Tehnation Posted August 20, 2020 Author Share Posted August 20, 2020 (edited) Imagine if you take ecuflash, romraider, and learning view, dumbed it all down, removed all the complicated stuff, and then shoved it in a little box smaller than a smartphone. Its like big brother is holding your hand, "make sure to disconnect those green cables"! "Turn the car off for 15 seconds".. it walks you through everything. Very nice software. Edited August 20, 2020 by Tehnation Link to comment Share on other sites More sharing options...
rhino6303 Posted August 20, 2020 Share Posted August 20, 2020 Imagine if you take ecuflash, romraider, and learning view, dumbed it all down, removed all the complicated stuff, and then shoved it in a little box smaller than a smartphone. Its like big brother is holding your hand, "make sure to disconnect those green cables"! "Turn the car off for 15 seconds".. it walks you through everything. Very nice software.So did you marry the accessport to your car and flash a tune to it already? Was a tuner able to get you a basemap for your AP? Link to comment Share on other sites More sharing options...
Tehnation Posted August 20, 2020 Author Share Posted August 20, 2020 Yep, should have a new map by tonight or tomorrow. Link to comment Share on other sites More sharing options...
Tehnation Posted August 21, 2020 Author Share Posted August 21, 2020 Can ap read srs codes? My airbag light came on.... Link to comment Share on other sites More sharing options...
whitexc Posted August 22, 2020 Share Posted August 22, 2020 (edited) Good question.....anyone? Sent from my moto z3 using Tapatalk Edited August 22, 2020 by whitexc Link to comment Share on other sites More sharing options...
DaveWaters Posted August 22, 2020 Share Posted August 22, 2020 Negative, AP will not read srs codes Link to comment Share on other sites More sharing options...
Tehnation Posted August 22, 2020 Author Share Posted August 22, 2020 (edited) Hmm I wonder if torque pro can do it!? If not I may have to buy a cheap one, found this guy. https://www.amazon.com/dp/B01MR7FZS1?tag=aq-best-airbag-scan-tools-20 , 80 bucks was the cheapest I could find that read srs/abs etc. Anyone know any other products? Actually, looks like this device doesn't do srs/abs on subarus. -Edit This guy does do abs and srs for subarus. Edited August 22, 2020 by Tehnation Link to comment Share on other sites More sharing options...
Max Capacity Posted August 22, 2020 Share Posted August 22, 2020 Will a Auto Parts store read them for free like CEL codes ? The major chain store do that. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it.  Engine Build - Click Here Link to comment Share on other sites More sharing options...
Tehnation Posted August 22, 2020 Author Share Posted August 22, 2020 I have Accessport, tactrix cable, torque pro.... none of this stuff does srs/abs... sigh. Â What about Subaru FreeSSM? Link to comment Share on other sites More sharing options...
Tehnation Posted August 22, 2020 Author Share Posted August 22, 2020 Will a Auto Parts store read them for free like CEL codes ? The major chain store do that. Most of the auto parts stores I go to only have regular code readers. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 22, 2020 Share Posted August 22, 2020 Most of the auto parts stores I go to only have regular code readers. Thanks, that is what I thought, but figured someone may know the answer. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it.  Engine Build - Click Here Link to comment Share on other sites More sharing options...
Tehnation Posted August 22, 2020 Author Share Posted August 22, 2020 (edited) I will ask around, can't hurt. A lot of times I see them just using whatever they sell. So they may or may not open up a better reader, who knows. Â But I just found this guy. Â https://www.amazon.com/FIXD-Professional-Bluetooth-Reader-Android/dp/B013RIQMEOÂ 60 bucks for some bluetooth scanner, that scans everything apparently. Good thing about amazon is they pretty much take all returns, so I may order it and if it doesn't work just send it back. Â update: This guy looks like a dud as well Edited August 22, 2020 by Tehnation Link to comment Share on other sites More sharing options...
Tehnation Posted August 22, 2020 Author Share Posted August 22, 2020 (edited) I really don't want to spend 150 bucks....the launch seems like the one to get.  https://www.amazon.com/LAUNCH-Transmission-Automotive-Diagnostic-Datastream/dp/B01FDKNBC0 Ordered this guy for 80 bucks, according to their website coverage checker, it does work. If not I'll just return it. https://www.innova.com/Product/Detail/3100j#coverageCheckerSection  https://www.amazon.com/Innova-3100j-CanOBD2-Diagnostic-Screen/dp/B01MR7FZS1 Free one day shipping so I will let you guys know if this works tomorrow. Edited August 22, 2020 by Tehnation Link to comment Share on other sites More sharing options...
Max Capacity Posted August 22, 2020 Share Posted August 22, 2020 Looks like it should work. Good Luck. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it.  Engine Build - Click Here Link to comment Share on other sites More sharing options...
Tehnation Posted August 24, 2020 Author Share Posted August 24, 2020 Tuner knocked out my base map in 2 tunes.... 1st one was good, just needed a little adjustment to get it to find idle again. Just took it out for a spin, car drives good. The ap must make things much easier for the tuner as well. I had other people baffled trying to tune on opensource, they all thought there was a mechanical problem. I guess them saying that the cobb is better for the stage 3 stuff makes sense. Link to comment Share on other sites More sharing options...
m sprank Posted August 25, 2020 Share Posted August 25, 2020 Chassis codes can be read from the dash display on the 05. I posted the instructions long ago. It has been so long, I dont recall if airbag codes were displayed, but probably not. Â Â Â In general it takes a good reader to pull airbag codes. Manufactures get very nervous when anyone touches the airbag system. Lots of legalities involved with the safety system. Link to comment Share on other sites More sharing options...
Tehnation Posted August 25, 2020 Author Share Posted August 25, 2020 I got the reader, it can read the srs codes, but doesn't look like it can clear them, so back to amazon it goes. I got 6 codes. It must be from when I removed the dash and seats, system probably had power. Link to comment Share on other sites More sharing options...
m sprank Posted August 26, 2020 Share Posted August 26, 2020 Could very well be. My $5k+ SnapOn scanner could read and reset the airbag codes. It takes that caliber of scanner. Most cars have stored codes from work being done "hot". I had a bad habit of pulling steering wheels with the power connected. It was faster to reset the codes than pull out memory saver and disconnect the battery. Link to comment Share on other sites More sharing options...
Tehnation Posted August 26, 2020 Author Share Posted August 26, 2020 (edited) i definitely worked on it while the battery was connected, I started the car without the seats while sitting on a bucket. Memory saver? I can reset the srs without a fancy scanner or dealer? Edited August 26, 2020 by Tehnation Link to comment Share on other sites More sharing options...
m sprank Posted August 26, 2020 Share Posted August 26, 2020 No. Sorry. Memory saver is a device used to save the settings in the radio, and ecm while disconnecting the battery. Lets you work on 95% of the car powered down (like airbags) without losing what customers would complain about. Â If you brought a mechanic a 6 pack after work I can almost guarentee the codes will be reset and you might learn a few tips too. Link to comment Share on other sites More sharing options...
Tehnation Posted August 26, 2020 Author Share Posted August 26, 2020 Is there a certain process for resetting the srs code? My reader had a reset function, it just didn't seem to work. I had 6 codes, I couldn't see all 6 coming back at once after reset. So I assumed the reader just couldn't do it. I ordered the launch crp123, apparently most of them are fake, I contacted Launch over in the UK. I probably got a fake one as well, we will see. At this point, i'm going to keep going up the line until I hit one that works. There's gotta be something reasonably priced that can do it. If the bootleg launch doesn't work, then I will try the icarsoft line. Link to comment Share on other sites More sharing options...
blackobxt Posted August 26, 2020 Share Posted August 26, 2020 Is there a certain process for resetting the srs code? My reader had a reset function, it just didn't seem to work. I had 6 codes, I couldn't see all 6 coming back at once after reset. So I assumed the reader just couldn't do it. I ordered the launch crp123, apparently most of them are fake, I contacted Launch over in the UK. I probably got a fake one as well, we will see. At this point, i'm going to keep going up the line until I hit one that works. There's gotta be something reasonably priced that can do it. If the bootleg launch doesn't work, then I will try the icarsoft line. That probably explains why mine does about 10% of what it claims it can do. Does yours feel super light and cheap when you hold it? Link to comment Share on other sites More sharing options...
Tehnation Posted August 26, 2020 Author Share Posted August 26, 2020 (edited) Which, the launch? Not sure haven't gotten it yet.  https://www.launchtechusa.com/ This is the official company site. https://www.launchtechusa.com/product-page/crp-elite The real product. Its 100 dollars more, 235, than the bootleg crp123. MAybe more, autozone is a reseller. Its the Launch crp123 premium, I think the fake is called crp123 professional.  https://www.launchtechusa.com/distributors https://www.autozone.com/test-scan-and-specialty-tools/code-reader/launch-tech-usa-4-0-in-tft-color-display-scan-tool/119870_0_0 Edited August 26, 2020 by Tehnation Link to comment Share on other sites More sharing options...
blackobxt Posted August 26, 2020 Share Posted August 26, 2020 I believe mine is the crp123. Bought it off amazon on sale, it ended up just being a glorified code reader. Really makes me miss having a modis Link to comment Share on other sites More sharing options...
