m sprank Posted January 21, 2011 Share Posted January 21, 2011 What??? It's ($180) for two hours of labor and $50 TB = ($230 tops) unless you add-in a new water pump ($100) and TB Tensioner ($110) - then you're looking at ~$500 tops (including labor). You can do a timing belt in 2 hours? Your my hero! Dale Most places charge about $1k just for the timing belt service. This includes water pump and pulleys. Timing belt is a good 4-5 hour job. Radiator has to come out, must have proper tools to hold cams and set belt. If you are getting quoted $500 with parts go for it (if you trust them). Because some one should call the Sheriff.. You just robbed the place. Timing belt, pulleys and water pump are $340 plus shipping. Even for a 2.5i it is not $500. Link to comment Share on other sites More sharing options...
SBT Posted January 22, 2011 Share Posted January 22, 2011 Mike - the prices I quoted above for Hanger's 2.5 SOHC were off of 1stsubaruparts.com. And I should have added in another $40 for coolant - my bad. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
m sprank Posted January 22, 2011 Share Posted January 22, 2011 Parts, yes. You can get parts for less than $500. I charge $340 for a Gates timing belt, water pump, pulleys and tensioner (for an LGT). Add in coolant for less than $40. Its the labor. Most places want $500 for parts and another $500 or so for labor. 2.5i is not much easier than LGT. Process is 90% the same. If Michael is short funds, I would just have the two services done separately. No matter where he brings it. Link to comment Share on other sites More sharing options...
havanahjoe Posted April 12, 2011 Share Posted April 12, 2011 Hey guys, I've been putting up with my squeaky brakes for far too long. I am officially over them and will do whatever is needed to get them to stop squeaking. I apparently have plenty left on my front pads and half way on the rears. Are there any respectable shops in San Diego or within a 100 mile radius that can do a good job? Or, can anyone recommend a replacement/upgrade that will make me happy? I'm still on stock wheels, not planning on replacing those at the moment. Is there anything decent that will still allow me to use the stock wheels? If not, is it worth going all the way and get new wheels to fit better brakes? Thanks! Link to comment Share on other sites More sharing options...
bakabakablah Posted April 12, 2011 Share Posted April 12, 2011 Support a vendor, ask m sprank! Link to comment Share on other sites More sharing options...
SBT Posted April 12, 2011 Share Posted April 12, 2011 ^ This! If you can tear down the brakes, pop out the pads and re-lube the backing plates, I'd imagine that your screeching/squealing will go away. Those plates are there predominantly to keep those noises at bay. While you're in there, you might as well re-lube your caliper sliders and bleed your brakes if it's been a year or so. Found that SoCal weather swings was hard on the fluid, that and a lot of mountain and desert driving, nearly every weekend. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
havanahjoe Posted April 12, 2011 Share Posted April 12, 2011 ^ This! If you can tear down the brakes, pop out the pads and re-lube the backing plates, I'd imagine that your screeching/squealing will go away. Those plates are there predominantly to keep those noises at bay. While you're in there, you might as well re-lube your caliper sliders and bleed your brakes if it's been a year or so. Found that SoCal weather swings was hard on the fluid, that and a lot of mountain and desert driving, nearly every weekend. Duh of course, I'll definitely work with Mike. We actually did all that when he did the 30k service on the car, didn't help. Jose also tried many things to no avail. I have had this squeaking since the car was new. "Normal" according to Subaru. Link to comment Share on other sites More sharing options...
SBT Posted April 12, 2011 Share Posted April 12, 2011 Time for a vid/sound clip. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted April 14, 2011 Share Posted April 14, 2011 Anyone know a good wheel repair shop? Firestone FACKED up my wheels. I dont wanna talk about it I just wanna find a fix. Personal experience is a must, I can search the internet myself. Anyone? Help!!! Link to comment Share on other sites More sharing options...
SBT Posted April 14, 2011 Share Posted April 14, 2011 I was going to send my Volk GT-Vs to True Wheel in North Hollywood. Recommended on all of the high-end forums for quality and quick turn-around. Really take pride in the work and a job well done. Check some of the before and afters on their website. Contact info: True Wheel 12547 Sherman Wy, Ste D North Hollywood, CA 91605 Neighborhood: North Hollywood (818) 765-5577 www.truwheel.com/ GL and post up the BF and AFTAs - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted April 14, 2011 Share Posted April 14, 2011 Thank you very much Dale! I am about 20 minutes from there sans traffic. I will be sure to post up an entire thread about Firestone, what they did, how I handled it and what the end results are. I cant post a thread/be objective about it yet - still too angry/disappointed. They may "just" be drag wheels but they were my drag wheels and they were FLAWLESS. Link to comment Share on other sites More sharing options...
Piripi Posted April 14, 2011 Share Posted April 14, 2011 Good luck with the 101 Brazilian Arnold. True wheel, repairs cracked wheels too????. My sister in law gave me her crackedOZ supperleggeras. She doesn't know how or when it happen,which suprises me even more. Link to comment Share on other sites More sharing options...
Piripi Posted April 14, 2011 Share Posted April 14, 2011 Nevermind. I just checked their website. They do cracks. Not crack. Link to comment Share on other sites More sharing options...
SBT Posted April 14, 2011 Share Posted April 14, 2011 I wonder - could they have fixed this...from a few years back after an encounter of the pothole from hell kind out in Anza Borrego just North of Ocotillo - not far from Sprank's place. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
leftcoast74 Posted April 24, 2011 Share Posted April 24, 2011 Wicked crack! I need to get some wheels refinished too. Link to comment Share on other sites More sharing options...
jaymesbry Posted April 24, 2011 Share Posted April 24, 2011 Anyone know any good wheel refinishers in San Diego? after my stupid old roommate jacked them up I feel like getting them just completely refinished. hrmm too bad i cant find anybody that can make them hyper black.. Link to comment Share on other sites More sharing options...
SBT Posted April 24, 2011 Share Posted April 24, 2011 JB - if you can find a spare set, I'd take them off and drop them with True Wheel - save on the shipping. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
Drew888 Posted April 26, 2011 Share Posted April 26, 2011 Thank you very much Dale! I am about 20 minutes from there sans traffic. I will be sure to post up an entire thread about Firestone, what they did, how I handled it and what the end results are. I cant post a thread/be objective about it yet - still too angry/disappointed. They may "just" be drag wheels but they were my drag wheels and they were FLAWLESS. Just Tire scratched up my then new Rota Subzeros and I made them buy me a new wheel. Good luck...sorry for the bad news. [URL="http://legacygt.com/forums/vbpicgallery.php?do=view&g=1586"VbGallery/URL] Link to comment Share on other sites More sharing options...
blklgt05 Posted May 13, 2011 Share Posted May 13, 2011 Can someone suggest a good alignment place in SD area? mod journal Link to comment Share on other sites More sharing options...
SBT Posted May 13, 2011 Share Posted May 13, 2011 I always used East County Alignments in Santee. Big into the off-road and racing scene and will set up your car to your specs (and make recommendations for the type of driving you do). Took all of my Subes there - they have my highest recommendation. More info here East County Alignments (866) 562-4110 10741 Woodside Ave. Santee, Ca. 92071 - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
Alfred_Buchi Posted May 16, 2011 Share Posted May 16, 2011 Chipped keys - cut and coded for 70 bucks Ace Hardware in Tustin. Not sure how many other Ace's have the code machines, and the keys are generic, but I don't care if the key I'm going to cut up for my remote start has a subaru logo on it anyway. I bet if you took a key you got online they could cut and code it for you for cheap too. Might be a good option for the all in one keys people love so much. Link to comment Share on other sites More sharing options...
SBT Posted May 16, 2011 Share Posted May 16, 2011 Pics? - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
m sprank Posted May 16, 2011 Share Posted May 16, 2011 Still here to assist the locals. Link to comment Share on other sites More sharing options...
m sprank Posted July 2, 2011 Share Posted July 2, 2011 have a safe and happy 4th of July weekend. Link to comment Share on other sites More sharing options...
leftcoast74 Posted August 6, 2011 Share Posted August 6, 2011 Bump for this thread and anyone who can help me sort out my electrical/ecu problems. Link to comment Share on other sites More sharing options...
