buppus Posted April 12, 2023 Share Posted April 12, 2023 I have seen a couple of threads where users stated this could be done, but I can't find any confirmation or pictures/video of the method. Can anyone give me some tips and tricks to getting this done? I really do NOT want to pull the dash. BTW, my issue is drivers side blowing hot regardless of dual auto climate control settings. Mode switch works fine, and passenger side switches from cold to hot no problem. At first it was stock on blowing only cold, and I was just going to be happy with that but one cold morning the system decided to switch to heat and get stuck there... So it seems like a straightforward diagnosis of the driver's side blend actuator. Spring doesn't last long in TX and I need that drivers side AC to work or I'll melt all over the leather. Link to comment Share on other sites More sharing options...
m sprank Posted April 12, 2023 Share Posted April 12, 2023 1 Link to comment Share on other sites More sharing options...
buppus Posted April 12, 2023 Author Share Posted April 12, 2023 That is on the passenger side my friend. I'm asking about the driver's side. Link to comment Share on other sites More sharing options...
m sprank Posted April 12, 2023 Share Posted April 12, 2023 (edited) Same deal. You get to have the pedals in your shoulder. I have posted the vacation pix all over the forum. Download a set and figure it out. Edited April 12, 2023 by m sprank Link to comment Share on other sites More sharing options...
SoobyDoobyDoo Posted April 13, 2023 Share Posted April 13, 2023 To clarify: this is to replace the drivers’ side without removing the dash? As I understood it, pass side is accessible through glove box but you had to replace drivers’ side by removing dash. Thanks for info! Link to comment Share on other sites More sharing options...
buppus Posted April 13, 2023 Author Share Posted April 13, 2023 So far I have received two helpful tips to accomplish this without removing the dash. 1. Pull the center console cubby and use that access to pop out the instrument cluster - this should give the basic access needed to swap the actuator, but the lower center stack trim may also need to be removed for the lower screws. 2. Make sure you have a very compact 1/4" bit ratchet available to get into that tight space - even a stubby screwdriver probably won't be able to get in there. There's a fella over at the OB forum that says he is going to attempt this sometime next week and report back, so if he follows through I will update here as well. 2 Link to comment Share on other sites More sharing options...
SoobyDoobyDoo Posted April 13, 2023 Share Posted April 13, 2023 That’s awesome! Thank you so much! Please let us know how that goes for him that’ll be a game changer! Link to comment Share on other sites More sharing options...
Rusty9 Posted April 13, 2023 Share Posted April 13, 2023 Been dreading doing this as I have the same issue. (un)Fortunately, my dash is all cracked from sitting in the garage so it's gotta come out anyway now. 1 Link to comment Share on other sites More sharing options...
leetdrv Posted April 14, 2023 Share Posted April 14, 2023 I had the same issue, stuck on hot air on driver side side. The driver side actuator was much harder to replace than the passenger side and if I remember correctly I did not have to remove the cluster. 1 Link to comment Share on other sites More sharing options...
Infosecdad Posted April 14, 2023 Share Posted April 14, 2023 I'm pretty sure I've replaced the driver's side actuator by just removing the driver's side kick panel under the steering wheel. It's wonderfully uncomfortable to jamb in there to get it out, but didn't come anywhere close to removing the dash. 3 Link to comment Share on other sites More sharing options...
m sprank Posted April 14, 2023 Share Posted April 14, 2023 Like I said. Same deal as passenger, you just get the joy of having the throttle pedal in your ear and the others against your shoulder. At my age, I would probably have a younger assistant lay across the floor board and over the sill. 1 1 Link to comment Share on other sites More sharing options...
SoobyDoobyDoo Posted April 15, 2023 Share Posted April 15, 2023 I hear that…that’s a whole lot better than removing the entire dash. In the time I havent driven my car it’s now on defrost and feet exclusively. Time to get in there… Link to comment Share on other sites More sharing options...
blackobxt Posted April 15, 2023 Share Posted April 15, 2023 Does anyone have part numbers for the actuators? Mine also sounds like a percolator. Link to comment Share on other sites More sharing options...
buppus Posted April 17, 2023 Author Share Posted April 17, 2023 The Driver's side blend actuator is 72131AG27A. I'm leaving the passenger side alone for the time being. Link to comment Share on other sites More sharing options...
Pleides Posted April 17, 2023 Share Posted April 17, 2023 2 hours ago, buppus said: The Driver's side blend actuator is 72131AG27A. I'm leaving the passenger side alone for the time being. Luckily for you the passenger side is substantially easier to get to. There are three actuators all in the same place so while you have the kick panel out, mess with the climate control settings and watch all three do their magic. You can drive around with the interior somewhat pulled apart for a couple days while you wait to replace any extra parts you found dead. As a bonus, you can finally replace that cabin air filter you've probably never replaced! 1 Link to comment Share on other sites More sharing options...
Rusty9 Posted April 17, 2023 Share Posted April 17, 2023 For what it's worth you can get the entire HVAC unit with all the actuators, heater core, a/c evap, etc for cheaper than the 3 actuators separately. But you know the old saying, they start with the heater core on the assembly line and build the car around it. 1 3 Link to comment Share on other sites More sharing options...
SoobyDoobyDoo Posted April 18, 2023 Share Posted April 18, 2023 Good write ups/info here: And here: Link to comment Share on other sites More sharing options...
buppus Posted April 27, 2023 Author Share Posted April 27, 2023 Ok, problem solved. Fella on the OB forum did a fantastic writeup with good pictures, here's the link. https://www.subaruoutback.org/threads/drivers-side-hvac-blend-door-actuator-replace-without-pulling-the-whole-dash.552721/post-6361198 3 Link to comment Share on other sites More sharing options...
xt2005bonbon Posted April 27, 2023 Share Posted April 27, 2023 On 4/17/2023 at 4:44 PM, Rusty9 said: For what it's worth you can get the entire HVAC unit with all the actuators, heater core, a/c evap, etc for cheaper than the 3 actuators separately. But you know the old saying, they start with the heater core on the assembly line and build the car around it. Link? I am going to do the following very soon: replace dash, replace driver side actuator, replace heater core, replace passenger airbag. Still not sure if it is worth getting an OEM vs non OEM heater core. Not even sure if the a/c evap should be replaced or not. But as far as I saw, the latter is $$$. Link to comment Share on other sites More sharing options...
KZJonny Posted April 27, 2023 Share Posted April 27, 2023 6 minutes ago, xt2005bonbon said: Link? I am going to do the following very soon: replace dash, replace driver side actuator, replace heater core, replace passenger airbag. Still not sure if it is worth getting an OEM vs non OEM heater core. Not even sure if the a/c evap should be replaced or not. But as far as I saw, the latter is $$$. Someone here was saying it’s cheaper to get the whole HVAC box as a unit then the cost of just the actuators…. (SubOperator?) I didn’t follow up on that since I’ve for some second hand actuators Ima try cleaning up and swapping out first. But if you’re going to do the whole dash anyway. I think the HVAC core ha the evaporator and heater core included. Link to comment Share on other sites More sharing options...
Rusty9 Posted April 27, 2023 Share Posted April 27, 2023 https://www.subarupartsdeal.com/parts-list/2008-subaru-legacy/heater_air_conditioner/heater_system.html?filter=(1%3DS%3B2%3D255%3B4%3D6MT%3B5%3D25GTB)&diagram=02 Seems like it went up a bit from last year...but its still a good value if you need to replace all the other stuff. 72110AG07A or 72110AG07B depending on production date. 2 Link to comment Share on other sites More sharing options...
KZJonny Posted April 27, 2023 Share Posted April 27, 2023 Oh man. Add reading glasses to the list of stuff I need. 1 Link to comment Share on other sites More sharing options...
xt2005bonbon Posted April 27, 2023 Share Posted April 27, 2023 When you search for the part number Rusty listed, then you see what the 'kit' includes and its price. I can't believe this.. https://www.subarupartsdeal.com/parts/subaru-heater-unit~72110ag07a.html Link to comment Share on other sites More sharing options...
hateitorloveit Posted June 1, 2023 Share Posted June 1, 2023 (edited) All of my vents are blowing hot air. Could this still be an issue with this actuator? My car was in storage over the winter and I was hearing the intermittent clicking noise from that actuator before I last used it. Is it possible to swap the driver side actuator without removing the gauge cluster? I've removed the dash a couple times but wasn't able to remove it without removing the steering wheel first. I think some people have different versions of the Legacy with telescoping steering wheels that make this task easier but mine doesn't have that. Edited June 1, 2023 by hateitorloveit Link to comment Share on other sites More sharing options...
SoobyDoobyDoo Posted June 1, 2023 Share Posted June 1, 2023 Are you able to change modes? Ie, can you switch from defrost to vents to feet? Mine has been doing that and recently, my driver side actuator went out. I cannot switch between the different modes. If yours is only blowing out hot air. It’s probably one of the ones on the passenger side. Link to comment Share on other sites More sharing options...
