GTTuner Posted January 16, 2007 Share Posted January 16, 2007 I decided to do some mod's to my headlights. HOW THE &@%!V DO YOU GET THE BUTYL TAPE APART WITHOUT WRECKING THE HOUSING!!!!! Pardon my frustration, but those things are stuck together like they had one fall apart once! Any tricks or tips for pulling the lens's off would be helpful. Thanks Link to comment Share on other sites More sharing options...
pwdrdayz Posted January 16, 2007 Share Posted January 16, 2007 There are detailed instructions in the Walkthrough section. You can either use a heat gun or bake them in the oven to soften the glue. Link: http://www.legacygt.com/forums/showthread.php?t=3737 Hope that helps. Link to comment Share on other sites More sharing options...
edmundu Posted January 16, 2007 Share Posted January 16, 2007 Oven method is more fool proof, as local overheating of one area can deform the housing. Plus you have to move fast with the heat gun to keep from having the butyl harden again. Link to comment Share on other sites More sharing options...
Underdog Posted January 16, 2007 Share Posted January 16, 2007 I literally just finished getting mine apart... A big ole heat gun and starting at the turn signal end. leverage and heat are the key... Good luck! It helps to have someone holding the heat gun as you pry. The Crimson Dynamo Link to comment Share on other sites More sharing options...
GTTuner Posted January 16, 2007 Author Share Posted January 16, 2007 Thanks guys. I did consider putting them in the oven for a bit, but my wife was bitching about the transmission in the bath tub! I was horified at how strong that sealer is. All I want to do is remove the reflectors, put some LED's in for the signals and paint the greay areas black. Opinions please: Should I use flat black paint or gloss? I was considering using that new plastic paint. No prep is necessary except for degreasing and tack down. I'm not sure if gloss or flat would look/function better. Thanks for the link pwdrdayz! Link to comment Share on other sites More sharing options...
edmundu Posted January 16, 2007 Share Posted January 16, 2007 I would say flat, leave the reflective surfaces for the lights! Link to comment Share on other sites More sharing options...
GTTuner Posted January 16, 2007 Author Share Posted January 16, 2007 ^^^^^^ agreed. The gloss would reflect some light, flat would absorb. Link to comment Share on other sites More sharing options...
Underdog Posted January 17, 2007 Share Posted January 17, 2007 I'm making mine in two a relaxed two-day project and I went to chose bulbs today... I went with the silverstar turn signals which have a silver-blueish appearance and light up amber... I will post pics in my thread when I'm finished. Can't wait to see yours too... I don't see the grey areas you're talking about. The Crimson Dynamo Link to comment Share on other sites More sharing options...
VXCL Posted January 17, 2007 Share Posted January 17, 2007 click link in sig and go to first page. you will be gald you did. peace start from the inner corner not the amber end. MAYHEM #122/22 STS NNJR SCCA AUTOX4U.COM XENON RETRO GUIDE Link to comment Share on other sites More sharing options...
Underdog Posted January 17, 2007 Share Posted January 17, 2007 Holy detailed write-up... nice job! I'm too satisfied with the stock projectors to go and do something like that... I only wanted the cleared out lights so there was no disruption to the GRP/chrome/black color scheme. And I had much more luck starting from the amber end heating the seam on the corner and prying with the turn signal hole and the top outside attachment point as places to grab. But... he's probably done by now anyway! The Crimson Dynamo Link to comment Share on other sites More sharing options...
VXCL Posted January 17, 2007 Share Posted January 17, 2007 Holy detailed write-up... nice job! I'm too satisfied with the stock projectors to go and do something like that... I only wanted the cleared out lights so there was no disruption to the GRP/chrome/black color scheme. And I had much more luck starting from the amber end heating the seam on the corner and prying with the turn signal hole and the top outside attachment point as places to grab. But... he's probably done by now anyway! reason i say start from the inner side is becuase most end up messing the housing up from prying, so if you do it only there you won't see it. MAYHEM #122/22 STS NNJR SCCA AUTOX4U.COM XENON RETRO GUIDE Link to comment Share on other sites More sharing options...
GTTuner Posted January 18, 2007 Author Share Posted January 18, 2007 Awesome advice. The oven method works great. Thank you everyone. BTW.....Underdog, yours is an 06 and I think the entire light is chrome. The 05's were similar to a dark argent grey around the reflectors. Silver stars, I have them too. They will shine a nice blueish hue once the reflectors are gone. Good luck, and take your time! My car is down fore the weekend. I got one light apart last night. The look on my wifes face when I pulled the light out of the oven was priceless. Link to comment Share on other sites More sharing options...
