jxjjang Posted June 28, 2006 Share Posted June 28, 2006 hey guys, i'm pretty new to this forum. i've switched out my low and high beams to xenon bulbs. i recently just purchased a set of H3 xenon foglights but it's a bitch getting into the foglight compartment. anyone know of any tricks that i can do to replace my foglights without doing major body work? thanks guys Link to comment Share on other sites More sharing options...
ralphyralph5 Posted June 28, 2006 Share Posted June 28, 2006 It all depends on what you call "Major", this takes about 20 minutes(maybe longer on your first try): http://legacygt.com/forums/walkthroughs-basic-operation-maintenance/15343-removing-foglights-pics.html Link to comment Share on other sites More sharing options...
SuperhawkLGT Posted June 28, 2006 Share Posted June 28, 2006 Going in from the bottom is easiest, I think. Link to comment Share on other sites More sharing options...
Turbotechnique Posted September 3, 2009 Share Posted September 3, 2009 Hey guys. I've only had my 05' LGT for a week now and I had a headlight and fog light go out. Did the headlight, Simple. However I cant figure out how to get to the fog light. In the manuel it says to have the dealer do it. I have to pay to have the dealer change a friggin' bulb?!?!?! Can some on help me? Thanks Walk through link isn't working either. Link to comment Share on other sites More sharing options...
jxjjang Posted September 3, 2009 Author Share Posted September 3, 2009 use a flathead screwdriver to pry out the foglight covers in the front of your car (use a cloth to prevent scratches). go underneath your car to take our two or three pop-its to access the foglight area. you'll find two bolts that you'll have to take out (12mm). once you do that, you can take the foglight housing out from the front and change them out. good luck! Link to comment Share on other sites More sharing options...
pillboy Posted September 3, 2009 Share Posted September 3, 2009 Glass cutter FTW. It is still ugly. Link to comment Share on other sites More sharing options...
hifonic Posted September 3, 2009 Share Posted September 3, 2009 I just pull the whole bumper off, 5 minute job. Link to comment Share on other sites More sharing options...
AV8TORSADF Posted September 3, 2009 Share Posted September 3, 2009 It's pretty dumb to hide any lights that need replacing behind so much equipment! Not thinking too far ahead! Link to comment Share on other sites More sharing options...
Turbotechnique Posted September 4, 2009 Share Posted September 4, 2009 use a flathead screwdriver to pry out the foglight covers in the front of your car (use a cloth to prevent scratches). go underneath your car to take our two or three pop-its to access the foglight area. you'll find two bolts that you'll have to take out (12mm). once you do that, you can take the foglight housing out from the front and change them out. good luck! Thanks. This does seem to be the best solution. I started to try it but the "pop-it's" seem like they want to break. Did you just replace them afterwards? Thanks Link to comment Share on other sites More sharing options...
FocuS Posted September 4, 2009 Share Posted September 4, 2009 No...you just have to be careful when you pry them as they get clogged with dirt and junk. Link to comment Share on other sites More sharing options...
bluesuby Posted September 4, 2009 Share Posted September 4, 2009 use a flathead screwdriver to pry out the foglight covers in the front of your car (use a cloth to prevent scratches). go underneath your car to take our two or three pop-its to access the foglight area. you'll find two bolts that you'll have to take out (12mm). once you do that, you can take the foglight housing out from the front and change them out. good luck! I found if you pop out the 2 or 3 pop-its, you can pry back the inner fender lining and remove the bulb from the rear of the housing. PITA? You bet, but I would not want to remove the housings. Link to comment Share on other sites More sharing options...
Gire Posted September 4, 2009 Share Posted September 4, 2009 ^^^^ +1 This is how you do it. I sat and watched my mechanically minded friend swap my bulbs while I was drinking beers. Link to comment Share on other sites More sharing options...
jxjjang Posted September 7, 2009 Author Share Posted September 7, 2009 i found it a little difficult to get under the undercarriage lining and get my hands inside to work the bulbs. taking the housing out is a piece of cake and you can easily see what you're doing. one extra step than bluesuby's method, but it's easier to work the wiring for the H3 bulbs! Link to comment Share on other sites More sharing options...
pillboy Posted September 7, 2009 Share Posted September 7, 2009 ^^^^ +1 This is how you do it. I sat and watched my mechanically minded friend swap my bulbs while I was drinking beers. You either drink fast ("beers"), or he is kinda of slow...or maybe he had already had his beers. It is still ugly. Link to comment Share on other sites More sharing options...
veritas Posted October 23, 2009 Share Posted October 23, 2009 Is there any difference between years. I have an 08? Link to comment Share on other sites More sharing options...
jxjjang Posted October 23, 2009 Author Share Posted October 23, 2009 i believe the 08+ uses 9006 bulbs? i'm sure you can find info somewhere around here Link to comment Share on other sites More sharing options...
veritas Posted October 23, 2009 Share Posted October 23, 2009 My bad, I should have clarified. I meant is the changing them out procedure the same? Link to comment Share on other sites More sharing options...
Strizzy Posted October 23, 2009 Share Posted October 23, 2009 My bad, I should have clarified. I meant is the changing them out procedure the same? Changing out the foglight bulbs on my 08 took me less than 10 minutes total to replace both bulbs and aim the lights. If I remember right, there were 2 pop-it's, and one screw. Once those are removed, the access panel can be moved out of the way and bulbs removed/replaced and lights aimed. My bad luck build Link to comment Share on other sites More sharing options...
veritas Posted October 24, 2009 Share Posted October 24, 2009 Just did this. Assuming you can get under the front bumper, this was stupid easy. thanks for the help guys! Link to comment Share on other sites More sharing options...
Polo08816 Posted October 31, 2009 Share Posted October 31, 2009 Changing out the foglight bulbs on my 08 took me less than 10 minutes total to replace both bulbs and aim the lights. If I remember right, there were 2 pop-it's, and one screw. Once those are removed, the access panel can be moved out of the way and bulbs removed/replaced and lights aimed. Was there a vertical adjustment screw just like there is with the headlights for the low beams? Do you happen to have a picture or know of a thread that shows how to aim the fog lights? http://legacygt.com/forums/showthread.php?t=77597&highlight=PIAA+bulbs Link to comment Share on other sites More sharing options...
lu0hh Posted October 31, 2009 Share Posted October 31, 2009 hi im new to this forum and i wanted to install fog lights onto my legacy. any suggestions or stuff? Link to comment Share on other sites More sharing options...
