edgemoulic Posted November 17, 2020 Share Posted November 17, 2020 Hello Everyone hope everything is well. I Just started on changing all my doors because of rust here in my place especially on winter times. I found similar color which matches all my doors and bumpers. But I’m thinking to get the hood since my Legacy is non turbo. Would that hole Will give me a problem if I change mine with it. Link to comment Share on other sites More sharing options...
whitexc Posted November 17, 2020 Share Posted November 17, 2020 Others will correct me but you haven't mentioned the year of your car which matters when it comes to the hood/front clip area. There were slight changes to the fourth gen design in XXXX (2007?) model year. Someone....anyone? Thanks for taking care of that car though, turbo or not. It deserves the love. Sent from my moto z3 using Tapatalk Link to comment Share on other sites More sharing options...
edgemoulic Posted November 18, 2020 Author Share Posted November 18, 2020 It is under my username. It will be Overkill to mention again what year and model. Unless they only read the wordings here. Link to comment Share on other sites More sharing options...
solidxsnake Posted November 18, 2020 Share Posted November 18, 2020 2005-2007 is all interchangable when it comes to hoods. 08-09 is different. Link to comment Share on other sites More sharing options...
edgemoulic Posted November 18, 2020 Author Share Posted November 18, 2020 It is interchangeable my main question is since my Legacy is non Turbo. What Will be the Best thing to do with the hole in the Middle of it. Would it be ok Or should I put something to block debris going in my engine. Link to comment Share on other sites More sharing options...
DoctorDaveLGT Posted November 18, 2020 Share Posted November 18, 2020 2005-2007 is all interchangable when it comes to hoods. 08-09 is different. Partially correct. All legacy hoods from 05-09 are interchangeable, its the 08-09 outback hoods that differ and are not interchangeable. 05-07 outback hoods are interchangeable with all 05-09 legacy's. Putting a turbo hood w/ scoop on your car isn't going to hurt anything. I rarely get debris in my hood scoop but if it worries you I would just put some mesh on the back of the scoop under the hood. Link to comment Share on other sites More sharing options...
JmP6889928 Posted November 23, 2020 Share Posted November 23, 2020 All of the 90's OB had scoops and no turbo. You'll be fine with it. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 23, 2020 Share Posted November 23, 2020 This brings back old memories of the of that thread asking if it was ok to take my GT to the car wash, what happens if soapy water gets into the tmic...LOL 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
