direavenger Posted June 14, 2006 Share Posted June 14, 2006 ...by my dealership Well its 15,000 mile service time and I was told that it would cost $250. I called BS, and had them do the Lube, oil filter, and safety inspection. I had my tires rotated at 12,000 miles, but thes rest of the stuff I'm not sure about. Is all of this really necessary? My service manual says no, but I wanted to ask you guys. I know that there are various threads about this, but I did not see a difinitive answer. Here is the pamphlet they gave me: The Dude - Two inches and counting... Link to comment Share on other sites More sharing options...
c-lo Posted June 14, 2006 Share Posted June 14, 2006 you don't have to take it to a dealer you know..... 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
PGT Posted June 14, 2006 Share Posted June 14, 2006 they need some help writing that pamphlet. 15k intervals are not 15k, 45k, 75k, 105k etc Link to comment Share on other sites More sharing options...
HansGT Posted June 14, 2006 Share Posted June 14, 2006 BS! no fuel filter at 15K. check the subaru site for what is needed. grease hinges wooohooo! Link to comment Share on other sites More sharing options...
Underdog Posted June 14, 2006 Share Posted June 14, 2006 you could take care of all that work on a weekend in less than 3 hours for less than $100. (and that's including beer money!) Also, "27 Point Safety Inspection" is when the tech working on your car takes his daily dump. IMO, unless your time is super valuable, do it yourself... pride + knowing its a job well done > taking it in the poop chute from the dealer The Crimson Dynamo Link to comment Share on other sites More sharing options...
Underdog Posted June 14, 2006 Share Posted June 14, 2006 they need some help writing that pamphlet. 15k intervals are not 15k, 45k, 75k, 105k etc is that more of the VA sarcasm? The Crimson Dynamo Link to comment Share on other sites More sharing options...
PGT Posted June 14, 2006 Share Posted June 14, 2006 Nope! Wouldn't 15k intervals be 15k/30/45k/60k/75k, etc? They got it right on the 30k intervals. Link to comment Share on other sites More sharing options...
direavenger Posted June 14, 2006 Author Share Posted June 14, 2006 Thanks for the comments...I realize that I don't need to take it to the dealer, which is why I refused any service other than the oil change and the "safety inspection" (the inspection was free). After further research on the fuel filter, I now realize that it is BS. Two quick questions:-Does the PCV valve need to be replaced at 15k?-How can I inspect the battery charging system (if this is at all needed)? I'm an electrical engineer, but rather ignorant of cars so I thought I'd give it a shot. The Dude - Two inches and counting... Link to comment Share on other sites More sharing options...
Underdog Posted June 14, 2006 Share Posted June 14, 2006 Nope! Wouldn't 15k intervals be 15k/30/45k/60k/75k, etc? They got it right on the 30k intervals. Oh, i see... semantics... should read: 15k service - Starting at 15k miles and repeating at 30k mile intervals. 30k service - Starting at 30k miles and repeating at 30k intervals. The Crimson Dynamo Link to comment Share on other sites More sharing options...
Underdog Posted June 14, 2006 Share Posted June 14, 2006 Thanks for the comments...I realize that I don't need to take it to the dealer, which is why I refused any service other than the oil change and the "safety inspection" (the inspection was free). After further research on the fuel filter, I now realize that it is BS. Two quick questions: -Does the PCV valve need to be replaced at 15k? -How can I inspect the battery charging system (if this is at all needed)? I'm an electrical engineer, but rather ignorant of cars so I thought I'd give it a shot. PCV valve = so cheap you might as well (~$3-5) Autozone will check your alternator and battery for free, so that might be worth checking out. Also, throw a fluke on your cables and check the resistance. I'm sure an EE can figure out if there is continuity or not. The Crimson Dynamo Link to comment Share on other sites More sharing options...
Subastew Posted June 14, 2006 Share Posted June 14, 2006 Thanks for the comments...I realize that I don't need to take it to the dealer, which is why I refused any service other than the oil change and the "safety inspection" (the inspection was free). After further research on the fuel filter, I now realize that it is BS. Two quick questions: -Does the PCV valve need to be replaced at 15k? -How can I inspect the battery charging system (if this is at all needed)? I'm an electrical engineer, but rather ignorant of cars so I thought I'd give it a shot. To answer your questions first, no and they will do that for free if you ask. I recently did my 15k service, and it was $80 WITH synthetic oil. They did all the recommended service, plus a couple extra crappy gimmics they try to sell you for more than they should (like fuel additive junk). Link to comment Share on other sites More sharing options...
direavenger Posted June 14, 2006 Author Share Posted June 14, 2006 PCV valve = so cheap you might as well (~$3-5) Autozone will check your alternator and battery for free, so that might be worth checking out. Also, throw a fluke on your cables and check the resistance. I'm sure an EE can figure out if there is continuity or not. Thanks for the info...and the vote of confidence The Dude - Two inches and counting... Link to comment Share on other sites More sharing options...
andrew.anderson Posted June 14, 2006 Share Posted June 14, 2006 The intervals make sense. Link to comment Share on other sites More sharing options...
Underdog Posted June 14, 2006 Share Posted June 14, 2006 The intervals make sense. hey don't rock the boat man! The Crimson Dynamo Link to comment Share on other sites More sharing options...
psucaptainkickass Posted June 14, 2006 Share Posted June 14, 2006 The intervals make sense. Yeah they make total sense because every other 15k service is a 30k service. Apologies in advance for being Mr. Obvious. Link to comment Share on other sites More sharing options...
PGT Posted June 14, 2006 Share Posted June 14, 2006 so, every 30k miles there's a '15k service'? :kekeke: ummkay...maybe they should call it the 'half off special'! Link to comment Share on other sites More sharing options...
psucaptainkickass Posted June 14, 2006 Share Posted June 14, 2006 so, every 30k miles there's a '15k service'? :kekeke: ummkay...maybe they should call it the 'half off special'! Man..I am gonna have to spell this out : 15k - 15k Service 30k - 30k Service ...still with me? 45k - 15k Service (30 + 15...) 60k - 30k Service.... 75k - 15k Serv.... So every second 15k service is a 30k service...you know to change all those different parts that you have change every 30k. ::rolls eyes:: Link to comment Share on other sites More sharing options...
