. Link to comment Share on other sites More sharing options...
Rhitter Posted April 5, 2017 Share Posted April 5, 2017 So umm, what are you bumping this for? Just enjoy finding 3 year old threads to send back to the top? My OBXT build Link to comment Share on other sites More sharing options...
wcbjr Posted April 5, 2017 Author Share Posted April 5, 2017 I hadnt even logged in for 3 years. Surprised my pics were still on the first page. Meh. Bye for another 3 years! I forgot what I was supposed to remember. Link to comment Share on other sites More sharing options...
swimboy1993 Posted April 20, 2019 Share Posted April 20, 2019 Thanks for writing this up, super helpful! Link to comment Share on other sites More sharing options...
gimpydingo Posted August 11, 2020 Share Posted August 11, 2020 Very helpful. I plan on rebuilding my turbo soon with all this non drive time. Link to comment Share on other sites More sharing options...
