SSpeed Posted March 11, 2021 Share Posted March 11, 2021 How long do stock coil packs last? I have 154k, modded for well over 100k of that, bigger turbo, e85. Just had a terrifying situation where the coil pack cutout at WOT, put me in limp mode and gave a cylinder 4 misfire. When I pulled the coil pack, cylinder 1's coil pack bolt was actually starting to back out and I could rock the coil pack around. 90% sure that was my problem, but I swapped 1 and 4 anyway, tightened them down and started back up. Running perfect again, but got me wondering how long coil packs last and if I should swap them all out as preventative maintenance. It looks like it would be about $320 for the set. Link to comment Share on other sites More sharing options...
Holla Posted March 11, 2021 Share Posted March 11, 2021 Mine are all original too. 16 years, 182k miles. I have a spare set I keep in the spare tire well for situations like you’re describing but I’ve never had any issues with mine. Link to comment Share on other sites More sharing options...
Pleides Posted March 11, 2021 Share Posted March 11, 2021 They are rubber, so they don't last forever. That said, I didn't replace mine during an engine rebuild and mine are 16 years old with 217K on them and work fine. It rains a lot here and I'm not getting water past them or anything like that. Link to comment Share on other sites More sharing options...
Max Capacity Posted March 11, 2021 Share Posted March 11, 2021 296,500 miles on the four that came on the car. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
SSpeed Posted March 11, 2021 Author Share Posted March 11, 2021 296,500 miles on the four that came on the car. Impressive! Link to comment Share on other sites More sharing options...
Code Posted March 11, 2021 Share Posted March 11, 2021 I have replaced three of the four over 11.5yr and 54k miles. "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
GEE-OTTO Posted March 11, 2021 Share Posted March 11, 2021 I replaced mine @ 182K miles when I got tuned. Link to comment Share on other sites More sharing options...
JJr Posted March 11, 2021 Share Posted March 11, 2021 I have replaced three of the four over 11.5yr and 54k miles. You're definitely not driving her enough, she's hating you! Link to comment Share on other sites More sharing options...
Febreze Mee Posted March 12, 2021 Share Posted March 12, 2021 You're definitely not driving her enough, she's hating you! Big facts! Throw me the keys and we can fix that. In almost two weeks I've put 1K miles on my car I need help. MILKRUN - Click Here Link to comment Share on other sites More sharing options...
Code Posted March 12, 2021 Share Posted March 12, 2021 You're definitely not driving her enough, she's hating you! First one failed during a logging pull. It wouldn’t fire properly under high load. Second one failed while on a spirited back road drive and wouldn’t fire properly under load. Third one failed during removal. The rubber boot tore so I replaced it. The two that had operational issues were both beginning to weld rate at the layered metal block. "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
