Blackbeard Posted July 16, 2020 Share Posted July 16, 2020 Looking for a set of cleaned ID1000cc injectors for my 07 LGT, not a set of the newer 1050x . Also trying to find a OEM turbo upgrade, vf52 or 440xt. Local nj/ny seller preferred of course. Thanks in advance Link to comment Share on other sites More sharing options...
awfulwaffle Posted July 16, 2020 Share Posted July 16, 2020 Because you're open source and lacking the small pulse width compensation tables? Link to comment Share on other sites More sharing options...
Blackbeard Posted July 17, 2020 Author Share Posted July 17, 2020 Yup, I am running open source, and the injector size simply because my tuner requested these specifically, otherwise I'd go with a set of new id1050x's. Link to comment Share on other sites More sharing options...
awfulwaffle Posted July 17, 2020 Share Posted July 17, 2020 (edited) You can add the ECUFlash/Romraider defs to make the 1050s work. Just did it a week ago. What ROM are you on? Cryo recommended me the ID1000s as well over 1050x, but that was because you can't get the 1050x behave at idle without the low pulse width comp tables, which aren't available on opensource by default. Edited July 17, 2020 by awfulwaffle Link to comment Share on other sites More sharing options...
Blackbeard Posted July 17, 2020 Author Share Posted July 17, 2020 (edited) You can add the ECUFlash/Romraider defs to make the 1050s work. Just did it a week ago. What ROM are you on? Cryo recommended me the ID1000s as well over 1050x, but that was because you can't get the 1050x behave at idle without the low pulse width comp tables, which aren't available on opensource by default. Funny you say that, I'm working with Dave from Cryotune at the moment to make this happen. He is requesting help defining tables as followed. Fuel injector trim (small ipw)(max ipw) Fuel injector trim (small ipw)(max rpm) Fuel injector Trim (small ipw) Fuel injector pulse width limit (min) If you can help at all id really appreciate it, and it'll save me some time finding a set of id1000cc injectors, and i can just use the 1050s. How did you get your set to behave? Edited July 17, 2020 by Blackbeard Typo Link to comment Share on other sites More sharing options...
awfulwaffle Posted July 17, 2020 Share Posted July 17, 2020 Yep, them's the ones. You can get into ROM disassembly which takes a pretty expensive piece of software, or you can ask one of the Romraider devs to track them down for you. I had the software at work and gave it a shot, only got half of the tables right and ended up asking one of the Romraider guys to help set the other two straight, so that's probably a better/faster option. You might have luck emailing td-d on the Romraider forums, and sending him some beer money for the trouble. First, though, what ROM are you on? You can find this by popping open the ROM Info dropdown in ECUFlash (under Current ROM Metadata), and looking at the Internal ID line. In the off chance that your ROM inherits from the same base as mine, I can just send you the definition files w/ addresses to get all the above defined. Edit: Also check out the Inherits: line under ROM info - this will tell whether our ROMs inherit from the same base. Would need to say A2WC521N. Link to comment Share on other sites More sharing options...
Blackbeard Posted July 17, 2020 Author Share Posted July 17, 2020 Only so much I can speak confidently about detail wise. Wish I knew a bit more about this, but the learning curve is quite steep, I'm on RomRaider as well, so I'll try and post in the help section or just PM td-d. Sending Beer money is no issue at all. Ecu id:4B12525207 Internal id: A2UI001C Flash Method: subarucan Memory Model:SH7058 Checksum:Subarudbw Inherits: 32bitbase Link to comment Share on other sites More sharing options...
awfulwaffle Posted July 17, 2020 Share Posted July 17, 2020 Yeah, looks like the best bet. Try emailing td-d instead of PMing. Good luck! Link to comment Share on other sites More sharing options...
Blackbeard Posted July 17, 2020 Author Share Posted July 17, 2020 Happen to have that email address? Pm it to me please. And thanks for the assist, I really appreciate it. Link to comment Share on other sites More sharing options...
Shawn06SpecB Posted July 19, 2020 Share Posted July 19, 2020 I have a low mile set of ID1000s and connectors... well and a VF52 as well... Link to comment Share on other sites More sharing options...
cheeseenlo Posted July 21, 2020 Share Posted July 21, 2020 PM'd you on the ID1000s and PNP connectors. Link to comment Share on other sites More sharing options...
