Mr. Electric Wizard Posted September 19, 2021 Share Posted September 19, 2021 I was about to order one of these but now I'm not exactly sure which one I need, and if they hold up overtime. This the one that I'm thinking about getting but unsure if it will fit my car (2006 OBXT): https://www.amazon.com/Fumoto-F106N-Drain-Valve-Nipple/dp/B07D995XRF/ref=pd_bxgy_img_2/141-8348809-0403124?pd_rd_w=4Bk0P&pf_rd_p=c64372fa-c41c-422e-990d-9e034f73989b&pf_rd_r=36M73QCTYT09ATHAW3G2&pd_rd_r=aa4f014d-f79a-4bbf-a929-6555fea1622b&pd_rd_wg=HDz9L&pd_rd_i=B07D995XRF&psc=1 Anybody use one? And how did it hold up over time? Thanks! Link to comment Share on other sites More sharing options...
Febreze Mee Posted September 19, 2021 Share Posted September 19, 2021 I've got one on the Outback. They are awesome and very convenient fwiw. Unfortunately, and I am one of very, very few outliers, mine has developed the smallest leak ever. No dripping. Just seepage. This was noticed after 6K miles (two oil changes) I'll be addressing this much sooner than later. FWIW, most everyone else has not had any issues and had nothing but great experiences with them. MILKRUN - Click Here Link to comment Share on other sites More sharing options...
Max Capacity Posted September 19, 2021 Share Posted September 19, 2021 I have three of them, been using them for many years. No leaks, ever. Get the nipple and a short hose, drain directly into a jug. Hint, empty milk gallon jug with a screw on top, Walmart has 1% mile for $2.35 or less. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
csaari Posted September 19, 2021 Share Posted September 19, 2021 You can look up which one you need on Fumoto's web site, https://www.fumotousa.com. I believe you need F105, which is what I have on my '05 Legacy. I went with the "S" variant, with the short nipple. It has been on the car for just over 5 years, works great with no issues whatsoever, I love it. Link to comment Share on other sites More sharing options...
motorbreath Posted September 20, 2021 Share Posted September 20, 2021 Same here, draining directly into an empty oil jug is the way to go. The only drawback is that you do not get a small amount of oil out due to Fumoto valve threads being quite deep. I have three of them, been using them for many years. No leaks, ever. Get the nipple and a short hose, drain directly into a jug. Hint, empty milk gallon jug with a screw on top, Walmart has 1% mile for $2.35 or less. Link to comment Share on other sites More sharing options...
aero901 Posted September 26, 2021 Share Posted September 26, 2021 Have one on an OB and it's definitely a mess/time saver. Only worry is knocking it on something (road debris, tall rocks on 4x4 roads, etc) since it does stick out further than the stock oil plug... Keep the stock oil plug in the car just in case. Link to comment Share on other sites More sharing options...
tocinoman25 Posted September 26, 2021 Share Posted September 26, 2021 on my 08 leggy for 8+ years IIRC and on my 07 Honda Accord 2+years was on 11 Legacy for 7+ years all with no issues Follow me on IG @chefodiycarguy and @chefo.soriano Link to comment Share on other sites More sharing options...
Homedepotmade Posted October 4, 2021 Share Posted October 4, 2021 1.5 years in. Oil changes are a breeze now. No mess either. Link to comment Share on other sites More sharing options...
Febreze Mee Posted October 12, 2021 Share Posted October 12, 2021 Performed an oil change the other day. Fixed the smallest leak from my Fumoto oil drain valve. The issue was due to under-torqueing the valve. Rookie mistake. Drained 4.5 QTs into a 5QT container with ease. 10/10 still recommend. MILKRUN - Click Here Link to comment Share on other sites More sharing options...
mccorry Posted October 13, 2021 Share Posted October 13, 2021 261K miles on my Fumoto and have never had an issue! Link to comment Share on other sites More sharing options...
Guest Posted October 16, 2021 Share Posted October 16, 2021 (edited) Had my Fumoto on the LGT for 15 years. Zero problems. EDIT: also for on several Toyotas I also have. Zero problems. Edited October 16, 2021 by unclemat Link to comment Share on other sites More sharing options...
big ears Posted October 16, 2021 Share Posted October 16, 2021 Have them on all of our cars, Subarus and others. The Fumoto valve just works and makes sense oil changes are a breeze. Link to comment Share on other sites More sharing options...
HDTurbo Posted October 16, 2021 Share Posted October 16, 2021 Had 'em on 3 Subarus and the new car, 20+ years. Never had an issue. Link to comment Share on other sites More sharing options...
RacerX69 Posted November 9, 2021 Share Posted November 9, 2021 I put a Stahlbus valve on all my vehicles. Put one on my 05 Legacy when I did the first oil change. Never need a wrench to drain the oil. Comes with a cap, and the drain hose. Link to comment Share on other sites More sharing options...
RWebb Posted November 9, 2021 Share Posted November 9, 2021 The only drawback is that you do not get a small amount of oil out due to Fumoto valve threads being quite deep. I found tipping the car slightly helps with this issue. Link to comment Share on other sites More sharing options...
