wcbjr Posted January 26, 2006 Share Posted January 26, 2006 Is the fuel tank under the rear seat? I need to ground my system in the trunk and want to drill into the side of the spare tire well. Just want to make sure not to drill into anything important. I forgot what I was supposed to remember. Link to comment Share on other sites More sharing options...
sandwood Posted January 26, 2006 Share Posted January 26, 2006 yes, it is. if you pull out the bottom cushion from the rear seat you get access to the fuel pump assembly. getting out of the legacy game Link to comment Share on other sites More sharing options...
rao Posted January 26, 2006 Share Posted January 26, 2006 Why drill at all, there are plenty of places to put a ground back in the trunk or under the rear seat. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
wcbjr Posted January 26, 2006 Author Share Posted January 26, 2006 I want the ground to be as short as possible. The amps are sitting on a carpeted board on top of the spare tire. I cannot run the cable under the trunk mat because it is a 0 gauge cable. So I want to have a 1-2 foot cable terminating on the side of the spare tire well. I forgot what I was supposed to remember. Link to comment Share on other sites More sharing options...
rao Posted January 26, 2006 Share Posted January 26, 2006 I'd go 1-2 feet to the rear seat supports or the seat belt anchors. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
wcbjr Posted January 26, 2006 Author Share Posted January 26, 2006 I can't run it under the trunk mat...... I forgot what I was supposed to remember. Link to comment Share on other sites More sharing options...
rao Posted January 26, 2006 Share Posted January 26, 2006 Then be sure to look carefully becuse the tank is under the rear seat. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
PGT Posted January 26, 2006 Share Posted January 26, 2006 I used a JL master grounding lug kit. I drilled a small hole in the lower edge of the spare tire well, all the way forward and to the left. Looking at Manville Smith's pics, that's where they did his car as well. Oh...make sure you use a wire wheel and strip the paint down to bare metal. Also, a smear of silicone over everything (inside and out) should be used. Link to comment Share on other sites More sharing options...
mbacis Posted January 26, 2006 Share Posted January 26, 2006 I grounded in the spare tire well also. Sanded down the area and used a self tapping screw. Link to comment Share on other sites More sharing options...
mccorry Posted January 26, 2006 Share Posted January 26, 2006 I'd NEVER drill on a new car! Talk about places for rust to start.... Why don't you pour some salt water on it, while you're at it! Link to comment Share on other sites More sharing options...
gt_ltd Posted January 26, 2006 Share Posted January 26, 2006 Is the fuel tank under the rear seat? I need to ground my system in the trunk and want to drill into the side of the spare tire well. Just want to make sure not to drill into anything important. careful man, someone's fuel tank got drilled by his audio shop (do a search for teh whole story).. This Space For Rent Link to comment Share on other sites More sharing options...
wcbjr Posted January 26, 2006 Author Share Posted January 26, 2006 It's most likely going to get grounded on the license plate side, or gas filler neck of the tire well. I forgot what I was supposed to remember. Link to comment Share on other sites More sharing options...
PGT Posted January 26, 2006 Share Posted January 26, 2006 I'd NEVER drill on a new car! Talk about places for rust to start.... Why don't you pour some salt water on it, while you're at it! That's why you seal it with silicone man!! Link to comment Share on other sites More sharing options...
Boulderguy Posted January 27, 2006 Share Posted January 27, 2006 And what's wrong with grounding into the gas tank?? I thought liquid was a good conductor... Link to comment Share on other sites More sharing options...
msmith Posted January 27, 2006 Share Posted January 27, 2006 You can also spray paint on after you have tightened the ground connection and then hit it on the underside of the car with a spray-on rustproofer. Link to comment Share on other sites More sharing options...
