ProSport gauges owners - Satisfaction survey
BOXRPWR
Rate your Satisfaction Index with ProSport Gauges
31 members have voted
  1. 1. Rate your Satisfaction Index with ProSport Gauges
    • Very Satisfied - no real problems (definately buy again)
      14
    • Satisfied - works well enough (buy again on a budget)
      13
    • Marginally Satisfied - work okay (buy another brand if you can)
      1
    • Not Satisfied - suck, problems etc. (would not buy again)
      3
  • Replies 177
  • Created
  • Last Reply
It sounds like you have the gauges hooked up to a dimmable circuit (wrong). The orange wire needs to be on a full 12v circuit. I can only guess you are tied into the clock circuit. I suggest you either A) turn up the dimmer switch or B) wire the orange wire to the "tail lamps" fuse/circuit.
whats strange is that it worked fine before. ill take a look to see what we did. i installed it a while back
