Tehnation Posted July 20, 2020 Share Posted July 20, 2020 Does anyone know if you need the kartboy spacers with a hotchkiss front sway bar? Link to comment Share on other sites More sharing options...
solidxsnake Posted July 20, 2020 Share Posted July 20, 2020 https://legacygt.com/forums/showthread.php/kartboy-endlinki-240035.html Looks like the answer is yes. Link to comment Share on other sites More sharing options...
Tehnation Posted July 20, 2020 Author Share Posted July 20, 2020 hmm.. I didn't use them before, so its weird, because they fit fine without it. Seems like it would make more sense in the rear because the tabs on my bars bent, I had to heat and hammer the shit out of them to bend them back. Link to comment Share on other sites More sharing options...
Shawn06SpecB Posted July 21, 2020 Share Posted July 21, 2020 spacers on the front, none on the rears with my setup Link to comment Share on other sites More sharing options...
Tehnation Posted July 21, 2020 Author Share Posted July 21, 2020 do you guys remember which hole does what for the rear bar? Ive had my car disassembled for like 3 years lol, i basically live at napa and home depot .... so many missing bolts ...sigh... Link to comment Share on other sites More sharing options...
rhino6303 Posted July 21, 2020 Share Posted July 21, 2020 Here are pictures of front and rear from m_sprank. They were taken from posts 368-370 from this thread. https://legacygt.com/forums/showthread.php/lalgt-rebuild-thread-152682.html?t=152682 Link to comment Share on other sites More sharing options...
Tehnation Posted July 21, 2020 Author Share Posted July 21, 2020 he only uses one spacer for each side as opposed to two. Link to comment Share on other sites More sharing options...
Tehnation Posted July 21, 2020 Author Share Posted July 21, 2020 (edited) i see people using one spacer per side, looks that way in the above picture. I tried it and didn't like it , so i used two. Thanks for all the info guys! The bolts went right in didn't have to use a jack or anything. Edited July 21, 2020 by Tehnation Link to comment Share on other sites More sharing options...
Tehnation Posted July 21, 2020 Author Share Posted July 21, 2020 i painted my bar black.... i musta been bored. now I'm trying to figure out which hole makes the suspension tighter in the rear Link to comment Share on other sites More sharing options...
Tehnation Posted July 21, 2020 Author Share Posted July 21, 2020 (edited) for anyone who needs new hardware. I went to home depot to get the bolts and washers, then autozone for the locking nuts. -pack of 2 bolts m10-1.5 65mm half thread grade 8 are 8$ -pack of 25 of 3/8" washers 4$ -pack of 5 locking m10-1.5 grade 10 nuts 4 dollars. The bolts that came with kartboys are grade 10 i believe and the ones at home depot are grade 8. If you don't have the kartboy spacers, you could probably stack 3 or 4 of these washers if your desperate. Edited July 21, 2020 by Tehnation Link to comment Share on other sites More sharing options...
DaveWaters Posted July 21, 2020 Share Posted July 21, 2020 Hole closest to the end of sway bar for the softest setting. Think of it from a leverage perspective. Just a heads up, grade 8.8 metric is the equivalent of grade 5 SAE. 10.9=8 SAE. I think you’d be better off running a 10.9 at an endlink. Your call though, I always overbuild. Link to comment Share on other sites More sharing options...
Tehnation Posted July 21, 2020 Author Share Posted July 21, 2020 (edited) i guess we are going to find out if they hold up lol!!! I used those in the front, the rear ones I have the kartboy rebuild kit bolts, I needed something now. I shoulda went to pep boys, they have a wider assortment of nuts and bolts.... will throw that on the list, but I will wait and see... its hot as balls outside, and I just want to get the suspension done so i can put my interior back together. This car needs to move asap, I gotta redo my driveway, its been over 3 years since ive redone the driveway cause this piece of shit has been sitting in one spot unable to move. Still gotta get insurance, registration, inspection, tuned and dynoed. Thanks for the info, didn't realize there were two ratings one for sae and metric. At least the nuts are good ROFL!!! https://www.fastenermart.com/understanding-fastener-grades-and-classes.html http://knowhow.napaonline.com/common-automotive-fasteners-guide/ Edited July 21, 2020 by Tehnation Link to comment Share on other sites More sharing options...
Tehnation Posted July 21, 2020 Author Share Posted July 21, 2020 now you have me worried..... Link to comment Share on other sites More sharing options...
Tehnation Posted July 21, 2020 Author Share Posted July 21, 2020 (edited) seriously, screw you.... omw to nappa.... lol You are 100% right... better to be safe than sorry, or do it again, especially for 15 bucks or so. Edited July 21, 2020 by Tehnation Link to comment Share on other sites More sharing options...
Tehnation Posted July 21, 2020 Author Share Posted July 21, 2020 (edited) andddd nappa doesn't have it .... amazon to the rescue! Ordered these guys but they are flanged. what do you guys think? https://www.amazon.com/U-Turn-M10-1-50-Flange-Bolt-Yellow/dp/B07JG64LQ8/ref=sr_1_1?dchild=1&keywords=m10x1.50+65mm+bolt&qid=1595352827&sr=8-1 Edited July 21, 2020 by Tehnation Link to comment Share on other sites More sharing options...
DaveWaters Posted July 22, 2020 Share Posted July 22, 2020 Sorry to get you worried... haha. I see no reason not to use flanged bolts. Now get that thing on the road. 3 years is too long. Link to comment Share on other sites More sharing options...
