quick4dr Posted May 24, 2015 Share Posted May 24, 2015 Installed an AEM oil pressure gauge today in about 45 minutes. Used pro sport oil galley plug kit, and wired harness with a add a fuze tap off the cigarette fuse. Grounded it under the dash. Ran the wire through the firewall in the clutch grommet location since I'm 5eat. Gauge is in center dash gauge pod. Simple install, great alternative instead of using a sandwhich plate at the filter. Link to comment Share on other sites More sharing options...
jhawk222 Posted June 27, 2015 Share Posted June 27, 2015 Great write up. My dealership was asking $16 for the plug:eek: Link to comment Share on other sites More sharing options...
silentsnow31802 Posted August 15, 2015 Share Posted August 15, 2015 Has anyone installed the prosport halo oil pressure gauge kit into this location? The sender is quite small compared to others I have seen. I would like to avoid the long steel branded hose if possible. Trying to keep things clean under the hood. Sent from my C6916 using Tapatalk Link to comment Share on other sites More sharing options...
Shello007 Posted August 16, 2015 Share Posted August 16, 2015 I installed mine in the front galley. Link to comment Share on other sites More sharing options...
Turkeylord Posted August 17, 2015 Share Posted August 17, 2015 I was able to fit my AEM sender if the front location as well. Link to comment Share on other sites More sharing options...
Flinkly Posted September 30, 2015 Share Posted September 30, 2015 Does anyone have their old galley plug still? would like to know how much thread engagement i have so i can design up a part to use. Don't really want to take mine out, measure, then put it back in. too many suspected issues to cause one more... Also, for those that put their sensors where the OEM switch is, do you transfer the switch to the rear galley plug and reconnect it to the ECU? * Build Thread * 26.53 MPG - 12 month Average * Link to comment Share on other sites More sharing options...
Turkeylord Posted September 30, 2015 Share Posted September 30, 2015 I can check mine when I get home, pretty sure I know where it's at. From memory, it's about 5/16 deep. I left my oil pressure light disconnected. If I wanted to have it again, I'd replace the stock sensor with an adjustable aftermarket one set to 15 PSI or so. Link to comment Share on other sites More sharing options...
jhawk222 Posted October 1, 2015 Share Posted October 1, 2015 Metric Standard I don't know if this helps........but these are the pics of the threading on the galley plugs. Link to comment Share on other sites More sharing options...
Turkeylord Posted October 1, 2015 Share Posted October 1, 2015 ^ Yup, I'll confirm. Just shy of 1/2" on the threads. Link to comment Share on other sites More sharing options...
Flinkly Posted October 1, 2015 Share Posted October 1, 2015 SO, my thought was to have one "custom" made since it's basically free to me, rather than paying for a part ($9 from Kinugawa, $13 from ProSport) + shipping, to save monies where i can for other parts i can't just make, but now that i'm looking around, you can get an O2 bung from anywhere and just drill it out and tap it for 1/8 NPT. i've already got a bung plug at the homestead, so might try that. just an FYI. i'll probably also have a few "custom" made, just cause i can. i'd offer the extra's up, but the Kinugawa price is pretty low already.... * Build Thread * 26.53 MPG - 12 month Average * Link to comment Share on other sites More sharing options...
Knapp Posted December 3, 2017 Share Posted December 3, 2017 Old thread I kmow, but could you upload the photos to the sites server? All thats showing is the photobucket garbage Instead. Thanks! Link to comment Share on other sites More sharing options...
Prosport Gauges Posted December 5, 2017 Share Posted December 5, 2017 SO, my thought was to have one "custom" made since it's basically free to me, rather than paying for a part ($9 from Kinugawa, $13 from ProSport) + shipping, to save monies where i can for other parts i can't just make. just an FYI. i'll probably also have a few "custom" made, just cause i can. i'd offer the extra's up, but the Kinugawa price is pretty low already.... Keep in mind the $13 INCLUDES shipping. Link to comment Share on other sites More sharing options...
