Phosoup253 Posted November 10, 2023 Share Posted November 10, 2023 (edited) 05 LGT Screwed up one of my water pump block thread. Over torqued the bolt to 13ft lbs and sure enough the bolt broke. In the process of extracting the bolt, I seemed to made it worse. At that point I’ve decided to just get the correct heli coil kit and make a new thread. Just when I thought all was well, it wasn’t. I didn’t center the heli coil so back to square one. I’ve tried gasket maker and just 5/6 bolts holding the pump on but still leaks. Any suggestions? Such a shame, was a low mileage longblock too at 65k IMG_1600.mov Edited November 10, 2023 by Phosoup253 Link to comment Share on other sites More sharing options...
Phosoup253 Posted November 10, 2023 Author Share Posted November 10, 2023 (edited) Beyond repair? Yeah I scuff the mating surface pretty bad as well. Edited November 10, 2023 by Phosoup253 Link to comment Share on other sites More sharing options...
GearJamr Posted November 10, 2023 Share Posted November 10, 2023 (edited) If it fits, you could try a size larger bolt. I'm guessing it's M6? Maybe tapping it at 1/4 or even M8? Or if you can drill the hole out some, and get a sleeve you can press in and tap to proper size. At this point, worth a shot. A Dremel with a buffing attachment might help get rid of the gouges. Or getting a metal filler..... Edited November 10, 2023 by GearJamr Link to comment Share on other sites More sharing options...
Max Capacity Posted November 10, 2023 Share Posted November 10, 2023 Please tell us, that's not a horizontal gouge across the sealing surface about 11 o'clock ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Phosoup253 Posted November 10, 2023 Author Share Posted November 10, 2023 Yeah there are some gouging on the sealing surfaces I’m not so proud of. Combination of being frustrated, back problems and not being the most patient individual led me to being a little careless while tackling this job with the limited space. Luckily I didn’t put everything back together so pulling engine should take no longer than 30 min. I’ll have this on a stand and take some better pics. 1 Link to comment Share on other sites More sharing options...
Enlight Posted November 10, 2023 Share Posted November 10, 2023 I would use some Permatex RTV on that gouge to see if it will hold. Those small bolts can be tricky, I bought an inch-pound torque wrench on eBay for those. muFreight.co A JDM Container Sharing Service from Japan to NYC Website | Instagram | Email Bessie II's Thread Link to comment Share on other sites More sharing options...
KZJonny Posted November 10, 2023 Share Posted November 10, 2023 You really can’t have too many torque wrenches. A little reading up on tolerances and how % accuracy is measured helps as well. I misunderstood some of that early into working on cars and engines, and made some mistake (broke some bolts) that I really should not have. A clutch basket retaining bolt in my KZ650 comes to mind…. Regretfully. 1 Link to comment Share on other sites More sharing options...
Phosoup253 Posted November 11, 2023 Author Share Posted November 11, 2023 Yeah think my next move is just go a size up in bolt size and re thread 1 Link to comment Share on other sites More sharing options...
silverton Posted November 11, 2023 Share Posted November 11, 2023 I'm surprised that bolt broke at 13ft/lb. that's only 5nm over spec. 13ftlb = 17nm, spec is 12nm. just for the record subaru wants you to do two passes of 12nm starting at the top going clockwise, saabaru on the other hand wants one pass of 8nm and a second pass of 12nm. I suppose someone prior could have abused the threads and weakened them. If you're lucky that will still seal, be sure to use an OE metal crushy type gasket. Link to comment Share on other sites More sharing options...
