br7sv9x8 Posted May 15, 2006 Share Posted May 15, 2006 has anyone done a reverse intake manifold on the LGT with the STI manifold? also ran the pipes throw the front with out moving the alteratior?? if you have any pix please post?? thanks -br7sv9x8 Link to comment Share on other sites More sharing options...
Xenonk Posted May 15, 2006 Share Posted May 15, 2006 not that I have seen.. just a lot of clearance issues to deal with to make it work.. are you planning to run and FMIC?? Keefe Link to comment Share on other sites More sharing options...
br7sv9x8 Posted May 15, 2006 Author Share Posted May 15, 2006 something like that and i want to find the shortest way to run it. Link to comment Share on other sites More sharing options...
jsalicru Posted May 15, 2006 Share Posted May 15, 2006 Umm, its easier to reverse it with the LGT manifold than it is with the STi unit. Check out PDX Tuning's car here on this site. On IWSTi or NASIOC check out Nixlimited's STi. He's running the LGT unit, reversed with a Perrin GT30. Got 460whp with race gas. "some say, his arms are made of coiled adamantium fibers. And that he tops his cereal with nuts and bolts. All we know is, he's called the Jose." Link to comment Share on other sites More sharing options...
mwiener2 Posted August 4, 2010 Share Posted August 4, 2010 Thread Bump!! Anyone have pictures or a link (direct link, not go search this 1200 post long thread) of a plastic reverse mounted manifold? My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
m sprank Posted August 6, 2010 Share Posted August 6, 2010 Its an STi, but I think this is what you are looking for Mike. Link to comment Share on other sites More sharing options...
mwiener2 Posted August 6, 2010 Share Posted August 6, 2010 exactly what I was looking for. Thanks My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
m sprank Posted August 6, 2010 Share Posted August 6, 2010 No problem. I enjoy checking out different set ups. Gives me ideas for future projects. I collect engine bay shots for just such projects. This guy built one mean arse big turbo motor. His block is fully built too. I really like the powder coat on the pipes for color match. Custom DP is nice too. Heck of a lot of work to be different. Gotta hand it to the guy. It came out clean. Link to comment Share on other sites More sharing options...
mwiener2 Posted August 6, 2010 Share Posted August 6, 2010 I havn't dug into it yet, but I think our plastic manifold reverse easier than the metal ones. We don't have to move alternator or power steering pump. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
m sprank Posted August 6, 2010 Share Posted August 6, 2010 From my understanding it is not that difficult. Lots of plumbing to do, but as you can see from the final pic. The power steering, alternator and A/C are all intact. Link to comment Share on other sites More sharing options...
rtbrjason Posted August 6, 2010 Share Posted August 6, 2010 Nice pics.. That seems so much more efficient. Link to comment Share on other sites More sharing options...
m sprank Posted August 6, 2010 Share Posted August 6, 2010 That turbo is breathing better, thats for sure. Link to comment Share on other sites More sharing options...
rao Posted August 6, 2010 Share Posted August 6, 2010 I doubt the intake manifold can hold up to the stress. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
m sprank Posted August 6, 2010 Share Posted August 6, 2010 Yeah Rob your probably right. No way it can handle sitting on top of the motor. Bet it breaks in a matter of minutes, LOL. Link to comment Share on other sites More sharing options...
rao Posted August 6, 2010 Share Posted August 6, 2010 I have read that plastic intake manifolds are pretty weak and prone to leaks. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
m sprank Posted August 6, 2010 Share Posted August 6, 2010 I read that the world is gonna end. The sky is falling too. Better use it now before its too late. Link to comment Share on other sites More sharing options...
TRSCobra Posted August 6, 2010 Share Posted August 6, 2010 With the TB on the right side, there's no way you can run a stock location turbo, though. Link to comment Share on other sites More sharing options...
DrSpeed Posted August 6, 2010 Share Posted August 6, 2010 Seems like that there is the same amount of plumbing involved with that setup as well. From the stock location, the pressurized tubes do a lap around the engine, and it seems to be the same case going in a clockwise rotation too. Instead of routing back up the left side to the intake manifold from the CAC, now the turbo feeds the CAC along the the firewall, following the left fender. hmm.... BANNED FROM THE TIKI FORUM. Link to comment Share on other sites More sharing options...
mwiener2 Posted August 6, 2010 Share Posted August 6, 2010 my setup will have no pipes around the back of the engine now My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
DrSpeed Posted August 6, 2010 Share Posted August 6, 2010 my setup will have no pipes around the back of the engine now That's what you need. Have the turbo on one side, run across the CAC, and have the inlet on the other. BANNED FROM THE TIKI FORUM. Link to comment Share on other sites More sharing options...
integroid Posted August 6, 2010 Share Posted August 6, 2010 my setup will have no pipes around the back of the engine now So are you going to use a FMIC that has the inlet and outlets on the same side? Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted August 6, 2010 Share Posted August 6, 2010 Great innovative thinking [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
rockle3 Posted August 6, 2010 Share Posted August 6, 2010 I read that the plastic intake manifold is prone to explosion to anything over 3 lbs of boost. Link to comment Share on other sites More sharing options...
DrSpeed Posted August 6, 2010 Share Posted August 6, 2010 I read that the plastic intake manifold is prone to explosion to anything over 3 lbs of boost. how do you explain the MAP at 16.5 psig? BANNED FROM THE TIKI FORUM. Link to comment Share on other sites More sharing options...
m sprank Posted August 7, 2010 Share Posted August 7, 2010 Sarcasm. You missed Robs earlier posts. We were all getting in on the gag. Link to comment Share on other sites More sharing options...
